WPA 2 Supplicant PEAP-TTLS
Hello
As I set RouterOS in mode client-station in a WiFi network with access restricted by user name and password without using certified under the 802.11i standard WPA with PEAP-TTLS. Have RouterOS WPA Supplicant with peap-ttls?
Thank you and sorry by my English.
It is not possible to run PEAP-TTLS on RouterOS client [mode=station].
MikroTik AP can be used as relay between client — MikroTik AP — RADIUS for PEAP-TTLS, when client [Windows any other OS] is able to work with PEA-TTLS.
It would be a great idea that future versions will be added the PEAP-TTLS supplicant, thanks for your reply.
I have a Mikrotik RB411, and in my situation I will need PEAP to connect the CPE as client of a campus network.
I have been testing the menus and options of the 5.1 and I have been disappointed with the lack of a Supplicant in this version: still not possible.
Could anybody confirm that the supplicant is not yet available? I will install a OpenWrt in the Mikrotik to connect my CPE…
