i have been using ubnt devices so far and i recently moved to mikrotik with the metal 52 ac. One thing i liked about ubnt was in its registration page u could see all the wifi clients that were registered along with their IP but in mikrotik u need to click on each in the list to see the IP, would it be possible to list the IP in the registration list itself?
You will find a list like that on the “quickset” page.
But be careful not to change anything on that page, it will ruin you config.
“quickset” is only for initial configuration!
You can see all connected clients on Wireless > Registration tab
Among other things you can have the ‘Last IP’ field shown (I think it’s shown by default) for each connected client.
No, it is not shown by default and (therefore?) it is not shown in Webfig (I think Webfig shows only columns that are shown by default in Winbox).
However, it is shown in the registration table that is shown on the quickset screen in Webfig.
thanks guys, i figured it out in winbox, had to add that column but there is no option to rearrange columns and in webgui there is no way to add columns
