Wireguard and VLAN
maybe I’m stupid. I’m using my RB4011 sucessfully with since the first 7 beta with wireguard (without VLANs).
Now I’m changing my config and I’m using 3 VLANs Using this example config).
But I’cant get running wireguard. Wireguard should use the vlan 90.
I’v added wireguard to the vlan-bride. I set the frame-types=admit-only-untagged-and-priority-tagged und vlan=90.
Maybe it’s a firewall rule? But I dont know which.
Please give me a hint. Thank you very much.
Here is the config (I delete wlan).
# sep/04/2021 10:28:33 by RouterOS 7.1rc1
# software id = 8H40-SBMV
# model = RB4011iGS+5HacQ2HnD
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface wireguard
add listen-port=11197 mtu=1412 name=wireguard1
/interface vlan
add interface=BR1 name=BASE_VLAN vlan-id=90
add interface=BR1 name=Obergeschoss vlan-id=92
add interface=BR1 name=Untergeschoss vlan-id=91
add name=WAN
add name=VLAN
add name=BASE
add name=Untergeschoss ranges=192.168.91.50-192.168.91.254
add name=Obergeschoss ranges=192.168.92.50-192.168.92.254
add name=BASE_POOL ranges=192.168.90.50-192.168.90.254
add address-pool=Untergeschoss interface=Untergeschoss name=UntergeschossDHCP
add address-pool=Obergeschoss interface=Obergeschoss name=ObergeschossDHCP
add address-pool=BASE_POOL interface=BASE_VLAN name=BASE_DHCP
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=\
    wlan1 pvid=91
    wlan4 pvid=91
    wlan2 pvid=92
    wlan5 pvid=92
    wlan3 pvid=90
    wlan6 pvid=90
    ether2 pvid=90
    ether3 pvid=90
    ether4 pvid=90
    ether5 pvid=90
    ether6 pvid=90
    ether7 pvid=90
    ether8 pvid=90
    ether9 pvid=91
    wireguard1 pvid=90
add bridge=BR1 interface=ether10
set discover-interface-list=VLAN
/interface bridge vlan
add bridge=BR1 tagged=BR1,ether10 untagged=wlan3,wlan6 vlan-ids=90
add bridge=BR1 tagged=BR1,ether10 untagged=wlan1,wlan4 vlan-ids=91
add bridge=BR1 tagged=BR1,ether10 untagged=wlan2,wlan5 vlan-ids=92
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN wan-interface-list=\
    WAN
/interface l2tp-server server
set l2tpv3-circuit-id="" l2tpv3-cookie-length=0 l2tpv3-digest-hash=md5
add interface=ether1 list=WAN
add interface=BASE_VLAN list=VLAN
add interface=Obergeschoss list=VLAN
add interface=Untergeschoss list=VLAN
add interface=BASE_VLAN list=BASE
/interface wireguard peers
add allowed-address=10.9.0.0/24,192.168.1.0/24 endpoint-address=xxxx.de \
    endpoint-port=11199 interface=wireguard1 public-key=\
    "key"
add allowed-address=10.9.0.0/24,192.168.200.0/24 endpoint-address=\
    yyyy.de endpoint-port=11198 interface=wireguard1 public-key=\
    "key"
add address=192.168.90.1/24 interface=BASE_VLAN network=192.168.90.0
add address=192.168.1.44/24 disabled=yes interface=ether1 network=192.168.1.0
add address=192.168.91.1/24 interface=Untergeschoss network=192.168.91.0
add address=192.168.92.1/24 interface=Obergeschoss network=192.168.92.0
add address=10.9.0.7/24 interface=wireguard1 network=10.9.0.0
/ip dhcp-client
add address=192.168.90.0/24 dns-server=1.1.1.1 gateway=192.168.90.1
add address=192.168.91.0/24 dns-server=1.1.1.1 gateway=192.168.91.1
add address=192.168.92.0/24 dns-server=1.1.1.1 gateway=192.168.92.1
set allow-remote-requests=yes servers=1.1.1.1
add action=accept chain=input comment="Allow Estab & Related" \
add action=accept chain=forward comment=Wireguard dst-port=11197 log=yes \
    log-prefix=WG: protocol=udp
add action=accept chain=input dst-port=11197 log=yes log-prefix=WG: protocol=\
    udp
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" \
    in-interface=BASE_VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" \
add action=accept chain=forward comment="VLAN Internet Access only" \
    connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment="Default masquerade" \
add distance=1 gateway=192.168.1.1
add disabled=no dst-address=192.168.200.0/24 gateway=wireguard1 \
    routing-table=main suppress-hw-offload=no
add disabled=no dst-address=192.168.1.0/24 gateway=wireguard1 routing-table=\
Servus,
I don’t think putting a WireGuard interface into a bridge works, since WireGuard works on Layer 3 (IP), whereas bridges work on Layer 2 (MAC).
I can’t quite figure out what you’re trying to do, but if you want the (encrypted) WireGuard traffic to be routed via a non-standard route trough VLAN90, you will have to use policy based routing.
Thank you.
I want to connect My 192.168.90.0/24 (VLAN 90) network connected via my 10.9.0.0/0 network to my 2 other places (192.168.1.0 and 192.168.200.0).
I will look again my config.
The best thing to do is post you config and we can what is missing.
one thing is probably rule to ensure internet returning traffic goes back out the tunnel etc…
and maybe firewall rules to allow WG access to vlan etc..
Anyway post your config
and network diagram would be helpful also
Hello, my config is already in #1.
But here is a simple network diagram. Thank you!
rb4011vlan.pdf (303 KB)
(1) I do not believe you an attach wireguard as a bridge interface as its neither an ethernet port or wlan port. Thus remove.
wireguard1 pvid=90
(2) For untagged vlans, they are not required to be shown on the interface bridge vlan settings but you have done so for wlan ports but not ethernet ports.
I prefer manually inserting them as you have so it clear to me and the reader what is going on. Just be consistent, all or none I guess.
Here is what I would have…
add bridge=BR1 tagged=BR1,ether10 untagged=wlan3,wlan6,ether2,ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=90
add bridge=BR1 tagged=BR1,ether10 untagged=wlan1,wlan4,ether9 vlan-ids=91
(3) What is the purpose of this rule?? It should be deleted in my opinion.
I understand the similar rule you have for the INPUT chain as this will be used for the initial connection from the external user to your RB4011 server.
udp
(4) I like the drop all rule at the end of the input chain, but what is the purpose of the two input rules for interface lists. Clearly the VLAN one already includes the base vlans so one or the other is a wasted rule. However what makes sense if ONLY full access is giving to BASE and for the rest, you allow only services required… DNS for example.
Up to you. For example…
add action=accept chain=input comment=“Allow VLAN” in-interface-list=VLAN
add action=accept chain=input comment=“Allow Base_Vlan Full Access”
In other words keep base vlan and for the rest of the users…
add action=accept chain=input comment=“Allow LAN DNS queries - TCP”
connection-state=new dst-port=53 in-interface-list=VLAN protocol=tcp
add action=accept chain=input comment=“Allow LAN DNS queries-UDP”
connection-state=new dst-port=53 in-interface-list=VLAN protocol=udp
(5) You are missing some standard input chain rules
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp ( especially important for troubleshooting wg connections to ensure router availabiility)
(6) You are missing some key forward chain rules…
First rule should be fastrack, also need drop invalid. I am assuming you have no port forwarding to worry about so no need for an allow dstnat rule.
Also the drop invalid rule.
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“Allow Estab & Related”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=forward comment=“VLAN Internet Access only”
(7) Okay lets take a look at IP routes.
add distance=1 gateway=192.168.1.1 - Good, all users/devices have access to the WAN through this connection.
add disabled=no dst-address=192.168.200.0/24 gateway=wireguard1 \ Good, all traffic coming back from the internet get sent back through the tunnel
add disabled=no dst-address=192.168.1.0/24 gateway=wireguard1 routing-table=\ ??? What is the purpose of this route rule??
The first rule will ensure traffic gets to the internet from all subnets and interfaces, and the second rule ensures that any replies from the internet will get back through the tunnel to the other end of the wireguard connection. I dont use ip addresses for my wg interfaces but try removing the last line (disable) and see if you have success.
(8) If you want the wireguard interface to be able to interact with vlan 90, suggest a forward chain rule just before the drop rule.
add chain=forward action=accept in-interface=wireguard out-interface=vlan90
This assumes you want to allow wireguard users to users/devices on vlan90.
If you wish the reverse then switch the in and out interfaces
If you need unsoliticed access both ways then you need two rules.
Please clarify what you mean by …wireguard should use vlan90??
