Zabbix SNMP high polling problem
Hi, I have a mikrotik CCR1072-1G-8S+ with firmware 6.48.6 LTS on which I have hundreds of virtual interfaces (c-vlan , s-vlan).
I have some problem with snmp monitoring done by Zabbix 6.0 LTS.
occasionally the items stop polling, the monitored interfaces (about 800) have a polling time of 40 seconds. do you know of any mikrotik or Zabbix bugs?
zabbix configuration file:
StartPollers=100
PS:
all snmp requests from the whole network (about 2000 hosts) transit from this router.
Translated with www.DeepL.com/Translator (free version)
hello,
this one is a classic snmp problem.
and generally, any polled devices - in their normal operating condition - will have no problem replying snmp traps.
so the question mark most of the time lies on the snmp server itself.
  • check its cpu, ram and disk space (tune your memory cache).
  • provide enough bandwidth so that snmp trap won’t timed out.
  • 40 second is too short for polling, it will saturated your network bandwidth, and could lead in timed out.
  • don’t forget to check its log.
btw, are those 2000 devies with 800 interfaces each?
1’st , just to clarify - The issue you are encountering is not a problem with any Mikrotik devices .
I use a combination of Zabbix and LibreNMS and WhatsUp-Gold NMS ( Network Monitoring System’s ) and Cacti to monitor thousands of devices in all of the networks I manage. — Each NMS has it’s strengths and weakneses.
Zabbix ; is great for performing ICMP pings to devices and the ability to draw network maps ( of your networks ) is great. I encounter similar problems with Zabbix ( like what you are stating in this Mikrotik forum post ) when I start adding hundreds to thousands of SNMP checks to my devices ( including hundreds of Mikrotik devices ). IMO , Zabbix main weakness is the VPS ( values process per second ) can jump to 400+ VPS , which then makes Zabbix almost unusable because the web interface becomes almost non-responsive. Soooo, I reconfigured my Zabbix NMS to only perform ICMP Ping tests and I also use Zabbix maps for my entire network. — You may want to look in the Zabbix forums to find possible answers to your issues.
LibreNMS ; is great for SNMP - however the ability to draw network maps requires a 3’rd party plug-in ( IMO ; it sucks ).
I would like to suggest that you take a look at the Mikrotik Dude NMS system. It’s works OK for most IPv4 networks ( I don’t know if it supports IPv6 yet ).
So , the issue you are encountering is not Mikrotik related - your issue is your Zabbix NMS system and how you have it configured.
North Idaho Tom Jones
