First forgive my English as this I am traducciendo with google.
My question is whether this team can mount a Wisp 100 clients and connect to the node with asymmetric 6Mb each customer in an area of 2km. I do not know if this is possible with a single node using Mikrotik equipment.
The idea is to reach that number of clients, if you have 100 customers 6Mbit have a few dedicated 120Mbit connection, and like other isp not guarantee the 6Mbit as if connected in parallel may not be, I doubt is if you can with a single node with the teams indicated that, if I can not give rise to 3Mbit, installing a single node is to know where I can return to the initial iversion before adding more nodes if needed.
u can get upto ~ 25Mbps TCP throghput on each sector panel, if ur cpe are connected to 54mbps, so if u are going to sell 6mbps each customer, I think will be possible
the ratio for reselling I guess u can go up to 1:6 ~ 1:8
I mean if u buy 1Mbps dedicated u can sell 6 or 8 times more 6mbps,8mbps
