Which is the best package combo for wifi on the RB4011iGS+5HacQ2HnD-IN for RouterOS 7.17.1?
- routeros + wireless
- routeros + wifi-qcom
- routeros + wifi-qcom-ac
While the documentation makes clear that my Audience unit needs “routeros + wifi-qcom-ac”, there is no direct specifcation for the RB4011…
Thanks!
yes it is:
The wifi-qcom-ac package Compatibility
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-Compatibility
RB4011iGS+5HacQ2HnD-IN (no support for the 2.4GHz interface),
rb4011 wifi version is a very rare device because uses a legacy wi-fi4 radio for 2.4ghz (almost the same radio of the ancient rb2011) combined with the best wi-fi 5 radio available on MikroTik, (same third radio of Audience) for 5ghz
with the spliting of packages between legacy wi-fi4 and newer wi-fi5 and wi-fi6 radios, rb4011 finds itself in the middle of a conundrum, where:
- if you want to use both radios you have to stay with legacy package
- if you want to take advantage of advanced features of 4x4:4 advanced wifi5 5ghz radio using the wifi-qcom package you have to lost the legacy 2ghz radio
My bad, especially since I remember seeing the note about wifi-qcom-ac not working with the 4011. So does that mean I should install wifi-qcom, or just leave wireless as is?
i added some facts to my previous post
