Wireguard interface with multiple peers
I’ve seen other discussions about this, but not clear if a change is intended, or if I’ll need to use a dedicated Wireguard interface for each peer:
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface wireguard peers
add allowed-address=192.168.0.2/32 comment=peerA endpoint-address="" interface=wireguard1 public-key="{uniquestringA}"
add allowed-address=192.168.0.3/32 comment=peerB endpoint-address="" interface=wireguard1 public-key="{uniquestringB}"
add address=192.168.0.1/24 interface=wireguard1 network=192.168.0.0
#        routerboard: yes
#         board-name: RB1100AHx4 Dude Edition
#              model: RB1100Dx4
#           revision: r2
#             channel: stable
#   installed-version: 7.5
Kind regards.
So far so good.
What are the user requirements (both local users and remote users).
Hi Anav,
Thank you for your reply.
The peers (peerA and peerB - Windows clients) need to speak to the subnets which sit behind the Mikrotik peer (in the below example - 172.16.0.0/16), e.g.:
This works perfectly for peerA, but peerB is unable to initiate a handshake with the Mikrotik (pcap shows the request reaching the Mikrotik, but it does not reply).
I’ve seen this thread, where I can see that it should be possible to have multiple peers on a single WG interface.
Wireguard client config:
[Interface]
PrivateKey = {local_privatekey}
Address = 192.168.0.2/32
DNS = 1.1.1.1
[Peer]
PublicKey = {Mikrotik_publickey}
AllowedIPs = 192.168.0.0/24, 172.16.0.0/19
Endpoint = 64.12.12.9:13231
PersistentKeepalive = 10
Kind regards.
Yes it should work looking at your information.
Please post full config on router.
/export file=anynameyouwish ( minus serial number and any public WANIP info )
Also ensure that Client B, gets the same public IP from the router that client A received, but the router gets Client Bs public IP and set on the router peer B settings.
Is there some firewall or other setting on peer B windows blocking ??
Hi Anav,
Please see attached config.
Checked and confirmed to be unique.
I don’t believe so, pcap shows the handshake reaching the Mikrotik public IP from peerB’s public IP, but no reply from the Mikrotik:
With peerA, I can see full handshake exchange - as you’d expect.
Kind regards.
wg_hide_02112022.rsc (3.72 KB)
(1) Is this an internet facing router? If so you are in serious deficiency of firewall rules and is really a security risk.
(2) Is this a cloud router, I dont understand your setup at all, need network diagram?
(3) What is the LAN, I see ether1 is disabled so thats not useful. I see bonded ether9 and ether10
and the vlans part of the bonding, so is that your WAN and if so, how does that work?? Is it one WAN, two wans, very confusing overall.
Nothing here to say why A works and B does not.
Hi Anav,
Many thanks for considering this.
The router has access to WAN via one of the VLANs on the bonding interface. The router is essentially an endpoint connected to a pair of TOR switches. WAN connectivity is handled by a cluster of (different) routers. Firewalling is done closer to server cluster by dedicated equipment/systems. Traffic can pass through this router, but there is a deny all rule for input traffic.
One VLAN for (essentially) WAN, one VLAN for management LAN.
Yes, very strange that the router doesn’t respond to the handshake. The public IP of peerB is reachable from the Mikrotik.
Many thanks for your time.
I didn’t check details, but make sure that you have correct keys for peerB. In case there would be some mixup, WG would simply ignore request from, as it would see it, unknown peer.
Sob see post #4!
I’m not sure what you’re trying to say there.
Hi both,
Many thanks for looking into this for me.
I found the solution in this thread. The issue is with the endpoint being set as a blank value in the peer config - “endpoint-address” should be entirely absent if it isn’t specified (peerA below is correct, peerB is incorrect):
add allowed-address=192.168.0.2/32 comment=peerA interface=wireguard1 \
    public-key="peerA_publickey"
add allowed-address=192.168.0.3/32 comment=peerB endpoint-address="" interface=\
    wireguard1 public-key="peerB_publickey"
When I sent the initial config, it was after recreating the nodes entirely, so seems I accidentally fixed the issue for PeerA (for a second time). Just an unfortunate coincidence.
Kind regards.
Sober, much thanks for the feedback. I do now recall reading that thread but not paying enough attention to it.
I will add it to my wireguard article.
To be clear, this only happens if you have entered in an endpoint address but then removed it.
Not quite clear on how this happens?
Hi Anav,
Via the WI, you need to collapse the “Endpoint” field and then click “OK” - not [“Apply” + “OK”] - which seems to commit the empty dropdown. Weirdly, if you return to the peer after committing the config successfully, the empty dropdown will be present again, but not present in the export:
add comment=test1 endpoint-address="" interface=wireguard1 public-key="sgfTz8xpzywdpRvjpeOmBtfQk63pbp3lcNCmKm6GYBk="
add comment=test2 endpoint-address="" interface=wireguard1 public-key="mBmVaeZMhb2ERRZgMn4chRdftAtEysNi4vhX+RxzsEo="
add comment=test3 interface=wireguard1 public-key="rw1TUYHIvayb2ovlhmFZ9m03FUSQt2g39tk0fjnIgRU="
add comment=test4 endpoint-address="" interface=wireguard1 public-key="2713AH/C6kmL5AFq90yOJ+CkQMKlGSBnmQ1NP67NNAg="
Must be a webconfig anomaly!!
It’s interesting, I would have expected that if blank address should have any effect, if would be the same as any wrong address. Which would be something you may not even notice, because WG is very keen on roaming, so even if you set peer’s address to any wrong address, first packet from peer will update current-endpoint-address and it will work just fine:
[sob@CHR5] /interface/wireguard/peers> print detail
Flags: X - disabled
 0   interface=wireguard1 public-key="xxx" endpoint-address=240.240.240.240
     endpoint-port=0 current-endpoint-address=192.168.80.10 current-endpoint-port=64191 allowed-address=192.168.44.10/32
     rx=6.2KiB tx=6.4KiB last-handshake=1s
But blank endpoint-address really does block it completely.
