Wireless network card "missing"
Hello!
Is it possible to use wireless network card (Asus PCE-AX3000) in a home built Mikrotik X86? I’ve tried, but can’t get it to work (no NIC when booting X86).
My Mikotik L5 X86 Package list: 7.13 routeros wireless container.
I should also mention that I am a new user of Mikrotik.
/R
No.
First problem is that Asus card uses Intel wlan module and that’s not supported in ROS. Only Atheros/Qualcomm WIFI drivers are in ROS.
And even if it was 802.11ax Qualcomm card, it would not work because Mikrotik simply doesn’t include any newer drivers in x86 ROS, best wireless that’s supported is 802.11n and that’s it.
But feel free to contact Mikrotik support to tell them you want to see new wifi drivers also for x86 ROS, if enough people ask for it maybe it will happen eventually…
