VFi
How to display a device name and its IP simultaneously?
Fri Dec 27, 2013 6:37 am
I added a device with name "Switch" and IP address "192.168.1.1".
The Dude only displays the device name (Switch) by default.
I want it to show the IP address at the same time in next line, for example:
Switch
192.168.1.1
How should I config The Dude?
Thanks!
lebowski
Re: How to display a device name and its IP simultaneously?
Mon Jan 06, 2014 5:40 pm
In the "appearance" you can specify any additional information you would like displayed. Since the appearance is able to be set globally, on a sub map or on an individual device you need to determine where is best for your setup.
On the appearance you can put [Device.FirstAddress] in the label... this will continuously display the address.
Lebowski
