Try replacing windows with another OS
This is due specifically to Windows 8-11 (it is not yet clear why)
For example, Windows 7, Linux gives full throughput speed
This has something to do with windows delays and balancing.
The devices aren’t installed yet and I don’t have access at the moment (they’re in a box in a closet When installed they will be bridging a gap of only 60 feet between two buildings.
I’m curious why Windows would slow down the link when connected over the air but not with a physical cable. Does Windows detect something in latency and possibly window size and throttle it?
I guess I will wait until the devices are installed, then update ROS to the latest version and in the meantime read up on ROS (I have a good background in Debian).
