PackElend
how to use SIM slot in CCR1009-7G-1C-1S+
Thu Feb 15, 2024 9:16 pm
Is anyone around who is using a SIM in the CCR1009-7G-1C-1S+?
I have just put in standard SIM, which worked well in my phone, in the SIM slot but nothing happens.
Its specification says:
Number of SIM slots 1 Smart card (Mini SIM)
but Interface in SMS or LTE Scanner shows unknown.
So what to do?
viewtopic.php?t=177260 reads not that good...
do I need extra hardware?
like mentioned in
viewtopic.php?t=109531
viewtopic.php?t=159520
viewtopic.php?t=187791
JohnTRIVOLTA
Re: how to use SIM slot in CCR1009-7G-1C-1S+  [SOLVED]
Thu Feb 15, 2024 9:38 pm
With usb 3/4/5G modem! The router have sd slot and smart card slot only!
PackElend
Thu Feb 15, 2024 10:14 pm
Wow that was a quick answer 😀, so the smart cart slot can read smart cards which have the shape of a mini SIM?
So the description is bit misleading...
Anyway, so I need a usb modem and an adapter for mini usb
By the way, what is a smart cart used for in a ccr?
JohnTRIVOLTA
Thu Feb 15, 2024 11:26 pm
Projects that have been abandoned by mikrotik, such as vpn tunnel crypto keys, etc.
PackElend
Fri Feb 16, 2024 11:20 am
thanks for the information
patrikg
Fri Feb 16, 2024 2:25 pm
Now you can press this bar to mark your thread as solved.
Users browsing this forum: No registered users and 2 guests
