Lately I've noticed that the "if...do" is triggered (i.e., the "if" resolves to "yes") every time the script is run, despite $LastHandshake being less than 5m. Pretty sure $LastHandshake resolves to ""
I didn't write the script, and I don't understand when $LastHandshake would resolve to ""
Can I just take out the condition: ([:tostr $LastHandshake] = "")
I vaguely remember mention that more recent versions of RouterOS do not need this DNS re-resolve -- and I dreaming this or is it true?
Thanks!
Code: Select all
:foreach i in=[/interface/wireguard/peers/find where disabled=no endpoint-address~"[a-z]\$"] do={
:local LastHandshake [/interface/wireguard/peers/get $i last-handshake]
:if (([:tostr $LastHandshake] = "") or ($LastHandshake > [:totime "5m"])) do={
:log info "WG-iface-restart script found WG peers with last handshake greater than 5 minutes; then reset the endpoint-address to reload dns of endpoint"
/interface/wireguard/peers/set $i endpoint-address=[/interface/wireguard/peers/get $i endpoint-address]
:local endpoint [/interface/wireguard/peers/get $i endpoint-address]
:log info "WG-iface-restart script found WG peer with last handshake greater than 5 minutes; then reset the endpoint-address to reload dns of endpoint: $endpoint"
