the last days i played around with the settings and read a lot of configuration files.
and then reboot, im not able to login anymore over win-box with the mac address.... what makes sense, activating mac-winbox on LAN, deactivates it on WAN, what is grouped with the ether1 interface.
BUT the routeros management site is not reachable via IP, not from win-box and not from the browser.
I can reach two other lr8 in my network over IP (not found in neighbors but reachable), so it might not be a hardware issue somewhere in the network
In the configuration www is enabled and set on port 80.
What do i miss...
# feb/29/2024 21:23:16 by RouterOS 6.49.13
# software id = QJ7C-BMP8
# model = RBwAPR-2nD
# serial number = HDG08KSREEP
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto \
auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
full-duplex=yes l2mtu=1598 loop-protect=default \
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
48:A9:8A:0B:F1:0D mtu=1500 name=ether1 orig-mac-address=48:A9:8A:0B:F1:0D \
rx-flow-control=off speed=100Mbps tx-flow-control=off
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set [ find name=all ] comment="contains all interfaces" exclude="" include="" \
name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" \
name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" \
include="" name=dynamic
set [ find name=static ] comment="contains static interfaces" exclude="" \
include="" name=static
add comment=defconf exclude="" include="" name=WAN
add comment=defconf exclude="" include="" name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet \
default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=no \
eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m \
interim-update=0s management-protection=disabled mode=dynamic-keys \
mschapv2-username="" name=default radius-called-format=mac:ssid \
radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-sta-private-algo=none static-transmit-key=key-0 \
supplicant-identity=MikroTik tls-certificate=none tls-mode=\
no-certificates unicast-ciphers=aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
2 area="" arp=enabled arp-timeout=auto band=2ghz-b/g/n basic-rates-a/g=\
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz \
compression=no country=etsi default-ap-tx-limit=0 default-authentication=\
yes default-client-tx-limit=0 default-forwarding=yes \
disable-running-check=no disabled=no disconnect-timeout=3s distance=\
dynamic frame-lifetime=0 frequency=2412 frequency-mode=regulatory-domain \
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 installation=any \
interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 \
mac-address=48:A9:8A:0B:F1:0E max-station-count=2007 mode=station mtu=\
1500 multicast-buffering=enabled multicast-helper=default name=wlan1 \
noise-floor-threshold=default nv2-cell-radius=30 nv2-downlink-ratio=50 \
nv2-mode=dynamic-downlink nv2-noise-floor-offset=default nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" \
on-fail-retry-time=100ms preamble-mode=both radio-name=48A98A0BF10E \
rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default \
secondary-frequency="" security-profile=default skip-dfs-channels=\
disabled ssid=hofnetz station-bridge-clone-mac=00:00:00:00:00:00 \
station-roaming=disabled supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1 \
tx-power-mode=default update-stats-interval=disabled vlan-id=1 vlan-mode=\
no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
wds-ignore-ssid=no wds-mode=disabled wireless-protocol=any wmm-support=\
disabled wps-mode=push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:\
17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H\
T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-\
7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
flash/hotspot html-directory-override="" http-cookie-lifetime=3d \
http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" \
smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none \
!insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=\
default !parent-queue !queue-type shared-users=1 status-autorefresh=1m \
transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no use-responder-dns=\
exclusively
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m \
dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1 \
lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=\
aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=\
modp1024
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU \
up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US \
up-port=1700
add address=eu1.cloud.thethings.industries down-port=1700 name=\
"TTS Cloud (eu1)" up-port=1700
add address=nam1.cloud.thethings.industries down-port=1700 name=\
"TTS Cloud (nam1)" up-port=1700
add address=au1.cloud.thethings.industries down-port=1700 name=\
"TTS Cloud (au1)" up-port=1700
add address=eu1.cloud.thethings.network down-port=1700 name="TTN V3 (eu1)" \
up-port=1700
add address=nam1.cloud.thethings.network down-port=1700 name="TTN V3 (nam1)" \
up-port=1700
add address=au1.cloud.thethings.network down-port=1700 name="TTN V3 (au1)" \
up-port=1700
add address=188.34.161.37 down-port=1700 name=loralama up-port=1700
/ppp profile
set *0 address-list="" !bridge !bridge-horizon bridge-learning=default \
!bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server \
!idle-timeout !incoming-filter !insert-queue-before !interface-list \
!local-address name=default on-down="" on-up="" only-one=default \
!outgoing-filter !parent-queue !queue-type !rate-limit !remote-address \
!session-timeout use-compression=default use-encryption=default use-mpls=\
default use-upnp=default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon bridge-learning=default \
!local-address name=default-encryption on-down="" on-up="" only-one=\
default !outgoing-filter !parent-queue !queue-type !rate-limit \
!remote-address !session-timeout use-compression=default use-encryption=\
yes use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set wlan1 queue=wireless-default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id \
!confederation disabled=no ignore-as-path-len=no name=default out-filter=\
"" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=\
no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 \
routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id \
!domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 \
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 \
!mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
!routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5 disabled=\
no encryption-protocol=DES name=public read-access=yes security=none \
write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=flash/log disk-lines-per-file=1000 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=\
0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=\
bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
eb,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude" skin=\
default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
ssword,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude" skin=\
default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
winbox,password,web,sniff,sensitive,api,romon,tikapp,!dude" skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled \
mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path="" \
require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=no crl-store=ram crl-use=no
/interface bridge port-controller
# disabled
set bridge=none cascade-ports="" switch=none
/interface bridge port-extender
# disabled
set control-ports="" excluded-ports="" switch=none
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes \
tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=\
1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
udp-stream-timeout=3m udp-timeout=10s
set discover-interface-list=!dynamic lldp-med-net-policy-vlan=disabled \
protocol=cdp,lldp,mndp
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes \
arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes \
max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=\
yes send-redirects=yes tcp-syncookies=no
/interface detect-internet
set detect-interface-list=none internet-interface-list=none \
lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 \
caller-id-type=ip-address default-profile=default-encryption enabled=no \
keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited \
mrru=disabled one-session-per-host=no use-ipsec=no
add comment=defconf disabled=no interface=wlan1 list=LAN
add comment=defconf disabled=no interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=\
no keepalive-timeout=60 mac-address=FE:37:42:59:9F:30 max-mtu=1500 mode=\
ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 \
max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any \
verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" \
caps-man-names="" certificate=none discovery-interfaces="" enabled=no \
interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ip cloud
set ddns-enabled=no ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-client
add add-default-route=yes default-route-distance=1 dhcp-options=\
hostname,clientid disabled=no interface=wlan1 use-peer-dns=yes \
use-peer-ntp=yes
/ip dhcp-server config
set accounting=yes interim-update=0s store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
max-concurrent-queries=100 max-concurrent-tcp-sessions=20 \
max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s \
servers="" use-doh-server="" verify-doh-cert=no
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" \
disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=\
all src-address=::/0 template=yes
/ip ipsec settings
set accounting=yes interim-update=0s xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster \
cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no \
max-cache-object-size=2048KiB max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=::
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443 tls-version=any
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729 tls-version=any
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/flash/pub \
disabled=no max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set auth-method=none connection-idle-timeout=2m enabled=no max-connections=\
200 port=1080 version=4
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no \
host-key-size=2048 strong-crypto=no
/ip tftp settings
set max-block-size=4096
/ip traffic-flow
set active-flow-timeout=30m cache-entries=16k enabled=no \
inactive-flow-timeout=15s interfaces=all packet-sampling=no \
sampling-interval=0 sampling-space=0
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes \
dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes \
igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes \
ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=\
yes nat-dst-port=yes nat-events=no nat-src-address=yes nat-src-port=yes \
out-interface=yes packets=yes protocol=yes src-address=yes \
src-address-mask=yes src-mac-address=yes src-port=yes sys-init-time=yes \
tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes \
ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/lora
set 0 antenna=uFL antenna-gain=0dBi channel-plan=eu-868 disabled=no forward=\
crc-valid,crc-error gateway-id=50303541575D4750 lbt-enabled=no \
listen-time=5000us name=gateway-0 network=public rssi-threshold=-65dBm \
servers=loralama !src-address
/lora channels
set 0 bandwidth=125_kHz disabled=no freq-off=-400000 radio=radio1
set 1 bandwidth=125_kHz disabled=no freq-off=-200000 radio=radio1
set 2 bandwidth=125_kHz disabled=no freq-off=0 radio=radio1
set 3 bandwidth=125_kHz disabled=no freq-off=-400000 radio=radio0
set 4 bandwidth=125_kHz disabled=no freq-off=-200000 radio=radio0
set 5 bandwidth=125_kHz disabled=no freq-off=0 radio=radio0
set 6 bandwidth=125_kHz disabled=no freq-off=200000 radio=radio0
set 7 bandwidth=125_kHz disabled=no freq-off=400000 radio=radio0
set 8 bandwidth=250_kHz disabled=no freq-off=-200000 radio=radio1 \
spread-factor=SF7
set 9 bandwidth=125_kHz datarate=50000 disabled=no freq-off=300000 radio=\
radio1
/lora radios
set 0 center-freq=867500000 disabled=no rssi-off=-162 tx-enabled=yes \
tx-freq-max=870000000 tx-freq-min=863000000
set 1 center-freq=868500000 disabled=no rssi-off=-162 tx-enabled=no \
tx-freq-max=0 tx-freq-min=0
/lora tx-lut
set 0 dac-gain=3 dig-gain=0 disabled=no mix-gain=11 pa-gain=0 rf-power=-6
set 1 dac-gain=3 dig-gain=0 disabled=no mix-gain=13 pa-gain=0 rf-power=-3
set 2 dac-gain=3 dig-gain=0 disabled=no mix-gain=9 pa-gain=1 rf-power=0
set 3 dac-gain=3 dig-gain=0 disabled=no mix-gain=10 pa-gain=1 rf-power=3
set 4 dac-gain=3 dig-gain=0 disabled=no mix-gain=12 pa-gain=1 rf-power=6
set 5 dac-gain=3 dig-gain=0 disabled=no mix-gain=10 pa-gain=2 rf-power=10
set 6 dac-gain=3 dig-gain=0 disabled=no mix-gain=11 pa-gain=2 rf-power=11
set 7 dac-gain=3 dig-gain=0 disabled=no mix-gain=11 pa-gain=2 rf-power=12
set 8 dac-gain=3 dig-gain=2 disabled=no mix-gain=12 pa-gain=2 rf-power=13
set 9 dac-gain=3 dig-gain=0 disabled=no mix-gain=13 pa-gain=2 rf-power=14
set 10 dac-gain=3 dig-gain=0 disabled=no mix-gain=15 pa-gain=2 rf-power=16
set 11 dac-gain=3 dig-gain=0 disabled=no mix-gain=10 pa-gain=3 rf-power=20
set 12 dac-gain=3 dig-gain=0 disabled=no mix-gain=12 pa-gain=3 rf-power=23
set 13 dac-gain=3 dig-gain=0 disabled=no mix-gain=13 pa-gain=3 rf-power=25
set 14 dac-gain=3 dig-gain=0 disabled=no mix-gain=15 pa-gain=3 rf-power=26
set 15 dac-gain=3 dig-gain=0 disabled=no mix-gain=15 pa-gain=3 rf-power=27
/mpls
set allow-fast-path=yes dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no \
use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public \
trap-generators=temp-exception trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=Europe/Rome
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=wlan1 leds=user-led type=wireless-status
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system routerboard settings
set auto-upgrade=no boot-device=nand-if-fail-then-ethernet boot-protocol=\
bootp force-backup-booter=no protected-routerboot=disabled \
reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard reset-button
set enabled=no hold-time=0s..1m on-event=""
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes ping-start-after-boot=5m \
ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=all
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any \
filter-interface="" filter-ip-address="" filter-ip-protocol="" \
filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" \
filter-operator-between-entries=or filter-port="" filter-size="" \
filter-stream=no memory-limit=100KiB memory-scroll=yes only-headers=no \
streaming-enabled=no streaming-server=0.0.0.0:37008
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=yes \
stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
