http://wiki.mikrotik.com/wiki/Wireless_Debug_Logs
It’s a work in progress, so suggestions and corrections are welcome.
Thats that should help us pin point most of our problems
Sidney
if you have any better explanation then you can add it there, but you hvae to be 100% sure that it is so.
Thanks Normis this is very helpful
Thank you!!
Finaly!!! Thanks!!!
Very Nice Thank You
Perfect!
I’ve been needing this for months!
Hi all.
I tried this functionallity and it works really well.
Is this then active by default?, I mean, every log is sent to memory after any event (that I choose).
Thanks.
I’m getting the MIC Failures on several of my clients. Interference isn’t an issue on one of them and their signal is -50, ccq is around 99.
Client is conecting to a RB112/CM9 using a laptop. Two other customers are using Tranzeo CPE 90’s.
They connect fine…then out of the blue I see those MIC failures.
Is there another explanation for the cause of these? Or is it just a compatibility issue between the cpe’s and ap and using TKIP.
Advice for “no beacons” if connecting to a Cisco AP, you need to increase the beacon rate on the Cisco radio config. Default is 100 and all my routerOS clients constantly dropped with this error, changing to 50 and it’s rock solid.
Congratulations! This information is very helpful.
kind regards/ldv
Thank you!
Talking about disconnection.
I suffered mainly two problems.
a) trees disturbing registration, so, moving antennas was the solution
b) excesive power on antennas, so, N/S ratio was too poor
I solved this problem, today not disconnection messages since 3 months ago!
Thanks.
thanks guy good work .. it help us !!
good working.
[admin@MikroTik] > /system logging
[admin@MikroTik] system logging> add topics=wireless,debug action=memory
hi, can I log to disk?
system logging> add topics=wireless,debug action=disk
Then ‘log print buffer=disk’.
Wow, thx so much for this…cheers…
This information avoided many questions!
