Hi guys, I have problem with access to NAS server from Media PC connected to VPN provider via Wireguard. NAS is running on 10.100.100.1/24 Main_Lan network with static IP .22 , Media PC is on 10.30.33.1/24 VPN_vlan network with staic IP .204. Everything is working except I can’t ping or access NAS from VPN_Lan network. Thanks for any help.
# oct/23/2022 11:20:33 by RouterOS 7.5
# software id = P0QQ-LSV7
# model = RB5009UG+S+
# serial number = xxxxxxxx
add admin-mac=xxxxxxxxxxxxxxxxx auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether1 ] comment=ISP_Internet_Access name=\
internet_access
set [ find default-name=ether2 ] comment=off_bridge_access_to_router name=\
off_bridge
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface wireguard
add listen-port=13231 mtu=1420 name=WG_Mullvad
/interface vlan
add interface=bridge name=Guest_Wifi vlan-id=66
add interface=bridge name=Lstream vlan-id=22
add interface=bridge name=Main_Lan vlan-id=100
add interface=bridge name=TP-Link vlan-id=44
add interface=bridge name=VOIP vlan-id=55
add interface=bridge name=VPN_vlan vlan-id=33
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=MNGMT
add comment="Deny access to ruter and Main_Lan" name=Untrusted
add name=pool_MNGMT ranges=172.16.100.2-172.16.100.10
add name=pool_Lstream ranges=10.20.22.199-10.20.22.254
add name=pool_VPN_vlan ranges=10.30.33.199-10.30.33.254
add name=pool_VOIP ranges=10.50.55.99-10.50.55.103
add name=pool_Guest_Wifi ranges=10.60.66.199-10.60.66.254
add name=pool_Main_Lan ranges=10.100.100.150-10.100.100.254
add name=pool_TP-Link ranges=172.16.4.99-172.16.4.199
add address-pool=pool_MNGMT interface=off_bridge name=dhcp_MNGMT
add address-pool=pool_Guest_Wifi interface=Guest_Wifi name=dhcp_Guest_Wifi
add address-pool=pool_Lstream interface=Lstream name=dhcp_Lstream
add address-pool=pool_Main_Lan interface=Main_Lan name=dhcp_Main_Lan
add address-pool=pool_TP-Link interface=TP-Link name=dhcp_TP-Link
add address-pool=pool_VOIP interface=VOIP name=dhcp_VOIP
add address-pool=pool_VPN_vlan interface=VPN_vlan name=dhcp_VPN_vlan
/routing table
add disabled=no fib name=useWG
add disabled=no fib name=KODI_to_NAS
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 pvid=100
admit-only-untagged-and-priority-tagged interface=ether4 pvid=100
admit-only-untagged-and-priority-tagged interface=ether5 pvid=100
add bridge=bridge comment=defconf interface=ether6 pvid=100
admit-only-untagged-and-priority-tagged interface=ether7 pvid=44
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=ether8
set discover-interface-list=MNGMT protocol=lldp,mndp
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge comment=Lstream_vlan tagged=bridge,ether8 vlan-ids=22
add bridge=bridge comment=VPN_vlan tagged=bridge,ether8 untagged=ether5 \
vlan-ids=33
add bridge=bridge comment=VOIP_vlan tagged=bridge,ether8 vlan-ids=55
add bridge=bridge comment=Guest_Wifi_vlan tagged=bridge,ether6,ether8 \
vlan-ids=66
add bridge=bridge comment=Main_Lan_vlan tagged=bridge,ether8 untagged=\
ether3,ether4,ether6 vlan-ids=100
add bridge=bridge comment=TP-Link_vlan tagged=bridge untagged=ether7 \
vlan-ids=44
add comment=defconf interface=internet_access list=WAN
add interface=off_bridge list=MNGMT
add interface=off_bridge list=LAN
add interface=Main_Lan list=MNGMT
add interface=WG_Mullvad list=LAN
add interface=Guest_Wifi list=LAN
add interface=Lstream list=LAN
add interface=Main_Lan list=LAN
add interface=TP-Link list=LAN
add interface=VOIP list=LAN
add interface=VPN_vlan list=LAN
add interface=Guest_Wifi list=Untrusted
add interface=Lstream list=Untrusted
add interface=TP-Link list=Untrusted
add interface=VOIP list=Untrusted
add interface=VPN_vlan list=Untrusted
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=xxxxxxxx endpoint-port=\
51820 interface=WG_Mullvad persistent-keepalive=40s public-key=\
"yyyyyyyyyyyyyy"
add address=172.16.100.1/24 comment=ether2_off_bridge_access interface=\
off_bridge network=172.16.100.0
add address=10.60.66.1/24 comment=Guest_Wifi_network interface=Guest_Wifi \
network=10.60.66.0
add address=10.20.22.1/24 comment=Lstream_network interface=Lstream network=\
10.20.22.0
add address=10.100.100.1/24 comment=Main_Lan_network interface=Main_Lan \
network=10.100.100.0
add address=172.16.4.1/24 comment=TP-Link_network interface=TP-Link network=\
172.16.4.0
add address=10.50.55.1/24 comment=Ooma_network interface=VOIP network=\
10.50.55.0
add address=10.30.33.1/24 comment=VPN_vlan_network interface=VPN_vlan \
network=10.30.33.0
add address=10.65.138.98 comment="WG_Mullvad interface address" interface=\
WG_Mullvad network=10.65.138.98
/ip arp
add address=172.16.4.2 comment="TP-Link Archer C7" interface=TP-Link \
mac-address=98:DE:D0:84:9E:26
add address=10.50.55.10 comment=Ooma interface=VOIP mac-address=\
00:18:61:0F:ED:DF
add address=10.20.22.199 comment=Denon interface=Lstream mac-address=\
00:05:CD:1C:D5:84
add address=10.100.100.250 interface=Main_Lan mac-address=68:B5:99:90:04:7A
add address=10.100.100.21 interface=Main_Lan mac-address=74:D4:35:14:60:5B
add address=10.100.100.60 comment=U6-LR interface=Main_Lan mac-address=\
D0:21:F9:DD:65:95
add address=10.100.100.22 comment=NAS interface=Main_Lan mac-address=\
38:60:77:05:95:76
add address=10.100.100.24 interface=Main_Lan mac-address=18:56:80:00:E3:0D
/ip dhcp-client
add comment=defconf interface=internet_access use-peer-dns=no
/ip dhcp-server lease
add address=10.50.55.10 comment=Ooma mac-address=00:18:61:0F:ED:DF server=\
dhcp_VOIP
add address=172.16.4.193 client-id=1:54:2a:1b:a0:1e:f6 comment=Sonos_Bar \
mac-address=54:2A:1B:A0:1E:F6 server=dhcp_TP-Link
add address=172.16.4.194 client-id=1:8:a6:bc:30:1e:e6 mac-address=\
08:A6:BC:30:1E:E6 server=dhcp_TP-Link
add address=10.20.22.75 comment=75TLC-TV mac-address=34:93:42:B2:9A:4D \
server=dhcp_Lstream
add address=10.20.22.65 client-id=00:05:cd:1c:d5:84 comment=Denon \
mac-address=00:05:CD:1C:D5:84 server=dhcp_Lstream
add address=10.100.100.99 client-id=68:b5:99:90:04:7a comment=HP_Printer \
mac-address=68:B5:99:90:04:7A server=dhcp_Main_Lan
add address=10.100.100.21 client-id=74:d4:35:14:60:5b comment=Box1 \
mac-address=74:D4:35:14:60:5B server=dhcp_Main_Lan
add address=10.20.22.55 comment=55TLC-TV mac-address=34:93:42:96:81:9F \
server=dhcp_Lstream
add address=10.100.100.78 client-id=88:53:2e:95:b1:81 comment=Samsung_Laptop \
mac-address=88:53:2E:95:B1:81 server=dhcp_Main_Lan
add address=10.100.100.60 client-id=1:d0:21:f9:dd:65:95 comment=U6-LR \
mac-address=D0:21:F9:DD:65:95 server=dhcp_Main_Lan
add address=10.100.100.24 client-id=1:18:56:80:0:e3:d comment=X1_Wireless \
mac-address=18:56:80:00:E3:0D server=dhcp_Main_Lan
add address=10.100.100.25 client-id=1:0:0:0:6:c2:f5 comment=X1_USB_Wired \
mac-address=00:00:00:06:C2:F5 server=dhcp_Main_Lan
add address=10.100.100.146 client-id=1:f2:7:7e:c3:57:46 comment=iPhoneSE \
mac-address=F2:07:7E:C3:57:46 server=dhcp_Main_Lan
add address=10.30.33.222 client-id=1:18:66:da:21:c0:c comment=KODI \
mac-address=18:66:DA:21:C0:0C server=dhcp_VPN_vlan
add address=10.20.22.0/24 dns-server=10.20.22.1 gateway=10.20.22.1
add address=10.30.33.0/24 dns-server=10.64.0.1,10.30.33.1 gateway=10.30.33.1
add address=10.50.55.0/24 dns-server=10.50.55.1 gateway=10.50.55.1
add address=10.60.66.0/24 dns-server=10.60.66.1 gateway=10.60.66.1
add address=10.100.100.0/24 dns-server=10.100.100.1 gateway=10.100.100.1
add address=172.16.4.0/24 dns-server=172.16.4.1 gateway=172.16.4.1
add address=172.16.100.0/26 dns-server=172.16.100.1 gateway=172.16.100.1
set allow-remote-requests=yes servers=9.9.9.9
/ip dns static
add address=10.100.100.1 comment=def.configuration name=router.lan
/ip firewall address-list
add address=10.20.22.0/24 list=NoAccess
add address=10.30.33.0/24 list=NoAccess
add address=10.50.55.0/24 list=NoAccess
add address=10.60.66.0/24 list=NoAccess
add address=172.16.4.0/24 list=NoAccess
add address=10.100.100.2-10.100.100.254 list=Allow_to_Tp-Link
add address=10.30.33.199-10.30.33.254 list=Allow_to_NAS
established,related,untracked
add action=accept chain=input comment="Allow Untrusted DNS udp" \
connection-state=new dst-port=53 in-interface-list=Untrusted protocol=udp
add action=accept chain=input comment="Allow Untrusted DNS tcp" \
connection-state=new dst-port=53 in-interface-list=Untrusted protocol=tcp
invalid
add action=accept chain=input comment="Allow MNGM to router" \
in-interface-list=MNGMT
add action=drop chain=input comment="Drop all else"
add action=accept chain=forward comment="KODI access to NAS" dst-address=\
10.100.100.22 in-interface=VPN_vlan out-interface=Main_Lan \
src-address-list=Allow_to_NAS
add action=accept chain=forward comment="allow wireguard vpn" in-interface=\
VPN_vlan out-interface=WG_Mullvad
"allow port forwarding(Wireguard DNS)" connection-nat-state=dstnat
connection-state=established,related,untracked hw-offload=yes
established,related
connection-state=invalid
add action=accept chain=forward comment="allow internet traffic" \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=Allow_to_Tp-Link dst-address=\
172.16.4.2 in-interface=Main_Lan out-interface=TP-Link src-address=\
10.100.100.24
add action=drop chain=forward comment="\"Drop all else\""
add action=masquerade chain=srcnat comment="Main_Lan_allow _to_TP-Link" \
out-interface=TP-Link src-address-list=Allow_to_Tp-Link
add action=masquerade chain=srcnat comment=KODI_Access_to_NAS disabled=yes \
in-interface=VPN_vlan out-interface=Main_Lan src-address-list=\
Allow_to_NAS
add action=dst-nat chain=dstnat comment=DNS_for__WG_Mullvad dst-port=53 \
protocol=udp src-address=10.30.33.0/24 to-addresses=10.64.0.1 to-ports=53
add action=masquerade chain=srcnat comment=masquerade_for_WG_Mullvad \
add comment="DNS to WG_Mullvad" disabled=no distance=1 dst-address=\
10.64.0.1/32 gateway=WG_Mullvad pref-src=0.0.0.0 routing-table=main \
scope=30 suppress-hw-offload=yes target-scope=10
add disabled=no dst-address=0.0.0.0/0 gateway=WG_Mullvad routing-table=useWG \
suppress-hw-offload=no
add comment=Kodi_To_NAS disabled=no distance=1 dst-address=10.100.100.22/32 \
gateway=VPN_vlan pref-src="" routing-table=KODI_to_NAS scope=30 \
suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=10.100.100.0/24
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup-only-in-table disabled=no src-address=10.30.33.0/24 table=\
useWG
add action=lookup disabled=no dst-address=10.100.100.22/32 interface=VPN_vlan \
src-address=10.30.33.204/32 table=KODI_to_NAS
/system clock
set time-zone-name=America/New_York
/system identity
set name=TikRouter
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes multicast=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=MNGMT
/tool romon
set enabled=yes
