Wireguard connection permamently lost after IPS disconnection
Hi to all, gens.
I have an issue with Wireguard connection after internet disconnection.
I have a furter network configuration:
  • a Wireguard server on VPS with fixed ip address, wg is configured with that script (maybe it matters due to some iptables settings).
  • two locations (read like two houses) with MT HAP AC2 on one and MT RB951G-2HnD on another (ROS 7.8).
    Both of them have very simmilar configuration: wireguard peer to (not hostname) with Persistent Keepalive=25s.
    Address List entries are marked with “marking connection” for further routing to wg-interface. Not all traffic goes to the tunnel.
    DNS is set to use a DNS-server inside tunnel (10.7.0.1) for all resolving.
The problem is when IPS connection is lost, wireguard connection is not re-establishing. That means IPS connection is working properly, VPS-ip-address is pingable, but wg handshake is always fails (Rx always zero). Even after rebooting router, what suprises me most. And even more - that only happens on hap ac2, not RB951G.
Disabling-enabling wg-peer not helping. Sometimes rebooting VPS helps, sometime - ping from VPS inside tunnel to peer (10.7.0.2 for example).
I cannot reproduce the issue intentionally, because simply pull IPS wire out is not working.
Any advice where to dig and how to debug it?
Sorry for welter with explanation in advance
We are hoping that this is fixed in the latest 7.10 stable release so that re-establishing a connection from client to server works when the server ISP changes, burps etc…
In the meantime many have been using scripts to accomplish this annoying oversight by MT coders…
Check out Para 6 - https://forum.mikrotik.com/viewtopic.php?t=182340
Thanks, anav, I will try 7.10, but when I get proof that it works - I don’t know.
About scripts - I’ve found them before (the ones that disabels wg-peer for some time). As I said I’ve tried to disable-enable it manualy, but it won’t helped. Maybe I should have considered time for re-handshake (Persistent Keepalive) and keep it disabled for longer time, but I haven’t. Will try this next time.
is this fixed? Im still facing this issue. It's not permanently lost, but I have to reboot to reestablish after the provider disconnect.
