When I try to connect to router the connection is successful. But several seconds later (when a little traffic passthrough) the connection is interupted and the device can’t see Mikrotik wireless network.
Wireless network device is VEN_10EC&DEV_8176. I have this problem also with old versions of RouterOS. Now I’m with v6.42.1 and the problem still present. I have and another devices with Intel and Atheros wireless adapters. They work just fine.
Here is my wireless configuration:
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce \
disabled=no frequency=auto mode=ap-bridge name=WLAN radio-name=MT ssid=\
MT-1 tx-power=26 tx-power-mode=all-rates-fixed wireless-protocol=802.11 \
wmm-support=enabled wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:1E:69:66 \
master-interface=WLAN multicast-buffering=disabled name=WLAN-2 ssid=\
MT-2 wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=password\
wpa2-pre-shared-key=password
And this is what I see in logs:
15:40:00 wireless,info D0:DF:9A:**:**:**@WLAN: disconnected, extensive data loss
15:40:01 wireless,debug WLAN: D0:DF:9A:**:**:** attempts to associate
15:40:01 wireless,debug WLAN: D0:DF:9A:**:**:** not in local ACL, by default accept
15:40:01 wireless,info D0:DF:9A:**:**:**@WLAN: connected, signal strength -44
When I try to connect to another wireless routers (like TP-Link, D-Link etc.) this wireless adapter work just fine.
