Wireless network bridge with Groove A-52HPn
I have a (otherwise isolated) wired network using a Groove A-52HPn as Wireless AP to this network. Now I want to log in into this network using a notebook located about 50m away from the AP (outdoors). This basically works, but not reliable enough, the connection sometimes drops.
I guess the Groove A-52HPn AP provides a strong enough signal, just the notebooks WiFi card doesn’t have enough transmission power to reply. Therefore I want to set up a second Groove A-52HPn to connect to the first Groove and enable network access for the notebook via the Grooves ethernet port.
I already tried these sugestions here:
http://forum.mikrotik.com/t/groove-5hn-simple-ptp-bridge/51484/1
But using these configurations I’m not able to access the client Groove anymore and I don’t get network access via the ethernet port of the Groove - using either dynamic or static addresses on the notebook.
Can someone help me in setting up the second Groove? If possible if would be great if the configuration of the first groove doesn’t have to be changed. Any help is appreciated.
