I’m wondering if the newish FT is not available for older wifi connections? Simple answer is it could be yes, or maybe I’ve got something not set right.
On the authtype column I see only a handful marked as ft-wpa3-psk. So is the FT only available on AX supported devices/connections?
Devices all have been updated to the latest:
The MT-MH-CORE is my Capsman managing all the wifi devices. Export of wifi configuration:
[admin@MT-MH-CORE] > /interface/wifi export
# 2025-03-06 10:53:41 by RouterOS 7.18.1
# software id = NU3E-E96P
# model = RB4011iGS+5HacQ2HnD
# serial number = A2820A208D61
/interface wifi datapath
add bridge=bridge disabled=no name=LocalWifi
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name="Hill Top Forest SecConf"
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name="Hill Top View Sec Conf"
/interface wifi configuration
add channel.reselect-interval=1h country=Canada disabled=no mode=ap name="Hill Top Forest CapConf" security="Hill Top Forest SecConf" security.ft=yes .ft-over-ds=yes ssid=\
"Hill Top Forest"
add channel.reselect-interval=1h disabled=no mode=ap name="Hill Top View Conf" security="Hill Top View Sec Conf" security.ft=yes .ft-over-ds=yes ssid="Hill Top View"
add channel.reselect-interval=1h .skip-dfs-channels=disabled country=Canada datapath=LocalWifi disabled=no mode=ap name="Hill Top Forest Basement CapConf" security=\
"Hill Top Forest SecConf" security.ft=yes .ft-over-ds=yes ssid="Hill Top Forest"
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment="Hill Top View Primary 2Ghz" disabled=no master-configuration="Hill Top View Conf" name-format=CAP-%I radio-mac=48:A9:8A:----- \
slave-configurations="Hill Top Forest CapConf" slave-name-format=CAP-%I
add action=create-dynamic-enabled comment="Hill Top View Primary 5Ghz" disabled=no master-configuration="Hill Top View Conf" name-format=CAP-%I radio-mac=48:A9:8A:----- \
add action=create-dynamic-enabled comment="Main House 5Ghz" disabled=no master-configuration="Hill Top Forest CapConf" name-format=CAP-%I radio-mac=48:A9:8A:-----
add action=create-dynamic-enabled comment="Main House 2Ghz" disabled=no master-configuration="Hill Top Forest CapConf" name-format=CAP-%I radio-mac=48:A9:8A:-----
add action=create-dynamic-enabled comment=Outdoors disabled=no master-configuration="Hill Top Forest CapConf" name-format=CAP-%I radio-mac=48:A9:8A:-----
add action=create-dynamic-enabled comment=Basement disabled=no master-configuration="Hill Top Forest Basement CapConf" name-format=CAP-%I radio-mac=74:4D:28:-----
