I have created tmpfs disk for log storage but every time OS writes to log on tmpfs I`ve noticed increasing in "Sector Writes Since Reboot" and "Total Sector Writes" counters. Is it normal bahavior? I am worry of wearing 16MB internal OS flash.
Normal, yes, I would say.
Unless you use ROSE package (which can create RAM disk), storage is flash.
But with 16Mb main storage, I don't think it would be a good idea to add that package only for that purpose.
You can also use that USB port on your device to add storage ?
Indeed, I overlooked you can also use normal DISK functions to make it.
Then it should only be some pointers/statistics being written to flash.
Normal OS stuff.
On 7.21.5 (long-term) seems to be OK. After 4 hours of working I see only few written sectors manily because configuration changes. Yesterday after 2 hours was 10k+ writes.
To claryfy (maybe its important) this issue comes from loging webproxy app:
