You are welcome:
# RouterOS 6.48.1
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-RUCKUS
set [ find default-name=ether3 ] name=ether3-SWITCH
set [ find default-name=ether6 ] name=ether6-ADMIN
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan20 vlan-id=20
add name=WAN
add name=LAN
add name=ADMIN
add name=VLAN
add name=dhcp_LAN ranges=192.168.2.100-192.168.2.160
add name=dhcp-vpn ranges=192.168.89.100-192.168.89.140
add name=dhcp_IOT ranges=172.16.1.20-172.16.1.100
add address-pool=dhcp_LAN disabled=no interface=vlan10 name=dhcp-LAN
add address-pool=dhcp_IOT disabled=no interface=vlan20 name=dhcp-IOT
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=dhcp-vpn
/caps-man manager
set ca-certificate=auto certificate=auto upgrade-policy=suggest-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no
add comment=defconf disabled=yes interface=ether1-WAN
add bridge=bridge1 frame-types=admit-only-vlan-tagged ingress-filtering=yes \
interface=ether2-RUCKUS
interface=ether3-SWITCH
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=yes interface=ether4 pvid=10
ingress-filtering=yes interface=ether5 pvid=10
set tcp-established-timeout=5h
set discover-interface-list=ADMIN
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether2-RUCKUS,ether3-SWITCH untagged=ether4 \
vlan-ids=10
add bridge=bridge1 tagged=bridge1,ether2-RUCKUS vlan-ids=20
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=ether1-WAN list=WAN
add interface=ether6-ADMIN list=ADMIN
add interface=ether6-ADMIN list=LAN
add interface=vlan10 list=ADMIN
add interface=vlan20 list=VLAN
add interface=vlan10 list=VLAN
/interface wireless cap
set caps-man-addresses=127.0.0.1 certificate=request interfaces=wlan1
add address=192.168.2.1/24 interface=vlan10 network=192.168.2.0
add address=172.16.1.1/24 interface=vlan20 network=172.16.1.0
add address=192.168.1.2/24 interface=ether1-WAN network=192.168.1.0
add address=10.10.0.1/24 interface=ether6-ADMIN network=10.10.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether1-WAN
add address=172.16.1.0/24 dns-server=208.67.222.222,208.67.220.220 gateway=\
172.16.1.1 netmask=24
add address=192.168.2.0/24 dns-server=208.67.222.222,208.67.220.220 gateway=\
192.168.2.1 netmask=24
set cache-size=4096KiB servers=208.67.222.222,208.67.220.220,8.8.8.8
/ip firewall address-list
add address=172.16.1.0/24 list=IOT
add address=192.168.2.0/24 list=LAN
add address=192.168.2.11 comment="IOT allowed" list=IOT-allowed
add address=10.10.0.0/24 list=Admin
add action=drop chain=input comment="Block from blocklist" log-prefix=\
"blk from blocklist" src-address-list=blacklist
"Allow input on ether-6 for Administration" in-interface=ether6-ADMIN \
src-address-list=Admin
add action=accept chain=input comment="Allow established, related" \
add action=accept chain=input comment="Allow L2TP VPN (ipsec-esp)" protocol=\
ipsec-esp
add action=accept chain=input comment="Allow L2TP VPN (1701, 4500, 500 /udp)" \
dst-port=1701,4500,500 protocol=udp
add action=drop chain=input comment="Deny All input from WAN" \
in-interface-list=!LAN log-prefix="drop input !LAN"
add action=drop chain=forward comment="Block from blocklist" log=yes \
log-prefix="blk to blocklist" src-address-list=blacklist
"Deny new,invalid,untracked connections" connection-state=\
invalid,new,untracked in-interface=ether1-WAN
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment="IOT->LAN allowed IPs" \
dst-address-list=IOT-allowed src-address-list=IOT
add action=drop chain=forward comment="Block IOT ->LAN su VLAN" \
in-interface=vlan20 log=yes log-prefix="Drop VLAN20 to VLAN10" \
out-interface=vlan10
"Allow established,related connections" connection-state=\
established,related
add action=drop chain=forward comment="Deny All forward from WAN" \
add action=masquerade chain=srcnat out-interface=ether1-WAN
add action=masquerade chain=srcnat comment="Masquerade vpn traffic" \
src-address=192.168.89.0/24
add distance=1 gateway=192.168.1.254
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=222
set api address=192.168.2.11/32
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote strong-crypto=yes
/lcd
set default-screen=stats-all enabled=no
/lcd interface pages
set 0 interfaces=wlan1
/ppp secret
add name=luc
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=Router
/system logging
add disabled=yes prefix="IPSECDBG===>" topics=ipsec
/system ntp client
set enabled=yes primary-ntp=193.204.114.232 secondary-ntp=193.204.114.233
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=ADMIN
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
