WPA / WPA2 4way handshake timeout error…
This is what I see no matter how I setup WPA / WPA2…
The client is an Intel 2200BG card.
AP = 532
ROS = 2.9.40
Card = R52H
I have tried:
for key:
10 char: Text on AP and client
HEX on AP and Client
Hex on AP and Text on client
Text on AP and Hex on client
13 char: Text on AP and client
16 char: Text on AP and client
TKIP on AP/client.
AES on AP and client.
I have tried all settings for both WPA and WPA2.
(All are personal WPA)..
Any ideas??
janisk
2
in wireless you have to set up mode=dynamic and then use PSK-key for WPA/WPA2
“Ack Timeout” is at default. (tried indoor and dynamic)
I am using PSK..
NOTE: the AP is only about 10 feet away from the client (for init testing)…
Am I looking at the correct “dynamic” setting ??
I have sent a SupOut to support..
Subject WPA/2200BG.
Craig
Got it !!
It was a driver issue on the client..
Windows and toshiba updates were not showing any new files, and the driver “supported” WPA/2 but…
I went searching and found a newer version on the driver / manager (PROSet) and Bingo…
It is listed as ver 10.X (the driver will show 9.X, but the PROSet will show 10.X)
I will list exact version data later..
Needless to say, KEEP your software up to date… and dont rely on the vendor to tell you it is out there..
Craig
