Port 88 (UDP)
Port 3074 (UDP and TCP) (I assigned this port manually)
Port 53 (UDP and TCP)
Port 80 (TCP)
Port 500 (UDP)
Port 3544 (UDP)
Port 4500 (UDP)
Ideally, UnPN should be activated
To simplify things and make sure that my XBOX is not changing its IP address dynamically, I manually assigned to it through the advance setting in the console, the following:
IPv4
IP address: 192.168.88.246
Subnet mask: 255.255.255.0
Gateway: 192.168.88.1
These ports should be open from within to the Internet, these shoud not be port forwarded (as I assume you did).
UPnP is evil…please don’t use it…ever!
Though…some games do require port forwarded to the console (which sucks in my opinion).
What game(s) are giving you problems?
The question is, how do I do that? What I should do to open these ports?
I just moved to this flat. I found the connection here. From what I know, no, I am not running an L2TP VPN server.
Ok so you can forward and open these port or use UPnP. Now I’m no fan of UPnP but in this case it might be the best option for you.
Can you do a export hide-sensitive and paste the output. Could be UPnP that needs tweaking. If not we can help with NAT rules as we can se interface names and so on that is needed.
You can paste the output here if you want to should be safe. Just remove the public IP if you have on in the output.
Did not know that PM was enabled but that is an option as well
So the NAT rules should be like this:
add action=dst-nat chain=dstnat dst-port=3074 in-interface=ether1 protocol=tcp to-addresses=192.168.88.246
add action=dst-nat chain=dstnat dst-port=88,500,3074,3544,4500,5730-5731,5739 in-interface=ether1 protocol=udp to-addresses=192.168.88.246
This will take all inbound traffic to the router on these ports and dest-nat (port forward) to IP 192.168.88.246 which I assume is the Xbox
So now comes the point I’m unsure of but I think you need firewall rules as well. I think you need rules in both input and forward. Now I’m not sure about this but here are the rules:
add action=accept chain=input dst-port=3074 in-interface=ether1 protocol=tcp
add action=accept chain=input dst-port=88,500,3074,3544,4500,5730-5731,5739 in-interface=ether1 protocol=udp
add action=accept chain=forward dst-port=3074 in-interface=ether1 protocol=tcp
add action=accept chain=forward dst-port=88,500,3074,3544,4500,5730-5731,5739 in-interface=ether1 protocol=udp
Note that these rules has to be above drop rules so you will have to move them after them being added.
Also note that if you want to use any of these ports in the future this NAT rule will break that. For example UDP 500 is used for some VPN tunnel and so on.
Regarding your UPnP rules look good but when it comes to Xbox and Mikrotik my experience is that sometimes it works and sometimes it does not
And last I did all this during a online meeting so please read trough as I might have made mistakes
Thank you a lot!
Could you please clarify what you mean by “ote that these rules has to be above drop rules so you will have to move them after them being added.”?
If you run the code in CLI the rules will be placed last and below the drop rules so they will not work. You have to move them so they are above the drop rules which are last.
Unfortunately, nothing has changed at all. Like we did nothing.
I received an email a few days ago from MikroTik support. The only one I have received so far saying that:
/ip firewall nat add chain=dstnat dst-port=1234 action=dst-nat protocol=tcp to-address=192.168.1.1 to-port=1234
this will “open” the port 1234 for the internal IP 192.168.1.1
The question is whether I should replace 192.168.1.1 with my XBOX ip…
Not a gamer myself, but I reckon the description of the ports to opened as listed on that URL is confusing, they are not explaining which direction these ports needs to be opened, and I suspect that 99% of these ports listed are required for outgoing should you have configured firewall as a “statefull” firewall, which default config does.
I just tested with my son’s XboxOne, tested NAT and it said moderate, then only enabled DST NAT to the XboxOne IP for both protocols TCP and UDP destination port 3074, now NAT says Open.
Might need to open additional ports for Gaming, but XBox itself reports OPEN NAT now
I said this in DM but I noticed that UPnP is disabled. So test to enable it would be a good start.
Also agreed ports are confusing as hell but hopefully UPnP would solve this.
Unfortunately, due to the fact that I am only renting this flat short term, I cannot upgrade the internet contract in order to resolve the issue
Instead, I just got an ExpressVPN account.
Any ideas if that could help? Also, any help on how I can set this up to my router?
