Wireless Interface enabled
Hi folks,
is it possible to add feature to set wireless interface enabled (in fresh installed MT) so that wireless inteface can be set by default to work in 2.4GHz-B ap-bridge mode ssid=default etc. Something like you guys did with ethernet, so it’s accessable via neighbour viewer.
Cheers…
You could do something like that when installing via netinstall - there you could run a custom script after installation…
Best regards,
Christian Meis
Yes, but why is the problem to be installed on rb532 or any other installation?
Please MT guys, respond to this thread.
Thx…
