+1
I just pulled the RB433 that bricked last night from RC4. Same thing. All the IP addresses are there, but they have a 0.0.0.0/0 next to them.
Verified, doesn’t work. ROS6 must have a different format, as it will not import the same language as 5.XX.
[admin@MikroTik] > queue
[admin@MikroTik] /queue> simple
[admin@MikroTik] /queue simple> add burst-limit=0/0 burst-threshold=0/0 burst-time
=0s/0s direction=both \
expected end of command (line 1 column 58)
[admin@MikroTik] /queue simple> disabled=no interface=all limit-at=0/0 max-lim
it=768k/768k name==
syntax error (line 1 column 13)
[admin@MikroTik] /queue simple> “Betty Hogenson” packet-marks=“” parent=none p
riority=8 queue==
expected command name (line 1 column 5)
[admin@MikroTik] /queue simple> default-small/default-small target-addresses=1
0.81.15.40/32 total-queue==
syntax error (line 1 column 18)
bad command name default-small (line 1 column 5)
is not normal…
Works great on x86 platforms.
But not fixed ssh client bug (there is an error on connect “mepty: session finished”)
Also BGP has issues on all 6.x versions, disconnecting peers, 5.22 works.
Other things, everything works good. Thank you.
Don’t work igmp proxy ![]()
And how about igmp snooping?
poor performance on SMB - only 14 Mb
please give more details on your test. 14MB or 14Mbit? What device, what client, what file, what OS?
in 5.22 was better even CPU went 100%
I like colorful buttons in 6.rc041 in winbox very mach - nice work
Verify your CPU speed. I had the same issue when upgrading to 5.11 a while back. Web traffic was not affected but SMB was slow as hell. After some time I noticed that the CPU was set to 100 MHz. After setting it to the correct value everything was workning again!
It`s set to 600 MHz , tomorrow I’ll try system reset.
So is this enough evidence Normis or do I need to open a ticket with Mikrotik? Just let me know what I need to do. I really want to test this out I’m excited to see enhanced queue performance but because of this bug, I cannot.
Actually I already have a ticket opened, and I sent the before/after screenshots as well. It’s easily replicated, just use a Mikrotik RB version with 100+ queues, and upgrade the firmware to RC.
I’m still not able to install RouterOS 6rc4 to a USB stick. Is there someone here who successfully installed ROS 6rc? to a USB stick?
Please solve the tcp issue of Routeros…
what issue?..
had the same problem with queues - but had them deactivated before upgrading - same happend - after upgrade from 5.21 to RC4 (RB1100AHx2)there have been 2 targed addresses at each queue - the second one that was added at the update is 0.0.0.0/0 - not a big problem on my testbox
not so good in real …
queue tree traffic not realtime like webfig
Thank you very much to everyone about 0.0.0.0/0 in queues after upgrade reports.
We repeated the problem and working on the fix to include it to the next 6.0 version.
I do not believe that is normal…
