Windscribe VPN using Wireguard on Mikrotik that works!
I have tried many tutorials to using Windscribe VPN service using IPsec and Wireguard and had very bad results. I just found a YT video posted 3 weeks ago that explained how to do it for other VPN Provider and went to test if it worked with Windscribe using Wireguard and it worked flawless. Without the hassle to set firewall permissions and forward ports. in the video also tells how to access LAN and tunnel internet data through the vpn using Policy rules. fast and easy. If you were having issues before, or could not establish a connection, they will be gone. I am using a RB5009 router. Thanks to MikroTik Masters from YT.
Here is the link:
https://www.youtube.com/watch?v=mDv40BBYs8w
Its better than most but still has some meandering not well explained items and some errors but overall not a bad video.
The fact that you state firewall rules should have no bearing on the wireguard config also detracts from the post ( aka your assessment).
