pfiff
August 27, 2026, 10:51pm
1
Hi there,
today I changed my LHG 5 with a LHG xl 5 ax antenna.
I used the LHG 5 to access the nearest HamNet Station 35km away.
After mounting the antenna to my roof pole, i notice that the wireless configuration is quiet different between this two models.
My old config on the LHG 5
/interface wireless
set [ find default-name=wlan1 ] country=no_country_set frequency=5740 frequency-mode=superchannel mode=station-bridge radio-name=DA6XX scan-list=5650-5850 ssid=DB0DAN-Benutzer-250Grad
My actuelly config <n the new LHG xl 5 ax
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-n .frequency=5740 .width=20mhz configuration.country=Superchannel .mode=station-bridge .ssid=DB0DAN-Benutzer-250Grad datapath.bridge=HAMNETBridge disabled=no
The device always shows me "no supported channels ".
I tried to change the chanel.band, configuration.country, and som other without success.
What am I doing wrong, or which setting is incorrect?
It always worked with the settings on the old device.
Thanks in advice.
David
Look in "Radios" and make sure that 5740 is shown as a supported frequency would be the first thing. Not sure what you get with the country undefined . . . Also, any particular reason you are forcing 5GHz-n?
pfiff
August 28, 2026, 5:51am
3
Figured out, that the AX Series is not capable to fit this requirements...
So the AX Series is not usable for HamNet as replacement for LHG5.
Is there any way to get the "channel information" from an LHG XL HP5 antenna?
Her the infos from my "old" LHG 5 (without ax)
Maybe someone has this antenna and can check to see if channel 5740 is available on it.
[admin@HAMNET Bridge SMALL] > interface/wireless/info/allowed-channels wl
an1
channels: 4920/20/a
4925/20/a
4930/20/a
4935/20/a
4940/20/a
4945/20/a
4950/20/a
4955/20/a
4960/20/a
4965/20/a
4970/20/a
4975/20/a
4980/20/a
4985/20/a
4990/20/a
4995/20/a
5000/20/a
5005/20/a
5010/20/a
5015/20/a
5020/20/a
5025/20/a
5030/20/a
5035/20/a
5040/20/a
5045/20/a
5050/20/a
5055/20/a
5060/20/a
5065/20/a
5070/20/a
5075/20/a
5080/20/a
5085/20/a
5090/20/a
5095/20/a
5100/20/a
5105/20/a
5110/20/a
5115/20/a
5120/20/a
5125/20/a
5130/20/a
5135/20/a
5140/20/a
5145/20/a
5150/20/a
5155/20/a
5160/20/a
5165/20/a
5170/20/a
5175/20/a
5180/20/a
5185/20/a
5190/20/a
5195/20/a
5200/20/a
5205/20/a
5210/20/a
5215/20/a
5220/20/a
5225/20/a
5230/20/a
5235/20/a
5240/20/a
5245/20/a
5250/20/a
5255/20/a
5260/20/a
5265/20/a
5270/20/a
5275/20/a
5280/20/a
5285/20/a
5290/20/a
5295/20/a
5300/20/a
5305/20/a
5310/20/a
5315/20/a
5320/20/a
5325/20/a
5330/20/a
5335/20/a
5340/20/a
5345/20/a
5350/20/a
5355/20/a
5360/20/a
5365/20/a
5370/20/a
5375/20/a
5380/20/a
5385/20/a
5390/20/a
5395/20/a
5400/20/a
5405/20/a
5410/20/a
5415/20/a
5420/20/a
5425/20/a
5430/20/a
5435/20/a
5440/20/a
5445/20/a
5450/20/a
5455/20/a
5460/20/a
5465/20/a
5470/20/a
5475/20/a
5480/20/a
5485/20/a
5490/20/a
5495/20/a
5500/20/a
5505/20/a
5510/20/a
5515/20/a
5520/20/a
5525/20/a
5530/20/a
5535/20/a
5540/20/a
5545/20/a
5550/20/a
5555/20/a
5560/20/a
5565/20/a
5570/20/a
5575/20/a
5580/20/a
5585/20/a
5590/20/a
5595/20/a
5600/20/a
5605/20/a
5610/20/a
5615/20/a
5620/20/a
5625/20/a
5630/20/a
5635/20/a
5640/20/a
5645/20/a
5650/20/a
5655/20/a
5660/20/a
5665/20/a
5670/20/a
5675/20/a
5680/20/a
5685/20/a
5690/20/a
5695/20/a
5700/20/a
5705/20/a
5710/20/a
5715/20/a
5720/20/a
5725/20/a
5730/20/a
5735/20/a
5740/20/a
5745/20/a
5750/20/a
5755/20/a
5760/20/a
5765/20/a
5770/20/a
5775/20/a
5780/20/a
5785/20/a
5790/20/a
5795/20/a
5800/20/a
5805/20/a
5810/20/a
5815/20/a
5820/20/a
5825/20/a
5830/20/a
5835/20/a
5840/20/a
5845/20/a
5850/20/a
5855/20/a
5860/20/a
5865/20/a
5870/20/a
5875/20/a
5880/20/a
5885/20/a
5890/20/a
5895/20/a
5900/20/a
5905/20/a
5910/20/a
5915/20/a
5920/20/a
5925/20/a
5930/20/a
5935/20/a
5940/20/a
5945/20/a
5950/20/a
5955/20/a
5960/20/a
5965/20/a
5970/20/a
5975/20/a
5980/20/a
5985/20/a
5990/20/a
5995/20/a
6000/20/a
6005/20/a
6010/20/a
6015/20/a
6020/20/a
6025/20/a
6030/20/a
6035/20/a
6040/20/a
6045/20/a
6050/20/a
6055/20/a
6060/20/a
6065/20/a
6070/20/a
6075/20/a
6080/20/a
6085/20/a
6090/20/a
6095/20/a
6100/20/a
David
The FCC doc on the product page gives the range, if that helps. (Not sure if you are US based, or ???) The international variant looks like it ought to cover it.
Looks like 5740 is just out of band . . .
Since it runs ROS, isn't the list available under "Radios" as I suggested prior?
/interface/wifi/radio/print detail
pfiff
August 28, 2026, 7:12am
5
Yes, you are Right, it is out of normal Bands.
In Germany the frequencies from 5650 MHz to 5850 MHz are reserved for Amateur Radio Zusage.
The HamNet is an Amateur Radio driven High Speed Wide area Network with WiFi technology. Mostly used with MikroTik or Ubiquiti Hardware.
It’s quite interesting, in my previous post you can see the capability of channels from my LHG 5.
There is a 5740 MHz Channel. An I have already used it.
But the FCC document is not showing this channel.
FCC LHG 5
So I had to ask if some has the LHG XL HP 5 and can read the information directly from the device, before I will buy the next device which doen’t work for this scenario…
Best Regards
David
Without further ado,
ham radio user or not, licensed or not,
the new MikroTik ax products can only be used on frequencies and channels supported by the chip
2412...2472 20MHz increase
5180 5200 5220 5240 5260 5280 5300 5320
5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720
5745 5765 5785 5805 5825 5845 5865 (5885 not on EU)
20 and 40 are available and 80 or 160 depends on hardware, but 5 and 10 are not possible for missing chip capabilites
If it's not listed, it's not supported.
pfiff
August 28, 2026, 9:24am
7
I'm well aware of that...
The question now is whether this is supported on the LHG HP5 devices...
But thanks for your comment.
pfiff:
LHG HP5
Is not ax (RBLHG-5HPnD), is RouterOS 6 compatible, so, still valid what I wrote before (no frequency restriction) , without speculation.
