Hi, I’m interested in municipality wireless networks and want to know if there is a Mikrotik solution for doing 2.4Ghz 3x3 or 4x4 mimo APs . I know there is netmetal 3x3 but it’s only 5Ghz.
thanks
thanks
You can use this card RB11e-2Hnd x2
in combination With RB953 using 2 card wifi cards and it will have total 4x4 streams
It should be quit effective.
Does MIMO works that way?
If yes, then how to configure them to appear as a single interface with four chains?
You cannot have one 4xmimo with two cards as they cannot communicate to each other so fast.
That’s what I was thinking about ![]()
Then, back to the topic - is there any 3x3 MIMO 2.4 GHz card that works with mikrotik?
https://blog.linitx.com/mikrotik-routeros-6-16-released/
“This is the first release to include support for 802.11ac, using the QCA9880/9882 rev2 (-BR4A) wireless chipsets.”
Mikrotik sell cards with AR9580 [if that is indeed what this card is - page says AR9590 as well] so I would be suprised if RouterOS didn’t support it.
http://linitx.com/product/mikrotik-r11e2hpnd-80211bgn-mini-pci-express-card/14024
