Wireguard Road Warrior Setup. Problems with iPhone Connection
I am attempting to setup a road warrior Wireguard connection to my router for the purpose of protecting my traffic on insecure public networks and using my home network pi-hole. I appear to have the connection working for a Windows laptop client connecting from another WiFi network. For an iPhone client, I consistently complete the initial handshake, but I get no traffic to or from the internet. Handshake is verified by seeing the handshake time update on the router.
The strange thing is there have been at least three occasions where the traffic was being routed fine for a period of several hours before failing and returning to the state of connection without routing traffic.
My set-up includes 2.4 and 5Ghz Wi-fi with a guest network. I have Ethernet port 5 set-up as a guest port isolated from the netwrok. I have pi-hole and wireguard running on a separate server, but would like to get wireguard running within the Mikrotik. Firewall rules include entries to isolate the wireguard clients too, but it does not work with those turned off either.
Please let me know if you see something I have missed to allow Wireguard traffic to reach the internet.
Config file is below
#2026-06-02 20:33:37 by RouterOS 7.22.1
#software id = 9Z5S-7ZSD
#model = E62iUGS-2axD5axT
#serial number = \[REDACTED\]
add admin-mac=\[REDACTED\] auto-mac=no comment=defconf name=bridge
/interface wifi
set \[ find default-name=wifi1 \] channel.band=2ghz-ax .skip-dfs-channels=
10min-cac .width=20mhz configuration.mode=ap .ssid=\[REDACTED\] disabled=no
name=wifi2g security.authentication-types=wpa2-psk,wpa3-psk .ft=yes
.ft-over-ds=yes
add configuration.mode=ap .ssid=\[REDACTED\] datapath.client-isolation=yes
disabled=no mac-address=\[REDACTED\] master-interface=wifi2g name=
wifi2g-guest security.authentication-types=wpa2-psk,wpa3-psk
set \[ find default-name=wifi2 \] channel.band=5ghz-ax .frequency=5170-5250
.skip-dfs-channels=all .width=20/40/80mhz configuration.mode=ap .ssid=
\[REDACTED\] disabled=no name=wifi5g security.authentication-types=
wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
disabled=no mac-address=\[REDACTED\] master-interface=wifi5g name=
wifi5g-guest security.authentication-types=wpa2-psk,wpa3-psk
/interface wireguard
add listen-port=49876 mtu=1420 name=wg1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=GUEST
add name=dhcp_pool1 ranges=192.168.99.2-192.168.99.254
add name=dhcp_pool2 ranges=192.168.98.2-192.168.98.254
add name=dhcp_pool3 ranges=192.168.97.2-192.168.97.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp_pool1 interface=wifi2g-guest name=dhcp1
add address-pool=dhcp_pool2 interface=wifi5g-guest name=dhcp2
add address-pool=dhcp_pool3 interface=ether5 name=dhcp3 use-reconfigure=yes
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wifi2g
add bridge=bridge comment=defconf interface=wifi5g
/ipv6 settings
set disable-ipv6=yes
add interface=wg1 list=LAN
add interface=wifi2g-guest list=GUEST
add interface=wifi5g-guest list=GUEST
add interface=ether5 list=GUEST
/interface wireguard peers
add allowed-address=192.168.77.1/24 client-address=192.168.77.3/32
client-allowed-address=0.0.0.0/0 client-dns=192.168.88.4 client-endpoint=
\[REDACTED\] comment="\[REDACTED\]" endpoint-port=49876
interface=wg1 name=User1 public-key=
"\[REDACTED\]"
add allowed-address=192.168.77.1/24 client-address=192.168.77.4/32
interface=wg1 name=User2 public-key=
"\[REDACTED\]"
add allowed-address=192.168.77.1/24 client-address=192.168.77.5/32
interface=wg1 name=User3 public-key=
"\[REDACTED\]"
add allowed-address=192.168.77.1/24 client-address=192.168.77.6/32
interface=wg1 name=User4 public-key=
"\[REDACTED\]"
add allowed-address=192.168.77.1/24 client-address=192.168.77.7/32
interface=wg1 name=User5 public-key=
"\[REDACTED\]"
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.98.1/24 interface=wifi5g-guest network=192.168.98.0
add address=192.168.99.1/24 interface=wifi2g-guest network=192.168.99.0
add address=192.168.77.1/24 comment=Wireguard1 interface=wg1 network=
192.168.77.0
add address=192.168.97.1/24 comment="LAN Guest" interface=ether5 network=
192.168.97.0
/ip cloud
set ddns-enabled=yes update-time=no
/ip dhcp-client
add comment=defconf interface=ether1 name=client1 use-peer-dns=no
use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.88.4 client-id=\[REDACTED\] mac-address=
\[REDACTED\] server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.4 gateway=
192.168.88.1
add address=192.168.97.0/24 comment="LAN Guest" dns-server=192.168.88.4
gateway=192.168.97.1
add address=192.168.98.0/24 dns-server=192.168.88.4 gateway=192.168.98.1
add address=192.168.99.0/24 dns-server=192.168.88.4 gateway=192.168.99.1
set allow-remote-requests=yes servers=192.168.88.4
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes
protocol=icmp
add action=accept chain=input comment="Accept Wireguard Handshake" dst-port=
49876 protocol=udp
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=accept chain=forward comment="Allow Guest to reach DNS"
dst-address=192.168.88.4 dst-port=53 in-interface-list=GUEST protocol=udp
dst-address=192.168.88.4 dst-port=53 in-interface-list=GUEST protocol=tcp
add action=accept chain=forward comment="Allow wireguard to reach DNS"
dst-address=192.168.88.4 dst-port=53 in-interface=wg1 protocol=udp
add action=accept chain=forward comment="Allow Wireguard to reach DNS"
dst-address=192.168.88.4 dst-port=53 in-interface=wg1 protocol=tcp
add action=accept chain=forward in-interface=wg1 out-interface-list=WAN
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN
add action=drop chain=forward comment="Drop guest to LAN" in-interface-list=
GUEST out-interface=bridge
add action=drop chain=forward comment="Drop Wireguard to LAN" in-interface=
wg1 out-interface=bridge
add action=drop chain=forward comment="Drop LAN to Wireguard" in-interface=
bridge out-interface=wg1
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=dst-nat chain=dstnat comment="PiServer VPN" dst-port=47111
in-interface=ether1 protocol=udp to-addresses=192.168.88.4 to-ports=47111
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/system clock
set time-zone-autodetect=no time-zone-name=America/New_York
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
The allowed-address field values of all your WireGuard peers are wrong. Currently, they are all set to allowed-address=192.168.77.1/24 which means WireGuard will work for one of the peers only.
When you have multiple peers assigned to the same WireGuard interface (wg1 in your configuration), then the address range in their allowed-address cannot overlap.
All of the peers have allowed-address=192.168.77.1/24, which means all peers say: "Hey I am responsible for the destination 192.168.77.1/24, if anything is sent to any addresses between 192.168.77.1 and 192.168.77.254, use me!".
One of the peers will catch all packets addresses to those 254 addresses, and the other peers receive nothing. WireGuard only works for one peer, usually the one you edited last.
The fix is to edit allowed-address of all peers, and use for of them only their single /32 address, not /24. For example, the first peer should have allowed-address=192.168.77.3/32, the second peer should have allowed-address=192.168.77.4/32, etc... (matches what you currently have in the client-address field of the peers).
Those /32 address ranges are distinct and not overlap. The first peer will then only be responsible for the single destination 192.168.77.3 and not for 192.168.77.4 for example.
  1. I find the fact that you are overlapping subnets on wifi very disconcerting/confusing.
    You provide the bridge a subnet, and the WLANs their own subnet, but then for some reason you put the WLANs (guest) on the bridge???
  2. Either use vlans to separate subnets or simply remove the WLANs (guest) from the bridge, they are on on their own port so to speak. I do note that wifi1 is trusted and part of the bridge subnet!
    You are missing the trusdted wifi1 ( wifi2g) on the bridge???
  3. If not using ipv6 then disable it in settings ( good done!) but also remove the junk associated ( address lists and fw rules) leaving only the following two rules
    add chain=input action=drop
    add chain=forward action=drop
    1. Simplify firewall rules
  4. Fix interface list, simplify and make efficient
    1. Wireguard, remove all the client settings, at least from the config we see, as it makes it very confusing, as the settings are for the router to mesh up with the client.
    2. Will assume your wireguard users are all trusted.
    3. Disabling icmp actually can interfere with traffic flow and any debugging required
    4. If forcing all users to pi, you create loopholes, aka allowing remote servers and allow all users to access services on router including DNS. Remove static setting, only allow pi-hole server to the internet for DNS via the router
    5. Also confusing as to why you are allowing the entire internet to use your pi-sever, DST NAT RULE REMOVED, and added rules to ensure all users go out pi-hole for DNS. Edit: Okay you were using it as some sort of VPN, still removed as you have wireguard to access router securely and thus can reach pi server securely.
    /firewall address-list { set static IPs on dhcp leases }
    add address=192.168.88.X/32 list=Authorized comment=adminPC on trusted network
    add address=192.168.88.Y/32 list=Authorized comment=adminwifi on trusted network
    add address=192.168.77.Z/32 list=Authorized comment="admin on wireguard"
    { ADD as required}
    add address=192.168.88.4/32 list=EXEMPT comment="pi-hole server"
    { ADD as required }
    /interface wifi
    .ft-over-ds=yes
    add name=TRUSTED
    add name=default-dhcp ranges=192.168.88.10-192.168.88.254 comment="bridge & wifi2g"
    add name=dhcp_pool1 ranges=192.168.99.2-192.168.99.254 comment="wifi2-g"
    add name=dhcp_pool2 ranges=192.168.98.2-192.168.98.254 comment="wifi5-g"
    add name=dhcp_pool3 ranges=192.168.97.2-192.168.97.254 comment="ether5"
    /disk settings
    add bridge=bridge interface=wifi2g
    set discover-interface-list=TRUSTED
    /ipv6 settings
    add interface=wifi2g-guest list=LAN
    add interface=wifi5g-guest list=LAN
    add interface=ether5 list=LAN
    add interface=bridge list=TRUSTED
    add interface=wg1 list=TRUSTED
    add allowed-address=192.168.77.3/32 interface=wg1 name=User1 public-key=
    "\[REDACTED\]"
    add allowed-address=192.168.77.4/32 interface=wg1 name=User2 public-key=
    "\[REDACTED\]"
    add allowed-address=192.168.77.5/32 interface=wg1 name=User3 public-key=
    "\[REDACTED\]"
    add allowed-address=192.168.77.6/32 interface=wg1 name=User4 public-key=
    "\[REDACTED\]"
    add allowed-address=192.168.77.7/32 interface=wg1 name=User5 public-key=
    "\[REDACTED\]"
    192.168.88.0
    192.168.77.0
    192.168.97.0
    /ip cloud
    /ip dhcp-client
    use-peer-ntp=no
    add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
    192.168.88.1
    add allow-remote-requets=yes set servers=1.1.1.1,8.8.8.8
    add action=accept chain=input connection-state=established,related,untracked
    add action=drop chain=input connection-state=invalid
    add action=accept chain=input dst-address=127.0.0.1 dst-address=172.0.0.1 interface=lo
    49876 protocol=udp
    add action=accept chain=input in-interface-list=TRUSTED src-address-list=Authorized \
    comment="admin access to router"
    add action=drop chain=input comment="drop all else"
    add action=fasttrack-connection chain=forward connection-state=established,related
    add action=accept chain=forward connection-state=established,related,untracked
    add action=accept chain=forward comment="Guests & WG to reach DNS"
    dst-address=192.168.88.4 dst-port=53 in-interface-list=LAN protocol=udp
    dst-address=192.168.88.4 dst-port=53 in-interface-list=LAN protocol=tcp
    add action=drop chain=forward comment="drop all else"
    add action=dst-nat chain=dstnat comment="redirect" dst-port=53 protocol=udp \
    in-interface-list=LAN src-address=list=!EXEMPT to-address=192.168.88.4
    add action=dst-nat chain=dstnat comment="redirect" dst-port=53 protocol=tcp \
    /system clock
    /system ntp client
    set enabled=yes
    /system ntp server
    set enabled=yes
    /tool mac-server
    set allowed-interface-list=TRUSTED
Thank you CGGXANNX! That solved my problem. Ended about 3 weeks of on-and-off struggling with it. Thank you also for the great explanation. That answers why it would seem to start working....I would go add another client and then find it would no longer work.
anav,
Thank you for looking at my config file.
1 &2. I believe I have 4 wireless interfaces defined. wifi2g, wifi5g, wifi2g-guest, and wifi5g-guest. wifi2g and wifi5g are on the bridge, but wifi2g-guest and wifi5g-guest are not. I don't believe I have overlapping subnets. 192.168.88.1/24 is assigned to bridge. 192.168.98.1/24 and 192.168.99.2/24 are assigned to each of the guest networks. 192.168.77.1/24 is used for wireguard connections. For wifi2g-guest and wifi5g-guest the client isolation is selected. Furthermore a firewall rules is set-up to prevent the GUEST interface list (both wifi-guest interfaces plus the ethernet5 port) from reaching the bridge.
  1. Removing the default IPv6 rules and leaving just the two makes sense. Will do.
  2. I see a few rules that were in place to allow my VPN running on the pi-hold server and some that I added while trying to troubleshoot. I can clean those up now. I'm not sure what you are looking for with the interface list.
  3. I'm confused what you are asking for here. I think the client settings are in there just for generating the QR codes used to create the tunnels on the clients.
  4. All wireguard users are trusted.
  5. ok.
  6. When you say "forcing all uses to pi" are you referring to forcing them to it for DNS or wireguard? Wireguard on the pi is gone now that it works in RouterOS. I need the pi-hole DNS server to be static, right? Otherwise everything breaks when its IP changes and the router dhcp server keeps handing out the old pi-hole DNS IP. I see the benefit to restricting outbound pi-hole internet traffic to only DNS, but I feel like that will cause me problems when I want to update the pi-hole. Let me know if I've created a vulnerability here somewhere that I don't understand.
  7. dstnat rule was there to permit the wireguard server to run on the pi-server. I will be removed now that I have it working within RouterOS. I plan to add rules only allowing DNS traffic once I make sure the pi-hole is reliably working.
I'm really confused looking through the config file you posted.
Once again, I really appreciate you looking though my config file. If the above explanations don't clear things up, let me know what I still need to look into.
If its working for you ignore my post!
