I have 3 120deg Sectors, an Omni-Directional antenna attached to 4 2.4ghz Mikrotik Groove APs I want all three to have same ssid, the sane mac address and work on the same channel frequency, does anyone know if would i encounter any problem. If yes, Which
Hint 1: do not use same mac-address, the other settings can be perfectly idenitcal except for IP address.
Hint 2: Do not use omnidirectional antennas for PtP or PtMP
Thanks a lot. Idont intend to use the same ip address but what is the effect of using the same mac address because i want to bind my clients to the mac address of my ap
You can bind the client for MORE THAN ONLY ONE MAC address!
If you use the same MAC address, the AP experiment some fake SWR, and on the clients disrupt the link with AP.
You can use the same MAC, if you are sure that the various AP absolutly do not receive other AP, also the clients.
