Wireless interfaces missing after upgrading to V7.9
Router board - AX3
So uptill recently i’ve been happy with v7 even the Beta versions across multiple boards, I installed v7.9 on my Ax3 today and for some reason the wireless interfaces are not found.
I tried net installing v7.6 ( which was the factory release ) as well as 7.8.
All upgrade were done with the Arm64 packages.
I’m not sure what issue occured to make the Router believe it has no Wireless interfaces.
Anyone got any advice or fixes to this? Hate to have a Wifi6 router with no Wifi.. Kind of useless to have it then haha.
Let me know if you need any more info.
Okey so I fixed it becuase I was being a little bit old school - the AX3 requires the Wifiwave2 package
Congratulations to have it sorted out on your own :laughing:
And for future readers:
ONLY use automatic update process, it will take wifiwave2 package into account for upgrade.
If you do not know what you do when you go manual, then at least check what packages were installed before the upgrade. Those need to be taken into account as well.
