JayK4190
Backup Dude
Fri Apr 14, 2023 9:12 pm
We have the Dude running on a windows PC and want to back it up in case of Pc failure. How do I go about backing it up so I can restore it later?
bpwl
Re: Backup Dude
Fri Apr 14, 2023 10:51 pm
In terminal (CLI) ....
DUDE
dude export
dude export-db
dude import-db
JayK4190
Re: Backup Dude
Fri Apr 14, 2023 11:56 pm
So, i went to the windows command prompt, went to the dude folder and ran the command you said. It flashed the screen but I'm not sure if it backup up anything and if so, where did it place it? Very new to the Dude and all of this.
bpwl
Re: Backup Dude
Sat Apr 15, 2023 5:24 pm
It is in Routeros terminal.
" Dude > export ?
" dude > export file=flash/myfilename"
"Dude > export_db=flash/mydbfilename"
RouterOS terminal via SSH , WinBox or browser ... to RouterOS device or VM (CHR) with DUDE server. (It is not in the DUDE client on the PC !)
.E.G. browser.
stmx38
Long time Member
Long time Member
Re: Backup Dude
Mon Apr 17, 2023 8:02 pm
You mean that you run Dude v3/v4 server on Windows? Can you please specify your Dude version.
JayK4190
Re: Backup Dude
Mon Apr 17, 2023 8:51 pm
We are running Dude version 6.45.8 on a Windows 7 PC.
stmx38
Long time Member
Long time Member
Re: Backup Dude
Wed Apr 19, 2023 9:37 pm
It means that you are running Dude v6 Server on ROS and Dude v6 Client on Windows 7 PC - Manual:The Dude v6/Installation.
And solution posted above is right for your case.
For more automated way, you may consider to look at Dude v6 - Backup locally and Dude v6 - Backup to FTP.
