no change since upgrading. went straight to 2.9.22 Just for kicks I did a strace while running it. Couldn’t get much out of gdb as it wasn’t compiled for debugging.
Script started on Fri 21 Apr 2006 04:25:41 PM EDT
^[]2;jp@mexican:~^G^[]1;mexican^Gjp@mexican:~> strace trafr capture.txt^M
execve("/usr/local/mis/bin/trafr", ["trafr", "capture.txt"], [/* 82 vars */]) = 0^M
[ Process PID=9655 runs in 32 bit mode. ]^M
uname({sys="Linux", node="mexican", ...}) = 0^M
brk(0) = 0x804a000^M
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)^M
open("/etc/ld.so.cache", O_RDONLY) = 3^M
fstat64(0x3, 0xffffc6f8) = 0^M
old_mmap(0x1ef9600000000, 8589934593, PROT_READ|PROT_WRITE, 0xf /* MAP_??? */|MAP_FIXED|MAP_ANONYMOUS|MAP_NORESERVE|MAP_POPULATE|MAP_NONBLOCK|MAP_GROW$
close(3) = 0^M
open("/lib/tls/libc.so.6", O_RDONLY) = 3^M
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0L\1\000"..., 512) = 512^M
fstat64(0x3, 0xffffc770) = 0^M
old_mmap(0x115c2c00000000, 8804682956805, PROT_READ|PROT_WRITE, MAP_FILE, 0, 0) = 0x5558c000^M
madvise(0x5558c000, 1137708, MADV_SEQUENTIAL|0x1) = 0^M
mprotect(0x5569b000, 27692, PROT_NONE) = 0^M
old_mmap(0x40005569c000, 8873402433539, PROT_READ|PROT_WRITE, MAP_FILE, 0, 0) = 0x5569c000^M
old_mmap(0x1c2c556a0000, 214748364803, PROT_READ|PROT_WRITE|PROT_EXEC|PROT_SEM|PROT_GROWSDOWN|PROT_GROWSUP|0xfcfffff0, MAP_FILE, 0, 0) = 0x556a0000^M
close(3) = 0^M
old_mmap(0x100000000000, 146028888067, PROT_READ|PROT_WRITE|PROT_EXEC|PROT_SEM|PROT_GROWSDOWN|PROT_GROWSUP|0xfcfffff0, 0xc /* MAP_??? */|MAP_ANONYMOUS$
mprotect(0x5569c000, 4096, PROT_READ) = 0^M
set_thread_area(0xffffcd88) = 0^M
munmap(0x5556d000, 126870) = 0^M
brk(0x806b000) = 0x806b000^M
open("capture.txt", O_RDWR|O_CREAT|O_TRUNC, 0666) = 3^M
socketcall(0x1, 0xffffcf90) = 4^M
socketcall(0x2, 0xffffcf90) = 0^M
write(3, "\324\303\262\241\2\0\4\0\0\0\0\0\0\0\0\0\0\20\0\0\1\0\0"..., 24) = 24^M
socketcall(0xc, 0xffffbf80^M
Right here I click start in wireless sniffer, then get the following as trafr quits.
) = 81^M
close(4) = 0^M
close(3) = 0^M
exit_group(0) = ?^M
^[]2;jp@mexican:~^G^[]1;mexican^Gjp@mexican:~> ^M
^[]2;jp@mexican:~^G^[]1;mexican^Gjp@mexican:~> exit^M
exit^M
Script done on Fri 21 Apr 2006 04:26:01 PM EDT
