*) dhcp server - added two radius string options (24, 25) for use in custom dhcp options;
*) fixed problem - ppp dial-on-demand did not work, it allways dialed in;
*) fixed problem - password was not saved when adding new user;
*) added feature - show last-logged-in in users list;
*) snmp - fix interface table;
*) dhcp ipv6 - added comment fields;
*) dhcp client ipv6 - add/remove default route or ntp server without renew when settings change;
*) ppp clients - set up dns dynamic-servers instead of static ones;
*) fixed problem - Connect button did not work in wireless scanner;
*) dhcp server - added radius framed route support;
*) fixed problem - MetaROUTERs did not work on PowerPC boards (RB800, RB1000, RB1100);
*) fixed problem - check-for-updates stopped working if it didn’t find new updates
previously;
*) dhcp ipv6 - added dns option support;
*) gre - support all protocol encapsulation, not just ip and ipv6;
I previously had 6.04rc4 from the private section on Mikrotik.com. I updated to the rc4 release from the main page, and now CPU on my RB433UAH is 100% immediately after boot.
The two main processes are Wireless and Console. Each using 47-48% each constant.
I am generating a supout.rif now and will log a ticket with Mikrotik support.
Nope. Sorry. You’ve removed every other version! They have all gone. They are no more. They have ceased to exist. (I could go on, but that would infringe the Copyright of Monty Python! LOL)
I’m using RB800+SR71-A
I have upgraded to 6.0rc4 and constant kernel failures appear.
Cannot change frequency cannot downgrade…
Had to remove wireless card to downgrade but the other side(rb800+SR71-A) is upgraded and cannot be reached.
Is there any safe frequency in which it will connect.
I’m using superchannel and non standard frequency(6000+below-control).
Thanks in advance.
Same for me.
I have an rb-sxt and just rebooted the cpu goes 100%
How it’s possible to find/kill the bad process? I’m not be able to upload the 5.22 stable version because my sxt disconnect continuously after some seconds logged in..
nickshore, nest, thank you for the report. Links are back on the download page.
antoxa, please make support output file on your RB333 and send it to us. For your information mine RB333 upgrade went fine and all ports are working properly.
sirkike please clarify which NAT problem exactly.
pizzulicchio, tool profiler
shows CPU load by process.
I am unable to generate a supout.rif from the RB433UAH to send to Mikrotik.
I also notice if I connect to the serial console, I can login but as soon as I try any command it very briefly displays something about a console crash and returns to the login page.
I also tried to do a netinstall on to a RB751 without success (it does not complete).
