I created a simple wireguard configuration for 2 peers (Android phone and iPad) the Android phone works without an issue but the iPad doesn’t even handshake. I used qr code to transfer configuration to both and they have same configuration other than ip and keys, I even added ipads configuration to my phone and it worked fine. Below is my config, it’s mostly stock, I’m not sure if it can be an issue on the router side, sounds more like an ios problem but maybe I missed something.
add admin-mac=D4:01:C3:72:DA:8B auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wifi
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.mode=ap .ssid="The Promised LAN" disabled=no name=2ghz \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.mode=ap .ssid="The Promised LAN" disabled=no name=5ghz \
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=lan-pool ranges=192.168.1.100-192.168.1.200
add address-pool=lan-pool interface=bridge lease-time=1d name=lan-dhcp
/queue simple
add disabled=yes max-limit=40M/750M name=queue1 target=192.168.1.0/24
/queue type
add cake-diffserv=diffserv4 cake-flowmode=dual-srchost cake-nat=yes kind=cake \
name=cake-upload
add cake-flowmode=dual-dsthost cake-nat=yes kind=cake name=cake-download
/queue tree
add bucket-size=0.01 max-limit=650M name=download packet-mark=no-mark parent=\
bridge queue=cake-download
add bucket-size=0.01 max-limit=38M name=upload packet-mark=no-mark parent=\
ether1 queue=cake-upload
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=5ghz internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=2ghz internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
/interface wireguard peers
add allowed-address=192.168.100.4/32 client-address=192.168.100.4/32 \
client-endpoint=mord.dev interface=wireguard name=KrzysPixel private-key=\
"<redacted>" public-key=\
"6xJIhMljwYHM3VCe8qyvMd/HRFXROd7K8oTaZqe2xHc="
add allowed-address=192.168.100.3/32 client-address=192.168.100.3/32 \
client-endpoint=mord.dev interface=wireguard name=iPad private-key=\
"lixpcroM8JmU+LUo2MBqQLG5/QFdAfoPG5yZHWPU0Q4="
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
add address=192.168.100.1/24 interface=wireguard network=192.168.100.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.10 client-id=1:4:92:26:d9:4d:c0 mac-address=\
04:92:26:D9:4D:C0 server=lan-dhcp
add address=192.168.1.2 client-id=\
ff:dd:a9:fc:7:0:1:0:1:2d:6e:68:a:d8:3a:dd:a9:fc:7 mac-address=\
D8:3A:DD:A9:FC:07 server=lan-dhcp
add address=192.168.1.3 client-id=1:e4:5f:1:1c:8c:9e mac-address=\
E4:5F:01:1C:8C:9E server=lan-dhcp
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
/ip firewall address-list
add address=hgb09magzq5.sn.mynetname.net list="External ip"
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat dst-address=192.168.1.2 out-interface=\
bridge protocol=tcp src-address=192.168.1.0/24
add action=dst-nat chain=dstnat comment=HTTP,HTTPS dst-address-list=\
"External ip" dst-port=80,443 protocol=tcp to-addresses=192.168.1.2
/ip service
set www disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Warsaw
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Here’s the client configuration that I exported:
[Interface]
PrivateKey = <redacted>
ListenPort = 51820
Address = 192.168.100.3/32
DNS = 8.8.8.8
[Peer]
PublicKey = D6u6AcSXwtppse/lc/JUzEp7aKATJvSacjHUAy3xLlA=
AllowedIPs = 192.168.1.0/24 <I tried with the default 0.0.0.0 too, no dice>
Endpoint = <public ip, I had my domain here and thought it might be the cause but apparently not>:13231
