as far as I heard, IPs are still here (and I upgraded x86 5.21 to 6.0rc4, no problems at all), but on RBs, in WinBox you see 0.0.0.0/0 added to each simple queue’s target. moreover, you can’t see that 0.0.0.0/0 in CLI, so you can remove it only via WinBox… p.s. they say it’s so, I haven’t seen it
you can check using sniffer, what are these weird packets that are dropped. (when you start sniffing, they will not be dropped but accepted into the router for sniffer to see.
Sorry but we don’t have any known issues like that. Support has asked you to provide your configuration, but you have not done that. Please answer questions from support, to get your issue resolved.
Please everybody who experienced problems with /queue target-address 0.0.0.0/0 after upgrade to 6.0rc4.
Contact support with /queue export compact (that was used on v5.x). Thank you very much for the help.
you have an error in the package wireless 6.0rc5 6.0rc4 !!!
RB433UAH power 24V 2A
5.22 upgrade 6.0rc5 > CPU 100% (wireless 97%), no internet > update RouterBOOT 2.41 > 3.1 > reboot> CPU 100% (wireless)> disable wirelles packages>reboot> CPU ±10%>enable wireless packages>reboot> CPU ±10%, all wireless disable default> enable R52H wlan3 > CPU 100%> disable R52H>CPU 100% (wireless)> reboot> all interface no view CPU 100% > disable wireless packages>reboot>CPU ±10% ether interface view>enable wireless packages > CPU ±10%>reboot>CPU ±10%> all wireless disable > enable wlan2 CM10 > CPU 100% (wireless)…>> downgrade 5.22 (no stable version) + restore configuration >>> a few errors and I’ll get there almost stable 5.20
These are on all RB’s, and they have 100-200 queues. I’ll pull the one from the field today and power it up in the office and see what happened. It’s the same thing I’ve seen every time I test ROS6 since beta2.
All the queues will have IP’s, then after upgrade they say 0.0.0.0/0, when upgrading to any of the beta or RC versions. That is where the change happens.
I don’t think it will work. I tried pasting even just a few queues from a export script, and it wouldn’t add them. /queue/simple/add/ etc… won’t import with RC4. Had to downgrade back to 5.22
