Wireless bridge and AP
Hi there!
This is my first entry in this forum, so i would like to say Hi to everyone and a big thanks to all the people who contribute here.
I recently bought two routerboards with 2 atheros minipci to both boards. I need to make the following configuration:
On routerboard1 the internet access is connect to lan via ether1, the wlan2 needs to be an AP and the wlan1 needs to be a station to establish a bridge from wlan1 on the second routerboard.
On the second routerboard, i want to make wlan1 to connect do the wlan1 on the routerboard1, and wlan2 needs to be an AP.
The problem is that when i take the ethernet cable from routerboard2, i don´t have routing to routerboard1.
I´ve been looking in the manual and in the forum for information and found the wds solution. After configuring wds, i still can´t make this work. Is there any tutorial or anybody can give me some help, pls?
scheme:
Internet ↔ ADSLRouter ↔ LAN ↔ Routerboard1 ether1 ↔ Routerboard1 wlan1 ↔ Routerboard2 wlan1 ↔ Routerboard2 wlan2 (AP)
Thanks for the help in advance,
Sandro Moreira
Check in the wiki, in there you will find some examples, also on the manual you have a couple of them too..
Regards
