emils
Forum Veteran
Forum Veteran
v7.1beta2 [development] is released!
Fri Aug 21, 2020 2:00 pm
RouterOS version 7.1beta2 has been released in public "development" channel!
What's new in 7.1beta2 (2020-Aug-21 12:29):
!) added "bgp-network" output filter flag;
!) added bonding interface support for Layer3 hardware offloading;
!) added IPv6 nexthop support for IPv4 routes;
!) added Layer3 hardware offloading support for CRS309-1G-8S+IN, CRS312-4C+8XG-RM and CRS326-24S+2Q+RM;
!) added WireGuard support;
*) disk - improved external disk read/write speeds;
*) ospf - fixed point to point routes becoming inactive;
*) route - fixed source address selection of outgoing packets;
*) other minor fixes and improvements;
All released RouterOS v7 changelogs are available here:
https://mikrotik.com/download/changelog ... lease-tree
How to report RouterOS v7 bugs:
viewtopic.php?f=1&t=152006
Kindis
Re: v7.1beta2 [development] is released!
Fri Aug 21, 2020 2:07 pm
This level 3 offloading looks very interesting. Do we have any numbers to show what it can mean as this has the potential to put emphasis on the R in CRS :-)
santyx32
Fri Aug 21, 2020 2:15 pm
Finally Wireguard
mafiosa
Fri Aug 21, 2020 2:36 pm
!) added Layer3 hardware offloading support for CRS309-1G-8S+IN, CRS312-4C+8XG-RM, CRS326-24S+2Q+RM and CRS354-48G-4S+2Q+RM;
Good to see ospf issue to be resolved. Also wireguard is a much awaited feature. Thanks!
leoktv
Trainer
Trainer
Fri Aug 21, 2020 2:40 pm
Any update in the v7 Routing Protocol Status?
Paternot
Fri Aug 21, 2020 2:49 pm
It does routing at wirespeed, in all ports. There are several constraints, and a limit of 4096 connections, if I'm not wrong. But in some use cases it will be a killing feature.
pe1chl
Fri Aug 21, 2020 2:55 pm
Observations (not really new for this build but maybe off the radar):
- when a static route is disabled, it disappears from the listing entirely, as if it has been deleted. when the window is closed/reopened, it appears again in greyed-out status.
- the BGP functionality still exists only in CLI and not in winbox. I would have hoped (or maybe this is the time to do that!) that all GUI info is derived from a common set of tables that is shared by all the user interfaces, so the work does not have to be done 3 times...
- when I close the Log window and re-open it, winbox completely hangs.
null31
Fri Aug 21, 2020 3:07 pm
WireGuard implementation was done like MikroTik did to OpenVPN or kept as is in Linux 5.6?
Thank you.
mrshark
Fri Aug 21, 2020 3:09 pm
any hint on how to flash this on a HAP MINI? On previous beta, it said internal storage is not enough to upgrade... it's a brand new model, factory reset... maybe because of beta and so build not optimized yet? Will it ever be a version for low storage devices?
thanks in advance
null31
Fri Aug 21, 2020 3:13 pm
thanks in advance
Use NetInstall to flash hAP Mini.
ludvik
Fri Aug 21, 2020 3:14 pm
winbox 3.24 64bit on win7, rb450gx4. Open interfaces, add Virtual ethernet. Winbox closed.
Quasar
Fri Aug 21, 2020 3:26 pm
Thank you.
It's Wireguard v1.0.0 proper (as shipped with v5.6).
Note for whoever wants to give it a spin: you need to use the cli to set the peer endpoint - Winbox doesn't allow you to set the port (it will default to 0).
Cha0s
Fri Aug 21, 2020 3:42 pm
Gave it a try on a hEX (RB750Gr3) and it worked out of the box!
The performance was capped at around 100mbit though. Maybe the hEX is not powerful enough.
More tests are warranted :)
mozerd
Forum Veteran
Forum Veteran
Fri Aug 21, 2020 3:43 pm
@Paternot
I 4 1 do NOT believe that It will do routing at wire-speed ... why I do not believe that .... because for L3 wire-speed requires an ASIC and non of the hardware specs I see have that L3 ASIC in the gear. Yes there will be an improvement in performance but nowhere near wire-speed.
macgaiver
Fri Aug 21, 2020 3:54 pm
@Paternot
https://i.mt.lv/cdn/product_files/CRS32 ... 200149.png
Are you sure that mention switchip doesn't have that feature?
msatter
Fri Aug 21, 2020 3:55 pm
Just tried this version and had to go back to 6.4x.
  • Bug [SUP-15464] which is partly fixed in 6.4x is still present in 7.1x (retain correct MTU PPPoE through a SFP on a 4011) restarting the SFP does not help.
  • Changing the MTU manually on a interface crashes the router (tested it on a 4011 and 750-Gr2) remark, MTU set in the configuration by a 6.4x seems to be honored
  • In routing I noticed something different on the route for the gateway PPPoE connection, the first was 0.0.0.0/0 but that a label DAv instead of DAS (v from VPN) and I have IKEv2 defined but not all traffic has to go through a tunnel. I assume this "v" indicates that the IKEv2 tunnels are terminated on the PPPoE.
I did upgrade my firmware to 7.1x but to no avail. And I first downgraded to 6.47.2 before upgrading to the 7.1beta2
mbovenka
Fri Aug 21, 2020 4:09 pm
What do you think the, let's say 98DX8208 chip in the CRS309 is? It's a switching ASIC that has lots of functionality built in, L3 forwarding among them. MT simply didn't implement it up to now.
DarkNate
Fri Aug 21, 2020 4:17 pm
WireGuard Support! Finally! About time!
honzam
Fri Aug 21, 2020 4:32 pm
Any update in wireless?
mozerd
Forum Veteran
Forum Veteran
Fri Aug 21, 2020 4:33 pm
@macgaiver
I am not familiar with that specific switch chip so I am in part writing out of ignorance of that specific chip.
I am familiar with how CISCO does in on their MLS devices. Typically for wire-speed routing in the Cisco Switch world Cisco requires three entities to implement multilayer switching: the switching engine (SE), the route processor (RP), and the MLS protocol. The SE performs the switching function, the RP performs the routing function, and the MLS protocol provides for communication between these two devices. This aside, there is one very simple concept that makes it all possible: the flow. A flow can be defined as a stream of packets from the same source to the same destination using the same application. As an example, a flow could be an HTTP session between a source browser and a target server. In a Cisco MLS network, the initial packet in a session is routed via the RP, but all subsequent packets in that particular session are switched by the SE. The SE maintains a cache about these flows and can determine whether or not a given packet is part of an established session. If so, the SE rewrites the pertinent packet info as if it had been processed by the router and then switches the packet. This process is commonly referred to as “route once, switch many.” It occurs at switch speed, not at the slower router speed.
So in terms of MikroTik and RouterOS I do not see ANY functionality that mimics or deals with wire-speed Routing at the switch level.
reddin
Fri Aug 21, 2020 4:38 pm
Hello!
Just upgraded to v7.1b2 and spotted a few issues:
First and most important is routing marks don't work
The second one is about wireguard. Why I can't specify the port number for peer? Is it intended or a bug as well?
mrshark
Fri Aug 21, 2020 4:55 pm
thanks in advance
not able to put device in netboot mode in any way tried... short, direct cable from pc eth to eth2, i add this command:
/system routerboard settings set boot-device=try-ethernet-once-then-nand
then unplug power and eth, move eth to eth1 port, replug power, it never appears in netinstall...
left eth cable in eth1, unplug power, keep pressed reset for more than 2 minutes, nothing, never appeared in netinstall...
again, unplugged power, keep pressed reset, replug power, left reset after lights went off, nothing again...
windows firewall disabled, av disabled, ip pc 192.168.88.2/24-->.1, ip netboot 192.168.88.3...
mrshark
Fri Aug 21, 2020 4:57 pm
in comments above is said to use cli for now, probably winbox is not yet updated to include gui for wireguard
cxcool
Fri Aug 21, 2020 5:03 pm
Wireguard endpoint port need to be fix in winbox .
there is no way to enter IP:port in winbox
CLI OK
reddin
Fri Aug 21, 2020 5:04 pm
Yeah, it works via cli, thanks.
Cha0s
Fri Aug 21, 2020 5:14 pm
L3 offloading happens on the switch chip.
That's why it's called "L3 offloading". They offload the routing functionality from the CPU, to the switch chip, thus achieving wirespeed.
The switch chips used in those RB models (which are ASICs basically) do support L3 routing at wirespeed as per Marvell's datasheet.
The hardware support was already there, but MikroTik just started supporting it on ROS.
null31
@mrshark
You need to use a switch between pc and router. Direct connection is prone to fail, since you have a change on link state.
So, the netinstall "become" slow to detect the router.
Also, typically ether1 is used by netboot, except if is identified another port for that role.
mozerd
Forum Veteran
Forum Veteran
Fri Aug 21, 2020 5:23 pm
@Cha0s
Do you have a link to the Marvell's datasheet.for the Chjp referred to please?
Cha0s
Fri Aug 21, 2020 5:27 pm
I don't have it at hand, but I remember someone had posted it in the forum a while ago.
mozerd
Forum Veteran
Forum Veteran
Fri Aug 21, 2020 5:44 pm
OK thanks .... I found the following that looks very interesting and exciting for MikroTik users :-)
Marvell PRESTERA 98DX83xx Family
In reading the specs I do not see L3 wire-speed benefits.
Paternot
Fri Aug 21, 2020 6:02 pm
@Paternot
Well, the switch chipset has the circuitry. If they will implement it all they way is another question. But the hardware is already there.
pe1chl
Fri Aug 21, 2020 6:18 pm
There is no need to question the possibility of doing L3 routing on a switch, there have been competing switches from other companies that do wirespeed routing for a long time.
It must be like 20 years ago when I got my first 3com L3 switch and was amazed at how it could route so fast, for that price, when compared to Cisco routers of the day (3640 etc).
And indeed, it normally works as described: the first packet for a src/dst ip pair is handled by the CPU, then an item is programmed in the switch that forwards the remainder of the traffic.
Just like it is done for L2 switching (where a MAC table is kept in the switch hardware to know where to forward the traffic.
poisons
Fri Aug 21, 2020 6:40 pm
Wireguard support cool thing, but where is an instruction how to use it?
mistry7
Fri Aug 21, 2020 6:41 pm
Still waiting for something?
eworm
Fri Aug 21, 2020 6:50 pm
Configuring wireguard is pretty straight forward. Just look at the options available.
ksteink
Fri Aug 21, 2020 7:02 pm
Very nice features!!! love them so far and keep going!!
Any time frame to move off development phase and make it ready for production / stable?
mducharme
Trainer
Trainer
Fri Aug 21, 2020 7:34 pm
IPv6 BGP is working now! Thanks MikroTik!
mducharme
Trainer
Trainer
Fri Aug 21, 2020 7:53 pm
They still have to implement MPLS - I think that is the one major feature still missing from the current beta. Otherwise, there are probably many small fixes needed here and there.
Jotne
Fri Aug 21, 2020 8:22 pm
Do a search on this forum and you find many answer. Netinstall is one way. You can also downgrade to an older version that is much smaller, like some 6.44.x version, then upgrade to latest.
IPAsupport
Fri Aug 21, 2020 8:28 pm
Totally agree! I will love to see MPLS implemented
metricmoose
Fri Aug 21, 2020 9:08 pm
Wireguard is working well, except for that minor winbox issue with the endpoint port. With how easy it was to setup, I totally get the Wireguard hype now. IPSEC has a frustrating amount of knobs to turn.
Between a couple hAP ac² routers, I was getting about 280 Mbps UDP. When I changed out one of those hAP ac² routers with an older RB951G-2HnD, I was getting about 75 Mbps. That's probably better than I'd get out of IPSEC on the same device!
rooted
Fri Aug 21, 2020 9:35 pm
Wireguard is included in the beta, that's awesome. Thank you to all the devs for the addition, looking forward to setting it up then I get home.
mducharme
Trainer
Trainer
Fri Aug 21, 2020 10:30 pm
P.S. One thing I would really like to see in the new RouterOS v7 MPLS implementation is MPLS mangle for QoS purposes - specifically, "mark packet" and "set priority" actions for MPLS. Right now to do MPLS QoS on RouterOS we have to create a bunch of extra bridges and use bridge filters for QoS. A simple MPLS mangle table would allow us to get rid of those extra bridges.
Also, please add "set priority" to the IPv6 Mangle. We have to use bridge filters as a workaround for that too at the moment.
IPAsupport
Fri Aug 21, 2020 11:32 pm
Here is the preliminary testing we have done on this version with two CHRs on ProxMox that are each on a different VLAN and the CRS317 routes between the VLANs
This is very quick UDP test - we will do more work using TCP with traffic generator and iperf3
4 to 5 Gbps with UDP and 0 to 3% CPU load
anuser
Long time Member
Long time Member
Fri Aug 21, 2020 11:39 pm
We are waiting for the usual stuff:
1. airtime fairness improvvements (http://blog.cerowrt.org/post/real_results/, https://forum.openwrt.org/t/aql-and-the ... vely/59002)
2. MU-MIMO
3. 802.11 k/v/r
anuser
Long time Member
Long time Member
Fri Aug 21, 2020 11:43 pm
3Com 4800G switch from 2009 is my bread and butter switch: IS-IS, BGP, OSPF, VRF; PIM-SSM all running with full IPv4 and IPv6 support.
santyx32
Sat Aug 22, 2020 1:23 am
2. MU-MIMO
3. 802.11 k/v/r
For sure we'll get those features on ROS just wait till WiFi 7 gets announced xD
sfrode
Sat Aug 22, 2020 2:27 am
I have no problem pushing ~9.3Gbit/s IPv4 in a single thread using iperf3 between two hosts routed on the CRS317 with L3 offloading enabled. IPv6 is, as expected, another story - it gives me ~370Mbit/s.
UpRunTech
Sat Aug 22, 2020 3:35 am
Thank you.
You'd be a fool to reimplement it yourself. Have a look at the Wireguard site and code and see for yourself how carefully it's been developed. Mikrotik would/might have only done some interface changes to make it work the ROS way.
reddin
Sat Aug 22, 2020 3:48 am
Can't add key in wireguard via cli with "=" at the end. But can add it later via edit and can add it via gui.
killersoft
Sat Aug 22, 2020 4:11 am
I still cannot get MACSEC running between devices("Gets to negotiating only").
Any suggestions ?
/interface macsec
add cak=4cb39ed149d0e0dbea5fad4b91e5456f ckn=f98446584e49ad9e2cd99b2aff00adb73e0b4109eb916b8d5bbe208dda274abb \
    disabled=no interface=ether5 name=macsec1 profile=default
[admin@under desk] /interface/macsec> print
Flags: I - inactive, X - disabled, R - running
 0   name="macsec1" interface=ether5 status="negotiating" cak=4cb39ed149d0e0dbea5fad4b91e5456f
     ckn=f98446584e49ad9e2cd99b2aff00adb73e0b4109eb916b8d5bbe208dda274abb profile=default
nathan1
Sat Aug 22, 2020 4:38 am
OpenVPN UDP still broken in this release. :(
For anyone else wondering, 7.0beta5 is the latest version that has OpenVPN UDP working. 7.1beta1 and and 7.1beta2 both have kernel crashes when you attempt to use it.
I reported it to Mikrotik and it has been acknowledged but it seemingly did not make it into this release.
nescafe2002
Forum Veteran
Forum Veteran
Sat Aug 22, 2020 10:11 am
Put the key value between quotes, you may find the correct syntax using the export command.
[admin@MikroTik] /interface/wireguard> add private-key="EMjwk8mpDylWKGU0c/z9TR1e5u1D75OUz2jsv3lZu3k="
[admin@MikroTik] /interface/wireguard> peers/
[admin@MikroTik] /interface/wireguard/peers> add allowed-address=10.20.30.40 public-key="ObVREVOUlpRvqPxshivdYGiirVhb/U/dt1T7rQE2WFk=" interface=wireguard1
[admin@MikroTik] /interface/wireguard/peers> export
# aug/22/2020 09:10:46 by RouterOS 7.1beta2
/interface wireguard peers
add allowed-address=10.20.30.40/32 interface=wireguard1 public-key="ObVREVOUlpRvqPxshivdYGiirVhb/U/dt1T7rQE2WFk="
Chupaka
Sat Aug 22, 2020 1:03 pm
By the way, there's no "export" command under new /routing menus :(
Chupaka
Sat Aug 22, 2020 1:21 pm
I tried to setup point-to-point OSPF via SSTP tunnel, and in /routing/route/print I see duplicated routes without gateway. WAIDW?
Flags: I - INACTIVE, U - UNREACHABLE, A - ACTIVE; c - CONNECT, o - OSPF, d - DHCP, l - LDP-MAPPING
Columns: DST-ADDRESS, GATEWAY, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
      DST-ADDRESS               GATEWAY         DIS  SC  TA  IMMEDIATE-GW
  Ad  0.0.0.0/0                 10.0.0.1          1  30  10  10.0.0.1%ether1
  Io  10.0.0.0/23                               110  20  10
  Ao  10.0.0.0/23               sstp-odesskaya  110  20  10  sstp-odesskaya
  Ac  10.0.0.0/24               ether1            0  10      ether1
  Io  10.52.56.0/24                             110  20  10
  Ao  10.52.56.0/24             sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.0.0                                110  20  10
  Ao  100.64.0.0                sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.0.1                                110  20  10
  Ao  100.64.0.1                sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.0.2                                110  20  10
  Ao  100.64.0.2                sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.0.3                                110  20  10
   o  100.64.0.3                sstp-odesskaya  110  20  10  sstp-odesskaya
  Ac  100.64.0.3                sstp-odesskaya    0  10      sstp-odesskaya
  Io  100.64.0.4                                110  20  10
  Ao  100.64.0.4                sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.0.5                                110  20  10
  Ao  100.64.0.5                sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.0.6                                110  20  10
  Io  100.64.1.0/24                             110  20  10
  Ao  100.64.1.0/24             sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.3.0/24                             110  20  10
  Ao  100.64.3.0/24             sstp-odesskaya  110  20  10  sstp-odesskaya
  Io  100.64.6.0/24                             110  20  10
  Ao  100.64.6.0/24             sstp-odesskaya  110  20  10  sstp-odesskaya
The config is the simplest one:
/routing ospf instance
add name=ospf_v2 router-id=100.64.0.7 version=2
/routing ospf area
add area-id=0.0.0.0 instance=ospf_v2 name=backbone_v2
/routing ospf interface
add area=backbone_v2 network=sstp-odesskaya network-type=point-to-point
danbit
Sat Aug 22, 2020 2:12 pm
Is there any examples on how to configure wireguard as client on mikrotik? I'd like to connect my mikrotik router to an existing wireguard server. Also, while setting up the peer endpoint, only IP addresses are allowed? Can't I use a domain name?
Thanks!
pe1chl
Sat Aug 22, 2020 2:13 pm
When you don't like that, just don't turn the knobs!
It is always easy (at least at first) to create something as a single supplier and focus on a single use-case, and make it look simple. Look at Microsoft Windows.
But as more and more features are added (e.g. multiple different encryption methods, as in IPsec), it becomes more complicated over time.
See how it went with OpenVPN, that was also simple at first but got more complicated on the way, especially because there was little forethought on how to accomodate future flexibility in the initial protocol.
IMHO the same will happen with wireguard.
In IPsec it happened right from the start because lots of options for lots of selections were there all the time. But without that, it would have been even more difficult to introduce stronger encryption and hashing protocols, for example.
Paternot
Sat Aug 22, 2020 3:20 pm
One thing that need to be done is to allow Wireguard to use FQDN instead of just IP addresses. For two reasons, basically:
1) Not everyone have a static IP
2) With IPv6, DNS names will make a huge difference. So much easier to remember and to check the spelling...
Yes, yes, I know. Wireguard doesn't do FQDNs. It doesn't matter: just put the name on the configuration, and do a DNS lookup at connection time. Exactly like we have with IPSEC today.
comet48
Sat Aug 22, 2020 6:10 pm
So announcement says CRS309-1G-8S+IN, CRS312-4C+8XG-RM, CRS326-24S+2Q+RM and CRS354-48G-4S+2Q+RM for L3 offload but CRS317 mentioned above as working.
I have CRS326-24G-2S+ (arm). Will it take advantage of L3 offloading? If so, what else will?
xvo
Sat Aug 22, 2020 7:27 pm
For CRS317 it was added earlier.
amirali
Sat Aug 22, 2020 8:03 pm
hi
please help about wg config
i setup peer and wg interface but cant get any traffic throw the tunnel
[admin@MikroTik] /interface/wireguard> export
# aug/22/2020 21:33:34 by RouterOS 7.1beta2
# software id = xxxx-xxxx
# model = RouterBOARD 952Ui-5ac2nD
# serial number = xxxxxxxxxxxxx
add listen-port=53 mtu=1420 name=wireguard private-key=\
    "private_key"
add allowed-address=0.0.0.0/0 endpoint=185.253.xx.x:53 interface=wireguard \
    preshared-key="preshared key" public-key=\
    "pub_key"
parham
Sat Aug 22, 2020 8:13 pm
WOW, fantastic job, RouterOS getting better and better, thanks, we just need letsencrypt integrated to RouterOS.
mozerd
Forum Veteran
Forum Veteran
Sat Aug 22, 2020 8:42 pm
i absolutely disagree with you @pe1chl
https://www.wireguard.com/#conceptual-overview
“ WireGuard securely encapsulates IP packets over UDP. You add a WireGuard interface, configure it with your private key and your peers' public keys, and then you send packets across it. All issues of key distribution and pushed configurations are out of scope of WireGuard; these are issues much better left for other layers, lest we end up with the bloat of IKE or OpenVPN. In contrast, it more mimics the model of SSH and Mosh; both parties have each other's public keys, and then they're simply able to begin exchanging packets through the interface.”
floaty
Sat Aug 22, 2020 8:43 pm
L3-offloading is a broad topic ... the prestera-chip also supports "NVGRE, VXLAN-GPE, GENEVE, SPB, and 802.1BR port extender"
... is vxlan-tunneling now also implemented with hardware-flow-support ... or we talking just base L3-forwarding capabilities ( ... for now) ?
FezzFest
Sat Aug 22, 2020 9:03 pm
Both Sierra MC7430 and Quectel EC25 work in MBIM mode in ROS7. Big difference with 6.47.x, as the MC7430 was only supported in PPP mode and the EC25 was supported in PPP and ECM modes. I do notice the amount of information the cards report is different. The MC7430 only reports RSSI, whereas the Quectel cards report RSSI, RSRP, SINR and RSRQ.
Edit: I noticed the APN doesn't get set up properly on EC25. I can make it work with AT+CGDCONT=1,"IP","apn-name". This was not needed in 6.47.
BrokenLink
Sun Aug 23, 2020 11:46 am
hi
    "private_key"
    "pub_key"
I have the same issue, I think firewall rules are not setup correctly (although I accept traffic on the listening port and forward to/from the interface), it doesn't seem to flow. The tunnel sets up correctly and the client routes to the WG server, but I can't figure out how to correctly set it up so that traffic is routed back correctly. Does anyone have a complete example including firewall rules where how to connect a roaming client to the WG server such that all (internet) traffic is routed through the MikroTik WG system?
pe1chl
Sun Aug 23, 2020 2:38 pm
When you restrict yourself to site-to-site tunnels between equipment running the same software, IPsec is not complicated either. E.g. a GRE/IPsec tunnel using pre-shared keys between two MikroTik routers can be configured with a couple of mouseclicks.
It becomes more complicated when you want more advanced functionality, like auto-config road warrior clients, certificates, etc. Simply declaring that "out of scope" is like burying your head in the sand; that is not going to be sustainable. Like with OpenVPN, the demand for those features will sooner or later lead to additions to wireguard, and by then it (including its new layer of additions) will be as "complicated" as OpenVPN.
Sure, IPsec can be frustrating. But only when dealing with unknown and uncontrollable peers that inconsistently publish their config. Between routers of the same manufacturer that you both control, it isn't a problem.
And with wireguard that is (for now) essentially what you have: the same software at either end.
Once the protocol develops and diverts between implementations, that will no longer be the case.
Znevna
Sun Aug 23, 2020 3:05 pm
So.. little broblem.
I've upgraded from 6.46.6 to 7.1beta2 directly (I know, bad) ...and this happend with my static routes. I made an export before and after the upgrade to see what changed.
I get the missing gateway, but the IP in pref-src? (and only there?) why?
before:
add distance=1 dst-address=172.28.248.0/24 gateway=ipip-tunnel-z3 pref-src=\
    192.168.69.1
add distance=1 dst-address=192.168.134.0/24 gateway=ipip-tunnel-z3 pref-src=\
    192.168.69.1
add distance=1 dst-address=192.168.135.0/24 gateway=ipip-tunnel-z3 pref-src=\
    192.168.69.1
add distance=1 dst-address=192.168.136.0/24 gateway=ipip-tunnel-z3 pref-src=\
    192.168.69.1
add distance=1 dst-address=192.168.248.0/24 gateway=ipip-tunnel-z3 pref-src=\
    192.168.69.1
after:
add dst-address=172.28.248.0/24 gateway="" pref-src=1.69.168.192
add dst-address=192.168.134.0/24 gateway="" pref-src=1.69.168.192
add dst-address=192.168.135.0/24 gateway="" pref-src=1.69.168.192
add dst-address=192.168.136.0/24 gateway="" pref-src=1.69.168.192
add dst-address=192.168.248.0/24 gateway="" pref-src=1.69.168.192
LE: I do have to read and understand the routing changes from the manual for v7.
For now I can't seem to get the IPIP tunnel to work properly over IKEv2. The other end (running 6.46.6) shows the tunnel coming up and running but nothing on the v7.1b2, and I can't send anything over it.
ujsd
Sun Aug 23, 2020 3:21 pm
Both Sierra MC7430 and Quectel EC25 work great in MBIM mode in ROS7. Big difference with 6.47.x, as the MC7430 was only supported in PPP mode and the EC25 was supported in PPP and ECM modes. I do notice the amount of information the cards report is different. The MC7430 only reports RSSI, whereas the Quectel cards report RSSI, RSRP, SINR and RSRQ.
I also notice the lte1 interface of the device with the EC25 card sometimes disappears after a reboot.
I like to add and ask others (if they are seeing the same) that I am seeing a similar issue with the LTE modem disappearing after a Router boot or USB Modem unplugging and plugging
The Quectel USB Modem EM12 reports no SIM detected,
I have to go into teh Qucetel EM12 modem and use AT commands to reset the SIM detect
miroslaw
Sun Aug 23, 2020 5:39 pm
Thank you guys for wireguard support, that's what I've been waiting for.
One minor bug I found, can't set comment for wireguard peers (cli & webfig, havent tried winbox).
I'm using hap ac2 RBD52G-5HacD2HnD
rpress
Sun Aug 23, 2020 8:44 pm
Yes, I noticed also comments don't save for wireguard peers at all. Also ipv6 addresses can only be used in CLI.
pe1chl
Sun Aug 23, 2020 8:56 pm
For now I'd assume that conversion from older versions does not work yet (for those features that drastically changed, like routing) and setup everything from scratch.
msatter
Sun Aug 23, 2020 10:50 pm
Request: make it possible to ignore the provided dynamic DNS by the VPN providers, also for WireGuard?
vitalys
Mon Aug 24, 2020 9:20 am
OpenVPN realization in Mikrotik is still useless due to lack of SHA256/SHA512 support (SHA-1 deprecated https://shattered.io/)
When SHA512 will be supported in Mikrotik?
bratislav
Mon Aug 24, 2020 11:57 am
There is a difference between hashing (as SHA1) and encryption (as AES...) and just because someone is able to generate 2 different PDF files that produce same SHA1 hash does not mean he could reversely generate private keys used in VPN ...
raimondsp
Mon Aug 24, 2020 2:25 pm
The wiki page has been updated with the most-recent information regarding L3 HW Offloading:
https://wiki.mikrotik.com/wiki/Manual:C ... Offloading
rpress
Mon Aug 24, 2020 3:48 pm
In IPv6 firewall filter the "reject" action is not working. It causes the whole IPv6 firewall to be bypassed and the counters show bogus numbers. I tried on both "input" and "forward" chains.
npeca75
Tue Aug 25, 2020 6:26 am
rb 760igs
if i try to make any change on PoE / eth5 router is rebooting with kernek failure message
PoE does not work with "auto", aways say "too low"
in prev v6 release this was worked without problem
tpedko
Tue Aug 25, 2020 9:39 am
model: RB4011iGS+5HacQ2HnD
add
/queue simple
add max-limit=30M/30M name=All_30Mbit queue=pcq-upload-default/pcq-download-default target=192.168.0.0/24
result, boot loop
krisjanisj
Tue Aug 25, 2020 10:09 am
@miroslaw & @rpress - Wireguard peers unable to set a comment has been reported to our developers and fix will be included in next RouterOS release.
@npeca75 & @tpedko - Is it possible for You to send supout.rif files to support@mikrotik.com, referencing this forum thread, so we can troubleshoot this further?
evgenij
Tue Aug 25, 2020 12:28 pm
ROS: 7.1beta2
1) Unable to create GRE6 and IPIPv6 interfaces
CLI and winbox says - failure: adding tunnel failed
2) Unable to set peer Endpoint port in winbox. CLI works
3) Unable to add IPv6 routes using the winbox: routes are deleted immediately after creation or disabling. CLI works
4) IPv4 routes are deleted immediately after disabling (winbox)
msatter
Tue Aug 25, 2020 12:43 pm
ROS: 7.1beta2
Number two was already mentioned in this thread. Number four is cosmetic and on re-entering the route window they are displayed as disabled.
raimondsp
Tue Aug 25, 2020 2:52 pm
CRS326-24G-2S+ has an older switch chip, for which L3 offloading is not supported yet. Here is the list of supported devices:
https://help.mikrotik.com/docs/display/ ... heirlimits
elbob2002
Tue Aug 25, 2020 3:05 pm
Upgraded my RB3011 this morning to 7.1beta 2.
I reset the router before upgrading and only configured it with a WAN connection to upgrade to Beta2.
Upgrade seemed to go okay so I set about configuring it correctly.
First issue was renaming an interface (ether1 renamed to WAN) would result in a reboot as soon as I clicked OK or Apply.
Second issue was a deal breaker and that was all 10 interfaces were limited to 10Mb only. I tried manually setting them to 1Gb full duplex but to no avail.
I reverted back to 6.47.2 so unfortunately I can't generate a supout but just wondering if anyone has seen anything similar? Surely there are other RB3011 users out there that have upgraded?
evgenij
Tue Aug 25, 2020 3:14 pm
Does anyone have problems with GRE/IPIP (v4) tunnels (interfaces don't work)? EoIP works
eworm
Tue Aug 25, 2020 3:21 pm
You have to unset the timeout for GRE interfaces:
/ interface gre unset timeout [ find ]
evgenij
Tue Aug 25, 2020 4:29 pm
Are you sure about timeout? there is no such option
eworm
Tue Aug 25, 2020 4:49 pm
Ah, stupid me... Of course it's keepalive.
/ interface gre unset keepalive [ find ]
evgenij
Tue Aug 25, 2020 5:01 pm
@eworm Thanks, now it works
Znevna
Tue Aug 25, 2020 5:12 pm
!!!!! this fixed my IPIP tunnel too. lol (unsetting keepalive for ipip that is).
THANKS.
[admin@gw-viper-rds] /interface/ipip> print
Flags: R - RUNNING
Columns: NAME, MTU, ACTUAL-MTU, LOCAL-ADDRESS, REMOTE-ADDRESS, DSCP
  #     NAME            MTU   ACTU  LOCAL-ADDRESS  REMOTE-ADDRE  DSCP
  0  R  ipip-tunnel-z3  auto  1402  172.28.252.69  172.28.252.1  inherit
Running! ^^
sinisa
Tue Aug 25, 2020 5:30 pm
Hello!
You have done a very nice work with Wireguard, I honestly did not expect it this year.
My problem with 7.1 is that recursive routes are not working (same problem as here: viewtopic.php?t=165021)
Everything else that I use is working fine (and since now we have Wiregiard, I don't need OpenVPN any more, do I don't care about UDP support)
Best regards...
msatter
Tue Aug 25, 2020 5:35 pm
I still consider 7.x as a pre-Beta as it just reboots you touch someting that is untouchable. You only will know it was untouchable because, after the reboot the change was lost.
I went back to a stable Beta within minutes after walking into reboot walls.
Znevna
Tue Aug 25, 2020 6:02 pm
Are the issues with RAW Firewall known?
If you have any rules there (two+) issuing a disable/enable on any of them makes the counters for the existing enabled rules go crazy.
Also I have a rule that keeps counting packets when enabled even though there shouldn't be any matching traffic (the notrack one), setting a log for it doesn't show anything..
/ip/firewall/raw> print stats
Flags: X - DISABLED, I - INVALID
Columns: CHAIN, ACTION, BYTES, PACKETS
  #     CHAIN       ACTION                           BYTES                     PACKETS
  0     prerouting  drop             7 182 164 577 801 072   9 367 141 933 521 187 617
  1  X  prerouting  drop                                 0                           0
  2  X  prerouting  notrack      9 890 406 038 755 190 484  15 743 512 066 554 732 580
  3  X  prerouting  passthrough  3 821 585 153 310 984 802       6 668 097 643 014 512
npeca75
Tue Aug 25, 2020 6:40 pm
Ok
supout was sent today
SUP-25925
elbob2002
Tue Aug 25, 2020 7:43 pm
Yeah. I wasn't expecting too much but I found the RB3011 much more unstable than the CHR and two CRS125s I have it running on.
npeca75
Tue Aug 25, 2020 8:44 pm
Is there a plan for resolving DNS peer names in WireGuard properties?
or we are doomed to script/resolve/set wireguard peer endpoint?
Paternot
Tue Aug 25, 2020 10:17 pm
Yes, this is a must! Is so easy to do, since almost all the needed code is already there.
danbit
Tue Aug 25, 2020 11:14 pm
+1 on that request. Using a domain would make things much easier indeed.
Also, I can't seem to find a way to enable logging for wireguard. Is this not yet implemented in this latest beta?
Paternot
Wed Aug 26, 2020 12:16 am
Yes, it is. Just like the rest:
1) Choose the topic (info, debug, etc)
2) Choose the prefix (wireguard)
romas
Wed Aug 26, 2020 12:32 am
It's good news about wireguard! I updated my RB951G-2HnD and all works well. But might you help me? I have wireguard remote server (172.16.0.1) my mikrotik (172.16.0.3 / 192.168.1.1) and my laptop (192.168.1.2) and I can't understand how to setup vpn to my remote server for my laptop without mark routing?
redskilldough
Wed Aug 26, 2020 3:27 am
Let's say I have this in my wireguard configuration file, how would I deploy it in my mikrotik router?
Also, how would I route traffic from client 192.168.0.44 only, through this tunnel?
Any help would be greatly appreciated
Thanks!
[Interface]
PrivateKey = 123456=
Address = 172.16.0.12/32
Address =111:222:aaa/128
DNS = 8.8.8.8
[Peer]
PublicKey = 456789=
AllowedIPs = 0.0.0.0/0
AllowedIPs = ::/0
Endpoint = aaa.bbb.com:2255
rplant
Long time Member
Long time Member
Wed Aug 26, 2020 1:22 pm
Minor issue with Wireguard
Mostly seems great, quite impressed with it, I have not used wireguard before.
If I don't set the peer address, so any address can connect, when a peer does connect to it
it seems to set the peer address/port itself in its config :(
I would also like DNS connect
eworm
Wed Aug 26, 2020 1:29 pm
This is by design. Peers are identified by their public key, changing the endpoint automatically makes it roam seamlessly.
If the peer changes its address the configuration should update again.
npeca75
Wed Aug 26, 2020 6:29 pm
hi @krisjanisj
another issue with rb760igs
temperature sensor is missing
no such item in Winbox and also sensor is missing from SNMP
:( pitty
UserFan
Wed Aug 26, 2020 9:20 pm
Please add parent proxy authentication
m0x35
Thu Aug 27, 2020 12:54 am
Does anyone have some issues with wifi? On my hap ac^2 from time to time wifi clients can't get ip addresses from dhcp. I have tried to reset wifi settings to default, reset router itself, configure wifi via quick setup web page. Nothing works for me. I have downgraded routeros back to the stable version and everything works just fine again. Only strange thing in logs that I saw was something like "disconnected, group exchange timeout".
subway
Thu Aug 27, 2020 6:26 pm
What I tried to find out if the ROS 7 betas can run on anything else than ARM based devices? For example can it work on the CCRs?
Maybe a bit of clarification on the supported hardware would be nice as I cant find anything about that except for a single entry by Normis from 2019 (only ARM for now).
Paternot
Thu Aug 27, 2020 6:37 pm
Here you will find the RoS 7.1beta download link. It shows each supported architecture.
rpress
Thu Aug 27, 2020 9:27 pm
Looks like only one wireguard interface is working at a time, whatever is started first. Only the first shows as "running".
Does anyone have more than one simultaneous wireguard interface working?
mozerd
Forum Veteran
Forum Veteran
Thu Aug 27, 2020 10:32 pm
I am not running the MikroTik implementation so I have no idea if in its current state of RouterOS 7.1beta2 how may peers can be run .... and yes under ubnt EdgeRouter I have multiple Peers running in client sites.
Following link shows how it should be done ... hope this helps you ... assuming the TiK way does not imped.
https://www.zahradnik.io/wireguard-a-vp ... ge-in-mind
scroll down to Everyone is a peer where the CLI info is shown.
Paternot
Fri Aug 28, 2020 12:21 am
I have one little test, with 3 CHRs. I named them after their IP, so we have 115, 116 and 118 machines.
I inserted static routes, sou The left machine should be able to ping the right machine - passing through the center one. Pay attention to the IP addresses on the Wireguard config - You will have to adjust them to your network.
This is NOT a production example. It is just the absolute minimum, in order to test two wireguard interfaces on a single machine. I didn't even set a password to the admin user.
rpress
Fri Aug 28, 2020 12:50 am
Thanks both for your input. I have found the problem: using WebFig the listen-port always defaults to 12321. Although I was not using the port, it would conflict with the other interface. Setting one of the listen-port to something else worked fine.
Interestingly using the terminal, the listen-port seems to be randomly generated, thereby not having this issue. But I wonder if this seemingly random port could have it's own problems. With Wireguard is it possible to disable listening altogether? Maybe this would be the best default.
Mannsean
Fri Aug 28, 2020 1:56 am
Same issue
kylepharo
Sat Aug 29, 2020 2:18 am
I'm having similar problems on my rb4011igs+5hacq2hnd-in. Also did a reset to defaults with minor adjustments (ssid, wpa2 psk etc).
Clients appear to lose DHCP lease, then disconnect completely. Phones (iphones) appears to to experience the problem the most often
Clearing and netinstalling the latest testing 6.48beta27 issues go away, no dhcp loss/disconnections on wifi
romas
Sat Aug 29, 2020 9:47 am
I have a small issue with DNS over HTTPS. It works perfectly in 6.47.2, but now mikrotik can't verify certificate. I tried to re-import it, but nothing helps.
pe1chl
Sat Aug 29, 2020 12:09 pm
Are you sure you have imported the entire chain from the root, and not only the server certificate?
romas
Sat Aug 29, 2020 1:56 pm
Yes I'm, and it was validated succesfully on stable branch
romas
Sat Aug 29, 2020 2:02 pm
Thanks!
[Interface]
DNS = 8.8.8.8
[Peer]
PublicKey = 456789=
AllowedIPs = ::/0
You might be interested this howto : https://rickfreyconsulting.com/wireguard/ , but how to route one client without marking I don't know, unfortunately.
Znevna
Sat Aug 29, 2020 3:00 pm
Tiny (not realy) bug:
I don't know why but my dynamic DNS servers went *poof* from the config. (Which are set by the pppoe client).
No wan disconnect, nothing in the logs. They just went missing.
And I was wondering why the DNS cache is empty...
redskilldough
Sat Aug 29, 2020 3:08 pm
Thanks!
[Interface]
DNS = 8.8.8.8
[Peer]
PublicKey = 456789=
AllowedIPs = ::/0
Thanks for the reply.
Anyway, I managed to get it to work, this should help those who want to connect to vpn providers that provide wireguard support, eg. I think nordvpn does.
Once you have such a configuration file for the wireguard client in windows, mac, do this, using winbox
1. Go to the wireguard menu, add a new interface
2. Leave the default setting, just add the private key from the interface section of the wireguard config file, in this example, 123456=, click apply
3. Go to the peer tab, add a new peer, use the public key from the peer section of the wireguard config file, in this example,456789=,
Since I want to route all traffic from specific clients to through this interface, put 0.0.0.0/0 in allowed ips
4. Use nslookup, resolve the endpoint, in this case, aaa.bbb.com to its ip address. Put that ip address in the end point.
5. Use the terminal go to /interface/wireguard/peers. if there is only 1 peer, run this, set 0 endpoint=[ip address]:2255
6. Go to IP addresses, set the ip address for the wireguard interface, in this case, 172.16.0.2/32
7. Go to IP firewall NAT, add a masquerade rule, chain srcnat, outgoing interface -> your wireguard interface, action=masquerade
8. Run this command in the terminal, /routing table add name=VPNProvider fib
9. Go to IP firewall mangle, add a mangle rule, use source address for the client whose traffic you want to route through the vpn interface, or use source address list for several clients.
Chain=prerouting, Action=mark routing, new routing mark, choose VPNProvider from the combo box. (This was the tricky part, you cant just type in VPNProvider like in ROS 6, you have to add it to the routing table first, the only can you choose it as a new routing mark)
10. Finally add a new route in the terminal, like this, /ip route add dst-address=0.0.0.0/0 gateway=[your wireguard interface]@main routing-table=VPNProvider
That's it, your specified clients should now be routed through your vpn connection
erkexzcx
Sat Aug 29, 2020 9:32 pm
Does this beta release work great with Winbox? Or is it console-only while it's beta?
Sob
Sat Aug 29, 2020 9:47 pm
Most of it is ok in WinBox. There's problem with Wireguard port mentioned in this thread. Also 'routing-table' parameter is missing from IP->Route.
romas
Sun Aug 30, 2020 11:52 am
Thank you for the tricky way with marking. I did it, pings between server and mikrotik is good, DNS is working on well, but internet on the client is incredibly slow, trying to troubleshoot it
BartoszP
Sun Aug 30, 2020 11:57 am
@romas:
Do you REALLY need to quote such a long post? What for?
Please edit it.
redskilldough
Sun Aug 30, 2020 1:18 pm
Yes, I noticed that too. I can max out my 500/100 internet connection with ROS 6.47.2, fasttrack enabled, but with ROS 7.1b2, I'm getting only about 100+/100, even with fasttrack enabled (using a mikrotik hex).
I guess it's still in beta and will probably get better later.
Chupaka
Sun Aug 30, 2020 3:53 pm
Could somebody check SOCKS5 with password auth in ROS v7? It's not working for me. SOCKS4 looks good.
NilKad
Wed Sep 02, 2020 3:12 pm
lte1 receives DNS via DHCP (from the modem) with the checkbox off in LTE APN - Use Peer DNS. I can't turn off the use of DNS from the router side.
pe1chl
Wed Sep 02, 2020 3:38 pm
You need to turn it off in the DHCP client!
sindy
Wed Sep 02, 2020 4:28 pm
For some modem types, the DHCP client is dynamically created and cannot be modified (nor prevented from being dynamically generated and created manually), so this advice is not applicable. For the dynamically created DHCP client, the setting in question (plus other ones) is (in theory) inherited from the apn profile.
For yet other modems (R11e-LTE6), there is no DHCP client at all, and nevertheless the IP address is assigned and the default route and other settings from apn profile are used (also in "direct IP" mode, i.e. not PPP/serial).
pe1chl
Wed Sep 02, 2020 4:59 pm
Ok, but it can be clearly seen above that "Use peer DNS" is OFF in the LTE profile and it is ON in the DHCP client. So that is a bug?
Gnubyte
I just found a reproductible bug causing reboot
Wed Sep 02, 2020 5:22 pm
Hi all,
I just installed v7.1beta2 on the CCR2004 I have here in tests. I was looking for better support of 1Gbps+ SFPs interfaces inserted in SFP+ ports, and I found a bug.
Presentation of reproduction conditions
A brand New CCR2004, with an Optical GPON ONU SFP recognized as brand "ODI"
The ONU is fully functionnal under v6.47.2, seems to let change the AUto Negotiation Speed to more than 1000M Full, but allways limited to 1000M.
According to https://www.dslreports.com/forum/r32230 ... 57810S-NIC SGMII linux patches can let SFP sticks run at more that 1000M, so I give a try to v7.1beta2.
I upgraded the fimrware, go to the sfp-sfpplus interface, doble clic, and yes, it's still recognized, but this time eligible speeds are not pre checked. So I check 2.5G Full, and instant reboot.
No way to change the neciable speed. Everytime I try to change it, it reboots. Unfortunately, It seems limited to 1000M.
  • I give a try with another stick of this kind, and I come back. I do have several sticks of this kind.
  • When I do exactly the same procedure with another SFP ONU Stick (CarllitoxxPro), it reboots.
  • It's exactly the same reboot changing the negociated speed of a S+RJ10 Mikrotik Interface
This bug, about SFP speed negociation, seems generic, including with Mikrotik Interfaces.
I can make you more explicit capture CLI, most of all for the first ONU stick of course, If you can let it run 2.5Gbps patching this bug, I would be gracefull.
Hope this helps. Feel free to contact me by email.
lupusx
Wed Sep 02, 2020 7:00 pm
Do beta releases require licence for testing ?
In other words can I install it f.e. on x86 for tests without any additional licence ?
rpress
Wed Sep 02, 2020 7:09 pm
Yes it requires a license. You can get a trial as usual.
And actually, when upgrading from v6 the old license is now invalid. So the license must be transferred to the new v7 install, making it not easy to go back to v6.
redskilldough
Thu Sep 03, 2020 6:31 am
Hi, disabling fasttrack seems to solve this problem
kylepharo
Re: I just found a reproductible bug causing reboot
Thu Sep 03, 2020 8:03 am
Have you tried changing the speed/duplex etc via the CLI instead of via the web ui?
I had a similar issue forcing a 10gbit interface to be 1gbit on a CRS 317 running 7.1beta2. Via winbox would cause the router to crash, via CLI worked fine.
bozko
Thu Sep 03, 2020 9:31 am
Can someone provide a working example of wireguard setup WITHOUT Endpoint on RouterOS device?
eworm
Thu Sep 03, 2020 9:39 am
Wireguard endpoints are set and updated automatically on handshake.
Gnubyte
Thu Sep 03, 2020 10:23 am
Thanks for the advice. I try it.
bozko
Thu Sep 03, 2020 10:29 am
Huh. Are you sure that both of endpoint can be updated automatically?
Nevertheless, I can't find any example of routeros setup with one of the peers is with endpoint (e.g. "client") and other is without ("server"). May be I'm on wrong path...
eworm
Thu Sep 03, 2020 12:02 pm
No, only one endpoint (at a time). The other side has to initiate the handshake.
But Wireguard does not follow a classic client and server model. It has just peers, so both sides can initiate the handshake.
thadrumr
Thu Sep 03, 2020 4:40 pm
7.1 beta2 no longer boots in i686/32bit mode. This kernel seems to only have 64bit enabled. Is this on purpose? Are 32bit machines finally getting the ax?
rpress
Thu Sep 03, 2020 4:53 pm
I don't have a single Wireguard interface with one peer as server and one as client. But I do have two Wireguard interfaces, where one is a server (listening) and has two peers. On these, the peer endpoints update automatically as already mentioned. My other Wireguard interface is a client with one peer. The CLI is needed to set the endpoint port for this one.
As I found the hard way the Wireguard interface listens regardless if you want it to or not. I expect that you should have no problem having one Wireguard interface like you want.
rooted
Sat Sep 05, 2020 7:40 pm
Removed due to complaining.
nostromog
Sat Sep 05, 2020 9:17 pm
In my case, even with user-peer-dns off both in lte1 and the dynamic dhcp-client, ip dns is showing it in the "dynamic-servers" and there is no way to get rid of them once installed, no matter what I do.
I'm using a USB cable with an android phone in "USB tethering" mode with a hAP ac^2. Other than this it works like a charm. The /ip/dns/dynamic-servers remain set when I unplug the cable and lte1 disapperars and remains visible only as something like *00008 in some places.
Znevna
Sat Sep 05, 2020 9:59 pm
This gentlemen wrote an in-depth tutorial for MikroTik site to site VPN:
https://rickfreyconsulting.com/wireguar ... n-example/
That's hardly an "in depth tutorial". And don't get me started on the quality of the screenshots, missing accompanied selectable text for whatever goods are or aren't in them, or the discrepancies between the screenshots and the settings export provided. Or the missing proper explanation of allowed address fields with proper examples.
Or how about the MTU? barely mentions something about it but that's it, nothing about setting up proper MTU for the interface.
"in depth", pft.
It's not rocket science to build up a Wireguard tunnel and route something over it.
Do you guys get a cut for traffic generated to his site or out of how many "clients" that guy "gets" thanks to you?:)
evgenij
Sun Sep 06, 2020 12:09 am
Does anyone have a problem with the bridge firewall?
IP firewall is enabled
I can see network traffic between the two interfaces, but not in the bridge statistics and the bridge-firewall is not catching any packets in the forward chain
mozerd
Forum Veteran
Forum Veteran
Sun Sep 06, 2020 2:38 am
@ Znevna ....
IMO Rick Frey provides an excellent tutorial on using WireGuard and MikroTik and I hope that he gets as many clients as he deserves.
Arcticfox
Sun Sep 06, 2020 11:12 am
Nice version, but on CRS326-24S+2Q something goes wrong: Kernel panic on much of reasons.
1. Connected to HP virtual connect via SFP+ - kernel panic
2. Connected to Procurve switch and assigned vlan to port via Copper SFP- kernel panic
3. Connected to cisco n3k-c3064pq kernel panic
And this panic is so deep that console is unreachable after reboot. Only reset to factory defaults helps to move it out.
What I did wrong (else trying beta).
Znevna
Sun Sep 06, 2020 12:08 pm
@ Znevna ....
Ofc you'd say that, you're in the same business model. I also hope he gets as many clients as he deserves.
"excellent" and "in depth" tutorials should be written on the forum if the intention was to share some knowledge with the users, not on some personal website for personal gain *cough* and drop the link randomly on the forum so that his website would get hits from the curious users. Luckily those two tutorials by him fits neither.
Writing a tutorial on the forum also allows you to get some feedback on your solution from other experienced users and maybe ways to improve your tutorial/solution (see the VLAN articles by pcunite for example).
As a bonus the forum provides support for proper CODE blocks that the users are used to.
As I've said, dropping links to your personal website on this forum and reddit screams only one thing and nothing good about it.
pe1chl
Sun Sep 06, 2020 12:12 pm
I fully agree with you, and also I think he is mainly a wireguard fanboi and makes false claims about the alternative methods (especially on RouterOS).
But hey, there are many of them.
huntermic
Sun Sep 06, 2020 12:43 pm
I have an issue here with the 7.1 beta 2 on 3 hAp ac^2 devices. Had te return to the stable branch for wireless to become stable again.
On all devices i had serious stability issues.
pe1chl
Sun Sep 06, 2020 12:45 pm
Such a posting would actually be useful when it included relevant details of what you were experiencing.
nostromog
Sun Sep 06, 2020 1:22 pm
He told that the same I am seeing: devices get stuck but otherwise connected on both interfaces.
Some time after last disable/enable cycle or reboot, any of the devices stop flowing through the wireless connection. If they are "clever" they migrate to the other, say wlan2. I often find after a few hours that all devices except one are in, say wlan1 and only one is in registration table at wlan2, but not working. disable/enable makes it work again, until it failed
It was not happening in 7.1beta1, it takes a few hours to happen, seems to be related with noise and distance, as it got better to me by:
* increasing the antenna gain in both interfaces (which also made for better signal overall and less warm router, BTW).
* changing a few other wireless settings.
Currently I have:
set [ find default=yes ] authentication-types=wpa2-psk group-key-update=1h mode=dynamic-keys supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=4 band=2ghz-onlyn channel-width=\
    20/40mhz-Ce country=spain disabled=no frequency=auto installation=indoor mode=ap-bridge ssid=MT \
    wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=5 band=5ghz-onlyac basic-rates-a/g=12Mbps \
    channel-width=20/40/80mhz-XXXX country=spain disabled=no frequency=auto installation=indoor mode=ap-bridge rate-set=configured \
    ssid=MT vht-supported-mcs=mcs0-9,mcs0-9,none wireless-protocol=802.11 wmm-support=enabled
and it happens less than with the default settings. Failing devices are mostly android, but also a windows and a linux laptop occassionally. I have set wireless debug in one of the phones and saw a message like NETWORK_UNAVAILABLE DHCP NOT RESPONDING=1 (I'm inventing the message but it was the idea). The router thought that the phone was happily connected, BTW, but it disappeared from registration table when I switched wifi off / on in the phone, only to return to the same when I forced to reconnect. After disable/enable of the wlanN interface everything works again... for a few hours.
huntermic
Sun Sep 06, 2020 1:39 pm
I know and i'm sorry for that but i had to revert to a stable situation because of work i had to do. But still i thought it might be usefull to report.
The issues i had were with wifi.
Clients disconnected frequently and could often not get an ip address.
Sometimes wifi totally stopt functioning until turned of and on again on the hAp ac^2.
rooted
Sun Sep 06, 2020 2:02 pm
I don't know the guy who wrote the tutorial and I'm not a network engineer, seemed in depth enough to help me so I thought it may help others.
Lighten up, I removed the post...
Znevna
Sun Sep 06, 2020 8:20 pm
bug: 7.1beta2, hAP ac2
changing any interface name belonging to the internal switch using WinBox GUI makes the router reboot:
sep/06/2020 20:14:55 system,error,critical router rebooted because some critical program crashed
Doing the same thing from terminal however: /interface/ethernet/print; /interface/ethernet/set X name=ethX; works fine.
LE: another bug(?) same version/hardware.
Leaving CPU Frequency to auto, I can see the frequency going up to 896MHz on high load. Ain't this dangerous?
Shouldn't we have an option to set max freq to the default frequency of the CPU? and not overclock it? As overclocking it can lead to .. well, problems?
Thanks.
subway
Sun Sep 06, 2020 11:13 pm
Bug:
1. After the upgrade (from latest stable), the PPPoE server was completely gone, but just that: the Secrets, Profiles and the rest of the PPP interfaces stayed.
2. After (or since) the upgrade, it is not possible to configure an interface as gateway under IP --> Routes. The only possibility is to set an IP as gateway.
Znevna
Sun Sep 06, 2020 11:19 pm
You can write the interface name manually and it will work even if there's no list from which you could easily select it.
On another note, I can't figure out how to setup load balancing using ECMP. More exactly how to adapt this old tutorial for v7: https://wiki.mikrotik.com/wiki/ECMP_loa ... masquerade
teleport
Tue Sep 08, 2020 12:01 am
have RBG450GX4 with latest stable version. am trying to apply 7.1 beta 2. no matter what approach i take(use webfig/winbox->quickset/winbox->system->packages for upgrade,dropping npk file), i get the 'not enough space for upgrade' in the log after reboot.
here is log line 1 and 2 after reboot:
system,info 'installed system-7.1beta2'
system,error 'not enough space for upgrade'
mine is a plain vanilla install for home use with no additional configurations/packages/customizations.
please let me know
subway
Tue Sep 08, 2020 1:15 pm
Thanks! Is this just a bug in the beta that the drop down list is not visible?
After the upgrade the routes that had interfaces as gateway were all in red, and the interfaces were gone.
nostromog
Tue Sep 08, 2020 1:22 pm
. Failing devices are mostly android, but also a windows and a linux laptop occasionally. I have set wireless debug in one of the phones and saw a message like NETWORK_UNAVAILABLE DHCP NOT RESPONDING=1 (I'm inventing the message but it was the idea).
I saw it again. The message was "NETWORK_SELECTION_DISABLED_DHCP_FAILURE=2 " (It was 1 last time I saw it. It recovers with disable/enable in wlan2 , disable/enable wlan1 in the router.
I'm not sure if the problem is due to connection o some other corruption: the wireless logs indicate good association followed by "sending station leaving (3)" about 8 seconds later, as if the station couldn't get dhcp going... but the router does not see any dhcp packet.
casus
Tue Sep 08, 2020 3:10 pm
Wireguard does not connect from Mikrotik behind NAT to a Linux server with a white IP.
eworm
Tue Sep 08, 2020 3:15 pm
What is a "white IP"?
But Wireguard with Mikrotik behind NAT is not a problem for me.
sindy
Tue Sep 08, 2020 3:25 pm
"White IP" is used in the post-soviet area instead of "public IP". "Grey" means "private". No idea what's the origin of this.
casus
Tue Sep 08, 2020 3:30 pm
Without using NAT. Without port forwarding, the interface address is not in the private or gray IP range.
Linux - conditionally server, Mikrotik - peer.
Share a secret )
eworm
Re: v7.1beta2 [development] is released!
Tue Sep 08, 2020 3:48 pm
Share a secret )
I'm sorry, but there's no secret... Just works for me.
Show you configuration export, possibly there's something fishy.
/interface/wireguard/export hide-sensitive
casus
Tue Sep 08, 2020 4:51 pm
follow the instructions from here : https://rickfreyconsulting.com/wireguar ... n-example/
and: https://www.cyberciti.biz/faq/ubuntu-20 ... pn-server/
# model = 960PGS
# serial number = CB540BCF02D3
add listen-port=8526 mtu=1420 name=3001
add allowed-address=192.168.160.0/24 endpoint=XX.181.201.XXX:61830 interface=3001 public-key=\
    "Fp9D00OEAHH9zotl3pw6cMTmwICL/OkZEj7KBo4ZWns="
Tinuva
Wed Sep 09, 2020 9:32 am
I have a similar issue like this on my RB750Gr3.
Upgraded to 7.2beta2 from 6.47 without resetting the router before the upgrade. It was then in a reboot loop until I reset it.
Afterwards, all 5 ports would connect at 1Gbps however, after a while, my WAN port ether1 would be stuck on 10Mbps sync, no matter what I do, different cables, different devices, it was stuck.
So moved the WAN port to ether5 and after a week same thing, except now I have both ether1 and ether5 stuck on 10Mbps sync.
I have moved the WAN to ether2 now, but if this keeps on happening, I will have to look at downgrading too :(
Really liked using wireguard, but 1Gbps ports are more important.
edit:
Actually I see this:
[admin@MikroTik] >> /interface/ethernet/export
# sep/09/2020 08:38:45 by RouterOS 7.1beta2
# software id = VQDT-J37Q
# model = RouterBOARD 750G r3
# serial number = 8AFF080AF8C6
set [ find default-name=ether1 ] advertise=10M-half,10M-full
set [ find default-name=ether5 ] advertise=10M-half,10M-full
Trying unset doesnt work:
/interface ethernet unset [ find default-name=ether1 ] value-name=advertise
What is the correct way to unset this advertise command ?
sindy
Wed Sep 09, 2020 11:06 am
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
Before issuing the command above, use /interface ethernet export verbose - it will show you that the value of the advertise parameter is set to this list for ether2-ether4; it's just that without the verbose modifier, the export does not show parameters with default values.
Tinuva
Wed Sep 09, 2020 11:18 am
Thank you @sindy that fixed it for me ;)
rplant
Long time Member
Long time Member
Thu Sep 10, 2020 4:18 am
Minor SFTP issue
winscp logging into router (hapac^2)
The top level directories (/flash, /disk1) show as broken links.
I can't click on them and go there.
I can type in /flash into winscp's open directory menu and that works fine.
reddin
Thu Sep 10, 2020 4:53 am
I've tried to connect like this to a dozen of a servers and everything worked well enough for me.
I've been wondering is it possible to generate keys on mikrotik for wireguard peers?
huntermic
Thu Sep 10, 2020 7:37 am
I would like to install v7.1beta2 on a RB4011 but it complains that it is missing multicast-7.1beta2-arm.npk
At the moment i'm running 6.48beta35 with the multicast package as extra package.
How do i upgrade without loosing the multicast functionality ( i use it for igmp-proxy ) ?
I got an answer from mikrotik: There is no multicast package, it is now part of system package, however IGMP-Proxy is not available in ROSv7 at the moment.
casus
Thu Sep 10, 2020 10:18 am
The Packet Sniffer on Mikrotik itself does not see any attempts to communicate with the server at all, filters by IP or port do not catch any packets in the direction of the server when the Wireguard interface is turned on and off.
Settings are made after Hard Reset, minimal - external interface and wireguard (+ manual IP for Wireguard interface).
rplant
Long time Member
Long time Member
Fri Sep 11, 2020 2:45 am
You can make a second wireguard interface, and copy the private and public key out of it.
Then delete it.
rplant
Long time Member
Long time Member
Fri Sep 11, 2020 2:46 am
Wireguard implementation seems to have gone pretty smoothly.
I don't suppose a backport to V6 is possible :)
rplant
Long time Member
Long time Member
Fri Sep 11, 2020 9:01 am
One issue with wireguard.
Sometimes It doesn't seem to keep its connection mark on output
The input to wg is coming in with a connection mark, but the output sometimes has
no connection mark.
Actually, on further review, its only when the output needs to go via a non default route.
(route marking needed), and also happens with Openvpn (and perhaps others)
sstp (tcp) using the same connection and route marking works correctly.
cihancan
Fri Sep 11, 2020 10:35 pm
Ive asked in the forums before updating to V7. One of the supports said it wont harm your device. I did it and it bricked my device. Thanks and sadly i will need to buy another retarded mikrotik device because its my only option. Plus LDF-5 doesnt work in net install mode my computer doesnt recognize it. Sad...
pe1chl
Fri Sep 11, 2020 11:05 pm
Users claiming netinstall doesn't work normally have made a mistake. It is not wise to try netinstall first on a device that already is in trouble, as when you tried it on a working device you would have found it is usually finicky.
You have to get the feel of it, and of course you have to have all the necessary preconditions present.
When you do it all correctly, it will also work on your dead LDF 5.
nostromog
Sat Sep 12, 2020 3:20 pm
Follow the manual until you arrive to configure netbooting. Then ignore what the image days (192.168.88.3) and set instead 192.168.88.1.
Then it will work.
Enviado desde mi Redmi Note 5 mediante Tapatalk
sapphire112
Sat Sep 12, 2020 11:43 pm
downgrade V7.1 beta2 impossible to downgrade Mikrotik chateau LTE12 stable version 6.47.3 no working Need help
sindy
Sun Sep 13, 2020 4:22 pm
Any change on the wireguard interface changes the mtu to 1420.
[me@chr-7-1] > interface/wireguard/print
 0 name="wg-0" mtu=1500 listen-port=5555 private-key="CE8v6Js/u5gw4qyIvVbY0idQ7fu4dArDK2dwDz4q33c=" public-key="Mrm8SbfGOmEnIUfmWrI+YBRV8fClymdgaceY+EjHqhY="
[me@chr-7-1] > interface/wireguard/set [find name=wg-0] name=wg-1
 0 name="wg-1" mtu=1420 listen-port=5555 private-key="CE8v6Js/u5gw4qyIvVbY0idQ7fu4dArDK2dwDz4q33c=" public-key="Mrm8SbfGOmEnIUfmWrI+YBRV8fClymdgaceY+EjHqhY="
santyx32
Sun Sep 13, 2020 4:24 pm
The device was launched with 7.X out of the box, you can't go lower than that
sapphire112
Sun Sep 13, 2020 6:43 pm
thank
to select the external antenna the menu which I must select both div main! ::
Shizumi
Sun Sep 13, 2020 9:44 pm
Currently I have:
/interface wireless
Can confirm the DHCP issue on RB4011iGS+5HacQ2HnD-IN, though I've only had it happen with one laptop (AC 9560, Arch Linux: linux 5.8.7.arch1-1 networkmanager 1.26.2-1). I was initially reluctant to blame RouterOS since I do tinker with a lot of experimental stuff (and the network card allegedly sometimes has issues with BT, got a new BT mouse recently, etc.), and all other devices seemed to operate normally, but after finally spending a few hours troubleshooting this I have to assume it's the router. RouterOS log only shows the client connecting and disconnecting. Linux/networkmanager log shows a DHCP timeout, which will (by default) make it disconnect after 45s and try reconnecting again. I noticed a DHCP lease does exist for the MAC address.
It isn't very consistent though, 7.1b2 worked normally at first, then the issue would occasionally kill the connection, but would be successfully reestablished after a few reconnects. It gets worse over time, from 1-2 times per day to every few minutes, until DHCP would fail every single time (no clear indication why). All other devices I checked worked normally at the time. Router restart fixes the issue temporarily.
Everything worked fine with 7.0 (I think b5, pretty sure I didn't test out 7.0b7 onwards with the new kernel).
gzgenm
Mon Sep 14, 2020 12:48 am
Can't make ptp ospf work with mikrotik running 6.47
Chupaka
Mon Sep 14, 2020 10:22 pm
I have ospf working over L2TP and SSTP, but there's some (visual?) weirdness in /ip routes with dynamic routes...
mrz
Tue Sep 15, 2020 10:00 am
What kind of weirdness? Known issue is that ospf route can appear twice in routing table.
2be
Tue Sep 15, 2020 10:37 am
Hello guys,
Could you please tell me, how can I set gateway value to the specific interface for incoming BGP filter?
/routing/filter/rule/add action=accept chain=bgp_in set-in-nexthop-direct=gateway1
doesn't seem to work. Perhaps set-in-nexthop-direct isn't implemented yet in ROS 7?
Is there any workaround for this?
Chupaka
Tue Sep 15, 2020 3:56 pm
Exactly: viewtopic.php?p=812440#p812440
Fopwoc
Tue Sep 15, 2020 11:28 pm
my router was hacked on this beta version!
Ip of the malware from Hong Kong
Jotne
Tue Sep 15, 2020 11:31 pm
I guess you have opened the admin (web/winbox/ssh or other) from internet.
Do you use VPN or secure your ruter better.
Chupaka
Wed Sep 16, 2020 12:03 am
Any details?
4903000
Thu Sep 17, 2020 4:56 am
Consider IPv6 NAT function please!
In my network enviroment I use 6in4 tunnel to access IPv6 resource ,It's just provide only one IPv6 address,so I need IPv6 NAT(ip6tables) to masquerade private IPv6 address.
Thanks!
spaxton
Thu Sep 17, 2020 10:26 am
I didn't install this version but I would like to ask if there will be any FTTH GPON settings parameters in this version..? Means that if I insert a GPON L2 SFP like Huawei HPSP2120, will there be any settings in mikrotik to add like LOID, password, PON serial...?
Best Regards.
xayide
Fri Sep 18, 2020 4:26 pm
Can you get 1Gbps wireguard throughput on any of the mikrotik devices at this time?
Paternot
Fri Sep 18, 2020 7:33 pm
They posted a print with one hAP AC2 doing 700 Mbps. Given the CPU used by the RB4011, with also 4 cores and much higher processing power, I'd say yes.
xayide
Fri Sep 18, 2020 9:18 pm
Thats a dream coming true. Getting away from the monster high frequency Intel Xeon (running openvpn at 700Mbps and now wireguard at 1Gbps, which is no problem) down to a single small router with poe and 1 gbps of protected internet....Just move all servers over to a tiny intel nuc to, if one can do with mikrotik I will not even need dual NIC or 2,5gbps to do full duplex firewalling at 1gbps. This is awesome!
sku
Sat Sep 19, 2020 11:35 am
I just setup Wireguard on my hAP AC² to replace the IPSEC tunnel I had before and am seeing around ~ 230 Mbit/s with max overclocked CPU on it. Would be nice to squeeze out a little bit more. Here is the CPU load while it's running and I have fasttrack disabled.
Thanks to Mikrotik for Wireguard in the first place it's an amazing addition.
I can also confirm that 2,4 GHZ Wifi is broken and client's don't get dhcp on that one, 5 GHZ seems to work fine.
nostromog
Sun Sep 20, 2020 1:09 pm
For me it works... until it stops working. Then I do
/interface/wireless { disable wlan1; enable wlan1}
ant it works again... until it stops working again, in a few hours.
14459278
Sun Sep 20, 2020 10:24 pm
System>Resources> CPU & CPU frequency not showing on RouterOS v7 BETA... Its problem???
anthonws
Mon Sep 21, 2020 8:10 am
+1 quite unstable WiFi connection. Devices don't get DHCP. Had to force static lease for my Android phone, otherwise it would never connect... Same thing happens with my iPad.
ksteink
Mon Sep 21, 2020 6:03 pm
Any dates to get the Stable Release? I like to not continue using 6.xx and already push to get 7.xx
nemoforum
Mon Sep 21, 2020 10:42 pm
RouterOS version 7.1beta2 has been released in public "development" channel!
Can also confirm a DHCP issues on hAP ac2: wireless clients time to time are unable to get IP address and reconnect in a loop.
WLAN interface disabling/enabling temporary "fix" the problem.
pe1chl
Mon Sep 21, 2020 10:54 pm
There are still so many small issues (and likely some big ones) that it would be foolish to promote it to "stable" anytime soon!
And of course it would have to go via "testing" anyway.
Paternot
Mon Sep 21, 2020 11:41 pm
All true. But sometimes I start thinking about it. No idea when it will be released, but I hope it will be before june 2021. One can always dream... :D
NAB
Trainer
Trainer
Thu Sep 24, 2020 5:29 pm
I can confirm that WireGuard 'just works'. Did a lab configuration and it was fine, so reconfigured the office anonymous VPN with our preferred supplier (https://vpn.ac/) who we have no hesitation in recommending, and that just worked too.
Can't wait for a proper 'stable' release of ROS7 now so we can start replacing various L2TP/IPSec and other VPNs across our entire customer base. Shame we lost that huuuuuuuuge potential customer some time ago though :-(
Thank you for WireGuard, Mikrotik.
I have several issues with v7 though....
* I'm not bothered about only being able to specify the WireGuard port from the command line, but I do get annoyed by having to reset the endpoint from the command line after I change something else in the peer definition.
* The packet sniffer doesn't show source and destination IPs in its live packet log (this actually stopped working at some point in v6).
* The drop-down route/interface box has gone when you create a route - now you have to type interface names in rather than just select them.
Znevna
Fri Sep 25, 2020 10:41 am
THANKS.
Flags: R - RUNNING
Running! ^^
Wanted to write about this earlier but forgot.
Things are half working.
The only way I managed to keep the tunnel running and alive was to leave keep-alive set on the 6.46.x end and leave it off on the 7.1b2 end, but also had to set a netwatch on 7.1b2 to ping the 6.46.x end every 10 seconds. Or else the tunnel goes down (the 6.46.x end stops running).
Weird.
pe1chl
Fri Sep 25, 2020 11:39 am
That is likely due to an unrelated issue, e.g. there is a NAT router somewhere inbetween or you use connection-tracking and not enough rules to be able to open the connection from both ends.
In such a situation the tunnel will fail when there is no traffic for more than the timeout of the connection tracking.
Znevna
Fri Sep 25, 2020 12:01 pm
Excluded, same config works fine without "workarounds" between 6.46.x versions.
Without the netwatch set in 7.1b2, the end from 6.46 fails after the keepalive timeout (10,3 = it stops running after 30 sec.) nothing to do with conntrack.
mafiosa
Fri Sep 25, 2020 6:01 pm
One year since v7 came into existence yet it is till in BETA. Hope to see RC by next year.
scampbell
Trainer
Trainer
Sun Sep 27, 2020 11:46 pm
@Paternot
I 4 1 do NOT believe that It will do routing at wire-speed ... why I do not believe that .... because for L3 wire-speed requires an ASIC and non of the hardware specs I see have that L3 ASIC in the gear. Yes there will be an improvement in performance but nowhere near wire-speed.
https://i.mt.lv/cdn/product_files/CRS32 ... 200149.png
Are you sure that mention switchip doesn't have that feature?
https://www.marvell.com/content/dam/mar ... 016-12.pdf
NAB
Trainer
Trainer
Mon Sep 28, 2020 5:33 pm
I appear to have found a problem with WireGuard.
From a x86_64 build, I can connect successfully to a Hap AC Lite, a Debian box and various VPN providers.
Unfortunately, when I try to bring up a connection to a CCR1009-8G=1S=1S+ (tile) box, the CCR crashes with a kernel failure.
I then tried to do a sup-output on the CCR, but that got to 8% and then did nothing more.
NAB
Trainer
Trainer
Mon Sep 28, 2020 5:37 pm
Update - after around half an hour, it jumped to 100% and finished!
pe1chl
Mon Sep 28, 2020 5:46 pm
That is "normal", also for 6.47 versions. It does not always take half an hour but it can take considerable time, being stuck at 7 or 8%.
NAB
Trainer
Trainer
Mon Sep 28, 2020 7:49 pm
:-) That shows how long it is since I've needed to generate one then!
anuser
Long time Member
Long time Member
Wed Sep 30, 2020 11:49 am
When can we expect the next v7 beta release?
Paternot
Wed Sep 30, 2020 1:49 pm
When it's ready!
Sorry, couldn't resist. I thought it would be released last friday, but...
msatter
Wed Sep 30, 2020 1:52 pm
Friday is not a good day being the start of the Mikrotik weekend.
Paternot
Wed Sep 30, 2020 2:06 pm
But they ARE releasing it on fridays. At least the last 2 or 3 releases where on a friday. Yes, yes. I know: joking and all that. :D
pe1chl
Wed Sep 30, 2020 2:28 pm
That is correct, unless there is some urgent fix the new releases are normally on friday at the end of their business hours....
Good strategy, it prevents a lot of phonecalls etc.
Chupaka
Wed Sep 30, 2020 5:37 pm
Yeah, at least you can evaluate the scale of disaster by Monday, not jumping into every small reported bug right after the release :)
pe1chl
Wed Sep 30, 2020 5:58 pm
Also lots of users would probably tend to call or file bugreports immediately when it was during the workweek, while in the weekend they know there will be no immediate response and they first study the matter a bit more, and find the solution themselves...
Paternot
Wed Sep 30, 2020 6:43 pm
To be honest, no one should jump the gun e install a new release into production. Well, there are exceptions, but...
Even (especially) if You don't have a lab to test: Wait and let the others do this for You.
mkx
Wed Sep 30, 2020 8:50 pm
Guys, stop telling everybody that they should wait for other people do testing of new release. If you do it long enough, nobody will test new release.
BTW, anybody installing beta version (the thread is about v7.1beta) in any approximation of production environment is living on the cutting edge and deserves whatever hits him/her.
Paternot
Wed Sep 30, 2020 9:43 pm
LOLing here. :D
SiB
Thu Oct 01, 2020 1:49 am
mkx
but people with Chateau not have a way to go back to ros v6 bcs mtk give them only Ros7 and no way of installing v6 (except v6.99.x :p ).
mafiosa
Thu Oct 01, 2020 11:15 am
Lets hope to see 7.1 b3 or porbably 7.1 rc tomorrow xD
huntermic
Thu Oct 01, 2020 11:56 am
Don't expect rc in for long time, they first need to include all functionality and have that tested for some time.
Probably won't see a rc version this year.
I would be surprised to see a stable version 7 next year.
mafiosa
Thu Oct 01, 2020 12:09 pm
it is already 13 months since first beta was out.
huntermic
Thu Oct 01, 2020 12:12 pm
Point being?
Eliot
Thu Oct 01, 2020 12:47 pm
Can't wait the stable one
santyx32
Thu Oct 01, 2020 2:28 pm
Looks like Mikrotik knows how to treat their employees, other companies would have rushed to push V7 into production as soon as possible.
bruins0437
Thu Oct 01, 2020 3:38 pm
Can't rush perfection! :) Glad they are taking their time to get it right.
mkx
Thu Oct 01, 2020 4:35 pm
mkx
My condolences go to victims of MT ;-)
mafiosa
Thu Oct 01, 2020 11:08 pm
Chupaka
Fri Oct 02, 2020 1:57 pm
https://help.mikrotik.com/docs/display/ ... col+Status
seems like beta3 is almost there.
Check "Page history". Those changes are one month old :)
Mikuser17
Fri Oct 02, 2020 2:55 pm
Installed beta 2 on a cap ac unit
The device was setup doing NAT and running Capsman.
CAP interfaces seemed ok but dhcp clients didn't receive an IP
After some time the CAP interfaces started disapearing in the interfaces list.
After 2 hours uptime alle interfaces including ether1 & ether2 were gone from the interfaces list.
15 min later I was unable to connect to the unit using web/ssh/winbox.
KR
bruins0437
Fri Oct 02, 2020 4:04 pm
Maybe next week haha
picnicsecurity
Sat Oct 03, 2020 2:36 pm
Any update on VTI support?
viewtopic.php?t=65734
madejson
Wed Oct 07, 2020 9:16 am
Also confirm DHCP Issue on 3 devices, two hAP ac2 and 962UiGS-5HacT2HnT. Even disabling/enabling wlan1 interface don't work for me. Removing host from DHCP server leases working, but not in whole situations.
Additionaly I registered rebooting and not saving settings for ethernet speed settings. I'm trying to disable autonegotiation and set speed manually, after confirm RB reboting and settings doesnt change.
Is someone have this same issue?
regards
mafiosa
Thu Oct 08, 2020 8:12 am
Also confirm DHCP Issue on 3 devices, two hAP ac2 and 962UiGS-5HacT2HnT. Even disabling/enabling wlan1 interface don't work for me. Removing host from DHCP server leases working, but not in whole situations. Even if I set dhcp pool like 192.168.20.* i'm receiving from DHCP server ip's from 192.168.88.*, gateway 192.168.88.1. I have to set manually IP from my network, then working ok.
regards
I faced the same issue so reverted back to stable. This is a very basic thing that should be working.
BartoszP
Thu Oct 08, 2020 8:43 am
@mafiosa
Is it a problem to press "Post reply" button to comment preceeding post instead of quoting it as a whole just to write few words?
Do you think that people are unable to follow the thread?
notToNew
Thu Oct 08, 2020 8:51 am
What is the problem? It is just efficient and the forum Software shortens the text anyway. Instead of hist post, your post actually has nothing to add to the thread.
Why you think someone should read this value-less Post?
BartoszP
Thu Oct 08, 2020 8:58 am
You are asking right ... What is the problem to press "Post reply" instead of "Quote"? It is just a different button.
If I see a quote I wonder if poster has joined some replies or just quoted whole previous post so I have to check it.
Don't you think it is unneeded waste of time?
notToNew
Thu Oct 08, 2020 9:07 am
Don't you think it is unneeded a waste of time?
No, Not at all. I am much faster in understanding his point an have no need in ycrolling up and reading the last messages to understand.
It is just efficient!
eworm
Thu Oct 08, 2020 9:29 am
Right you are. But it is important to shorten the quote to what you actually intend to quote, just as we both did.
Quoting a post including a quote, including a quote, including a quote .... does not add mutch value.
So I am all for quotes if done right.
Guntis
Thu Oct 08, 2020 2:30 pm
m0x35, kylepharo, nostromog, Shizumi, sku, anthonws if you have issues with clients connecting to wlan and acquiring addresses from DHCP server, please write to support@mikrotik.com or contact us via our support portal https://help.mikrotik.com/servicedesk
In support ticket, please describe issue in detail, your network setup and create supout.rif file once issue is present and share it with us. Thank you for reporting the issue.
nostromog
Thu Oct 08, 2020 4:37 pm
(...) nostromog (...) please write to support@mikrotik.com or contact us via our support portal https://help.mikrotik.com/servicedesk In support ticket, please describe issue in detail, your network setup and create supout.rif file once issue is present and share it with us. Thank you for reporting the issue.
I can't because I had to go to stable in the only machine it had this problem (hAP ac^2). The rest of the machines I have running 7.1betas (no ARM, all one-core MIPSBE) are doing ok, so I guess it is either architecture dependent or dependent on number of cores, configuration, history of installs/configuration, or a mixture of those.
But you have enough people having the same problem.
dalami
Fri Oct 09, 2020 2:22 am
Has anyone been able to restore normal/stable wifi operation on this beta? I loaded it on my home router for Wireguard - wifi is now useless. Fortunately I have a secondary wifi AP available.
dalami
Fri Oct 09, 2020 2:38 am
At least for the past few minutes - after performing a "/interface wireless reset-configuration" for both 2G and 5G, and then setting the channel widths back to 20/40XX and 20/40/80XXXX, things seem to be working. We'll see if it stays that way for a while. Based on some other inconsistencies I'm guessing/hoping there's some issues with upgrading that might not exist in "clean" installs of 7.1b2.
manbot
Fri Oct 09, 2020 5:04 pm
Hello everyone!
Have installed latest ROS7.1beta2 on CCR1009-7G-1C-1S+
Wireguard is not working on TILE architecture devices: can't point port on endpoint for PEER not from Winbox (as expected - was in thread earlier)not from console (Winbox terminal)
Suggestion, on my point of view - wait for next version.
Or, any advices from other "lucky" TILE device owners :)
madejson
Sat Oct 10, 2020 1:09 pm
Is someone prepared tickets with mentioned wifi issue? I'm not so experienced as most of you so basing on my konwledge could be wrong. I hope that new release will have fixes for all problems discussed here.
Other thing: should we register tickets for every single issue mentioned here?
Regards
izytech
Tue Oct 13, 2020 9:45 am
It would be really great if statistics for outgoing hardware queues could be visible in cli, winbox and snmp. For most of the CRS3xx switches the chipset have 8 hw output queues. But we cant see any stats for them.
It would also be very nice to have a ratelimiter per outgoing qos queue but thats a nice to have only.
lucim101
Thu Oct 15, 2020 9:17 pm
OVPN over UDP works great for me on CHR
I did notice when I try to add a routing mark I cant type any New Routeing Mark , It only have one option and that is to choose main,
lucim101
Thu Oct 15, 2020 9:23 pm
Hello!
Just upgraded to v7.1b2 and spotted a few issues:
First and most important is routing marks don't work
The second one is about wireguard. Why I can't specify the port number for peer? Is it intended or a bug as well?
The Routing Marks it a bummer, basically the only thing holding me back to do some proper testing on OVPN UDP
osc86
Fri Oct 16, 2020 2:04 pm
We know that DHCP doesn't work in the current beta (for wireless clients), but for me the wireless interfaces are not passing any kind of traffic. Even if I use a static ip address / DNS / Gateway on a wireless device, it can't connect to any host on the network or the internet. The traffic is bridged out locally.
I can't find an error in my configuration.
Is it working for anyone?
mrz
Fri Oct 16, 2020 2:10 pm
Probably this will help you to set up routing tables:
https://help.mikrotik.com/docs/display/ ... icyRouting
dgnevans
Fri Oct 16, 2020 4:14 pm
I put on a test unit. RB951G-2HnD
Testing OSPF. wanted to add a filter if you click routing then filter nothing appears in Winbox.
Under OSPF Instances if you try to choose Ou-Filter Winbox will close.
mrz
Fri Oct 16, 2020 5:05 pm
From v7 changelog:
-) Winbox does not show all features, use CLI for most functionality
matlib
Fri Oct 16, 2020 9:51 pm
Hey all,
someone with Chateau 12LTE who was able to get properly working with SIM card?
Modem is very unstable and connection after a while drops.
dalami
Fri Oct 16, 2020 11:01 pm
I just had my hAP AC2 powered down for a period (about 12 hours) - and on turning it back on I found it...wiped. Totally reset to default including wiping the file storage...where I had stored a couple backup configs. And being brilliant as usual I hadn't downloaded them for safekeeping.
Given that this is my home router re-configuring wasn't that big a deal. But...dunno if this has been seen by anyone else or not. I don't *think* I pushed anything for reset purposes during the startup, and I don't *think* anybody else fiddled with the equipment last night.
On the positive side - this theoretically means I'm starting with a clean QuickSet config for Home Dual AP so things *should* be setup optimally...right?
Daniel
xvo
Fri Oct 16, 2020 11:35 pm
Are you sure they were in /flash folder, not in the root directory that is mounted to RAM?
dalami
Sat Oct 17, 2020 12:16 am
I learned something new again. Thanks! Yes - I'm sure the backup files were in the root level - though they were there previously during other reboots.
pe1chl
Sat Oct 17, 2020 10:52 am
It is normal that you lose all the files stored in the filesystem and not in the flash directory (and you should not keep a stash of backups there because it fill fill up the small flash space available).
However, it is NOT normal that the unit comes back with all the settings set to defaults. Settings should be always saved in flash.
sapphire112
Re: v7.1beta2 [développement] est libéré!
Sun Oct 18, 2020 1:31 am
Hey all,
I have the same problem the C.A falls quickly
SiB
Tue Oct 20, 2020 4:42 pm
sapphire112
Long story short:
sdegler
Wed Oct 21, 2020 4:28 am
Hey I do aspects of the Datacenter world in my day job. HW enabled wirespeed L3 routing on a single ASIC is pretty standard fare in that world, and has been so for some time. However, I wouldn't look for policy based routes, full internet routing tables, smart queues, complex firewall filtering, or anything like that. So its a mixed blessing, and many datacenter network software failure scenarios center on the disparities between the capabilities of the asic and the cpu, which are basically the only two chips on a top of rack or spine switch. Its relatively easy to overwhelm the CPU and the usually PCIE interface to it from the asic. This is why there is so much todo about "control plane policing" COPP with these devices. A few million pps means nothing to the asic but a fraction of it will melt the CPU if its control plane traffic like spanning tree and routing protocol updates.
However you are correct in that only a few vendors provide routers that can forward millions of pps with arbitrarily complex routing policy and flow based shaping and analysis.
I am familiar with how CISCO does in on their MLS devices. Typically for wire-speed routing in the Cisco Switch world Cisco requires three entities to implement multilayer switching: the switching engine (SE), the route processor (RP), and the MLS protocol. The SE performs the switching function, the RP performs the routing function, and the MLS protocol provides for communication between these two devices. This aside, there is one very simple concept that makes it all possible: the flow. A flow can be defined as a stream of packets from the same source to the same destination using the same application. As an example, a flow could be an HTTP session between a source browser and a target server. In a Cisco MLS network, the initial packet in a session is routed via the RP, but all subsequent packets in that particular session are switched by the SE. The SE maintains a cache about these flows and can determine whether or not a given packet is part of an established session. If so, the SE rewrites the pertinent packet info as if it had been processed by the router and then switches the packet. This process is commonly referred to as “route once, switch many.” It occurs at switch speed, not at the slower router speed.
So in terms of MikroTik and RouterOS I do not see ANY functionality that mimics or deals with wire-speed Routing at the switch level.
dgnevans
Wed Oct 21, 2020 9:18 am
On OSPF, I have mutiple vlans o nmy router. if their are other routers or devices using OSPF on the vlan then the VLAN is advertised to the other routers if not the vlan is omitted from the other routers. as a result have to setup static routes.
It appears to not redistribute the connected routes as it is not seeing them as active.
So have managed to get it to work.
What I had to do was add all my Vlans to one Area. lets say default 0.0.0.0
Before I was able to have default where all my routers connected to each other ie on a backbone vlan and then have an area with different area id for vlans not facing the backbone that are behind the router. now I had to add them all to the same area as temp work around. I think there are some bugs in OSPF. sure they will be resolved in upcoming version.
bruins0437
Thu Oct 22, 2020 4:17 pm
I think I am suffering from beta withdrawals. Lol
0xid0
Thu Oct 22, 2020 4:30 pm
This beta has a lot of bugs in ac2. Is there any way to downgrade to 6.48 but keeping configuration?
pe1chl
Thu Oct 22, 2020 5:16 pm
You can force a downgrade and then restore the backup you made before you installed the beta (you made a backup, right?).
Or you could make an export of the currently running version and keep that as a guide (download it to a PC and open it in notepad)
when configuring a 6.x version after you have reset it to defaults.
Most paragraphs from the export can probably still be cut/paste into a telnet to the router.
It is the usual somewhat-laborious work of transferrring a config to another router, that is not streamlined well in MikroTik.
mafiosa
Fri Oct 23, 2020 2:19 am
Can we expect the next beta version today as it is a Friday and over 2 months since the last beta release?
mkx
Fri Oct 23, 2020 8:56 am
We've got 6.47.6 yesterday. And it wasn't even Friday. I think that's enough for this weekend ;-)
torstorm
Sat Oct 24, 2020 3:21 pm
micro SDCARD is not yet supported? Tile-Gx OHCI is not listed in usb resources...
nellson
Mon Oct 26, 2020 11:56 am
Hello Folks
We are running routeros v7.1beta2 on a RBD53G-5HacD2HnD (Chateau LTE12), and have experienced some instability, all we can see when it happens, is one log entry:
I am not entirely sure, but I think we can provoke it, by changing port speed on an interface ex. to "100 half duplex" and back to "auto negotiate".
How can I help the developers debug this, in a meaningful way.
Update:
We can replicate this behaviour 100% of the times, when we are changing port speed on an interface.
pe1chl
Mon Oct 26, 2020 12:26 pm
While of course a router should not crash under these circumstances, this is a setting that you normally should not touch. It does not work like most people think it would!
When you want to control the speed/duplex, keep the "auto negotiate" setting but remove the "Advertise" checkmarks for the modes you do not want it to choose.
SiB
Mon Oct 26, 2020 12:30 pm
nellson
Update:
Write directly to support@mikrotik.com or create a case by https://help.mikrotik.com/servicedesk
Attach the last supout.rif, check if autosupout.rif not generate automatically on crash ?
nellson
Mon Oct 26, 2020 1:20 pm
Thank you for your quick the responses.
I have systematically tried changing every possible speed and or duplex setting, it does not matter, the router crashes and reboots.
It will send in the suggested support files to mikrotik support.
nellson
Mon Oct 26, 2020 1:28 pm
Here is a workaround, for those who need might need it before a fix is committed, you can set the advertised port speed and duplex setting via the console, then the router does not crash.
Update:
Settings will not be reflected in winbox, only on the console, but it works!
rooneybuk
Mon Oct 26, 2020 2:49 pm
anyone tried configuring BGP in ROS7.1beta2 I would love to see some examples :)
MoNsTeRRR
Tue Oct 27, 2020 2:48 am
There is a full example in the doc https://help.mikrotik.com/docs/display/ ... figuration
mafiosa
Wed Oct 28, 2020 11:51 am
yes me too especially with filters. Also it's been 2 months since last beta release.
rooneybuk
Wed Oct 28, 2020 12:05 pm
Thanks just want i needed :)
McSee
Thu Oct 29, 2020 2:27 am
Fasttrack doesn't work for me in 7.1beta2 on Chateau. It's shown as active in IP Settings, but counters there and in dummy rules in Firewall are all zeros.
Config is pretty basic and fasttrack works with the same config in 7.1beta1.
Edit: Also doesn't work with default config in 7.1beta2 and works in 7.1beta1.
nellson
Thu Oct 29, 2020 1:07 pm
I am seeing the same behaviour on 7.1beta2, the fasttrack counters are indeed not working.
nellson
Thu Oct 29, 2020 1:16 pm
We are also experiencing unstable WiFi in version 7.1beta2 on a RBD53G-5HacD2HnD, clients are not able to receive a DHCP offer on 2G, not sure if 5G is affected though.
nemoforum
Thu Oct 29, 2020 4:16 pm
It seems wi-fi issue has been fixed in 7.1beta3. Running it for a week without any issues.
PS: not yet available for everyone.
SiB
Thu Oct 29, 2020 5:09 pm
We still wait for it bcs ppl have two other big problems: Both work's properly in ros7beta5
mafiosa
Fri Oct 30, 2020 3:32 pm
Beta 3? How did you get it?
Miklan
Fri Oct 30, 2020 6:45 pm
In v7.1beta2 I can't manage to import a private SSH key which is password-protected :
[admin@MikroTik] > /user ssh-keys private import user=admin private-key-file=test.key
passphrase: *******
unable to load key file (incorrect passphrase?) !
Of course no issue at all on v6.x with the exact same key.
Is there a known issue MikroTik support ?
Thank you !
mafiosa
Fri Nov 06, 2020 9:06 am
3 months yet next beta is not yet released! waiting for next release that would mitigate the wifi dhcp lease issue on hap ac2
floaty
Fri Nov 06, 2020 9:33 am
just because already chocolate-santa's awaiting you in the local supermarket, it doesn't mean christmas eve has broken !
... maybe it's a little bit about timing ?! guess your impatient question shows mom and dad they're do'in fine : )
matlib
Tue Nov 10, 2020 12:44 pm
Hey,
is there anyone who owns a Chateau LTE12 and is able to use LTE mode only?
Currently I'm able to connect to internet only using 3G mode.
I'm in contact via Mikrotik support and I'd like to know if someone else is experiencing the same problem.
SiB
Tue Nov 10, 2020 12:52 pm
matlib
And that's why you write here instead of creating new thread, sorry but this is not a place to speak about APN AT Commands and Log's changes in LTE.
LSan83
Tue Nov 10, 2020 12:54 pm
Hey,
Here i am! I always use LTE mode only on Chateau LTE12 (and before on WAP LTE and LHG LTE too). It works well with all 3CA combination (provider 3 Italy, now Wind3)
pe1chl
Tue Nov 10, 2020 12:55 pm
It appears they again went "under water" with the v7 beta. There is mention of a 7.1beta3 that apparently some people have, and which is mentioned in the feature completeness table on the help site, but which has not been released to the public.
It is a bit unfortunate, because I really would like to test some things and could do so on some routers, but the 7.1beta2 is not good enough for that.
emils
Forum Veteran
Forum Veteran
Tue Nov 10, 2020 1:49 pm
Currently we are having issues with beta3 booting on TILE architecture. Beta3 will be available when we get these issues sorted out.
pe1chl
Tue Nov 10, 2020 2:16 pm
It would be welcome when you release new v7 betas quickly even if they are only for single architecture, e.g. only for CHR.
That at least enables some testing and evaluation. Getting them to work on all devices is something that can trail after that.
r00t
Long time Member
Long time Member
Tue Nov 10, 2020 3:05 pm
Yes. Don't block the release just because one platform can't boot. It's still in BETA stage so such things can be expected to happen. Release it so new features can be tested and debugged while you are working on the TILE to boot again.
