DanielJB
Wireless beacon interval and DTIM missing
Wed Dec 28, 2016 10:57 am
I think it is reasonable to be able to tune the wireless beacon interval and DTIM.
I my case, a 200ms beacon interval and DTIM count of 1 would be more optimal than the defaults.
Anyone else missing this feature with other basic APs feature?
bmatic
Re: Wireless beacon interval and DTIM missing
Fri Jan 20, 2017 7:53 am
Yes, I also think that in professional AP's like MikoTik should be option for changing beacon interval and DTIM count.
Best luck with that.
bajodel
Long time Member
Long time Member
Tue Feb 28, 2017 11:01 pm
yep +1
esaym
Wed Mar 01, 2017 7:10 am
yep +1
+1
sb56637
Tue Mar 21, 2017 4:53 pm
I would also find this option useful. It has been available with the TomatoUSB firmware for approximately forever. :)
jo2jo
Mon Apr 10, 2017 8:15 am
+1 -- really need this feature to cut down on wasted frequency when deploying alot of APs density for coverage reasons
see this amazing info on how important this feature is (and that we def. should have it in a product as advanced at ROS)
http://www.revolutionwifi.net/revolutio ... lator.html
Sebi
Tue Apr 10, 2018 10:34 am
+1 we really need this feature
Davis
Sun Apr 15, 2018 7:52 pm
+1 Beacon interval and DTIM would be useful (especially in crowded areas)
gparent
Sat Jun 02, 2018 12:08 am
Pretty much registered because I'm looking for this also.
Zwodka
Tue Jun 05, 2018 1:14 am
+1 useful feature
dave864
Sun Jul 01, 2018 4:05 pm
+1
I have an iot gadget that needs DTIM or beacons to be spaced out. DTIM works brill at 7. My choice was that or change beacons to 200 / 250 ms
hugo11
Thu Jul 05, 2018 9:48 am
+1
had this set on my old Asus with ddwrt. iPhones had stable connection and I could detect them on NW reliably. with mikrotik I see now a lot of drops.
franaz
Sat Nov 03, 2018 2:27 am
I just registered to underline that we need that feature... it would be a very bad joke if not implemented in one of the near updates!
Stefan
oscar555
Sat Dec 15, 2018 4:52 pm
For me, it's very important to be able to change the beacon interval. I'm used to do it with all my OpenWRT routers. If Mikrotik has this option, I will change all my OpenWRT routers to Mikrotik ones :)
anuser
Long time Member
Long time Member
Sun Dec 16, 2018 10:46 pm
Has anyone ever created a ticket at MikroTik support with an official feature request for this one?
Sebi
Thu Apr 11, 2019 9:50 am
muetzekoeln
Thu Apr 11, 2019 12:48 pm
bnw
Wed Jul 10, 2019 12:31 am
I opened ticket #2019030822005631 in March 2019, support told they would pass the request to developers and find out if it is possible to implement on their hardware.
suszi
Sat Nov 23, 2019 6:56 am
+1 also
marrold
Tue Dec 03, 2019 9:38 pm
I could do with this - I need to adjust DTIM
bnw
Tue Mar 10, 2020 4:35 pm
SUP-10676 in new ticketing system.
yosu
Fri Oct 02, 2020 11:16 am
+1
I remember seeing this option a few years ago, but now it is removed.
pe1chl
Tue Dec 28, 2021 11:04 am
I think it would be useful to have this, or to have a small random offset to the default beacon interval.
I observe "waves" of "lost connection, no beacons received" on point-to-point links running with a CCQ around 80%.
I checked, and e.g. on a point-to-point link where 4 SSIDs are sent by the AP (3 virtual interfaces), I can see over time that 2 or 3 are received OK, one or two others disappear.
I guess there is some local indoor AP that beacons exactly at the same time as one of the local APs is transmitting, and they go under in the interference.
This continues maybe half an hour, and after that the connection is OK again. Probably the moment of transmission of the beacons has drifted by that time.
When we could set the beacon transmission time e.g. to 210ms instead of 200ms, and that local AP uses 200ms, this kind of problem could be resolved.
lubomirs
Thu Sep 14, 2023 3:54 pm
On many forums it is recommended to change the DTIM regarding the iPhone, but how? The iPhone 6 kept disconnecting and connecting, resolved on the iphone forums. . . . . but mikrotik has it in the ass.
The last plastic router also has this setting. . . .
holvoetn
Thu Sep 14, 2023 6:32 pm
This ?
I don't have iPhones at home, so I don't use it.
Be advised that's on a wifiwave2 device, though.
