Thank you for the Webfig reports, we would try to fix them on the upcoming version.
7.25 broke ICMPv6 ND between on-link IPsec peers. I had IPsec policy to exclude ICMPv6 for link-local addresses and packets to the on-link peer.
The configuration on one peer is currently like this:
/ip ipsec policy
add action=none comment="link-local icmpv6" dst-address=fe80::/64 protocol=\
icmpv6
add action=none comment=link-icmpv6 dst-address=\
fd57:71de:7124:e000::21/128 protocol=icmpv6 src-address=\
fd57:71de:7124:e000::20/128
add comment=link dst-address=fd57:71de:7124:e000::21/128 peer=\
peer-link proposal=intergateway src-address=\
After updating, the IPv6 neighbor can no longer be resolved, and IKE fails to establish SA. I worked around this by adding static neighbors.
I'm glad to hear that <3
Please make sure the 7.25.1 version covers ALL known regressions (as mentioned in this topic and in tickets)... take a week more when necessary.
In case someone is interested, I developed a patch to make version 3 in 7.25, you can find it in my github.
It works. Thanks
If someone shows the ASM patches, like this project does, another AI can do some reverse engineering of the winbox.exe to see where this code goes to. That's a better approach.
It the binaries on forum that I think are a problem. Patching your own winbox.exe is better plan... but your one release away from more changing in RouterOS so it be a game of whack-a-mole on per release basis I think. So it have to be maintained since I'm sure more changes are in store in the WinBox protocol, perhaps more substainal ones now that they "retired" WinBox3.
Already checked ![]()
Very glad, that there are people, who have more experience and can make it faster, than me. I was able to fix only 4 of 11 issues, that are described in this project. But it will help me a lot to figure out with other issues and may be I will apply them to my ESR version, if @peich1 won't mind.
As you can see, Upstream now has its own column and the U flag is not used anymore.
A joke... on his part!
I've been using this nick for more than 20 years! ![]()
Do as you please with the code. ![]()
The Upstream always has its own colume. The flag has indicated it does receives the multicast packet.
If you choose the wrong upstream interface, it will show flag “IU” , which indicate no multicast received.
on 7.25, even if you put a wrong interface as upstream, there is no flag showing it is inactive.
I wouldn't be so sure that pe1chl tried anything with your nick ... his nick is actually his amateur radio operator call sign ... quite possibly issued to him by some call sign administrator ... possibly even further in the past than 20 years.
So I'd call this a coincidence.
Another issue I noticed with 7.25
7.25 WebFig: CAPsMAN-managed wifi interface form shows inherited configuration fields as set (with wrong values), and OK/Apply writes them as overrides
hEX S as CAPsMAN manager, 7.25 stable, wifi-qcom-ac CAPs (hAP ac²/ac³, 7.25). A CAP master interface on the manager uses configuration=Test and only overrides channel, frequency and tx-power. CLI shows the effective values correctly:
/interface/wifi> print detail where name="device-master-2g-Test"
MB ;;; operated by CAP ..., traffic processing on CAP
name="device-master-2g-Test" ... configuration=Test configuration.ssid="Test" .mode=ap .dtim-period=3 .country=REDACTED .tx-power=15
security.disable-pmkid=yes .wps=disable .ft=yes .ft-over-ds=yes .connect-priority=0/1 .authentication-types=wpa2-psk,wpa3-psk
channel=2GHz channel.frequency=2437 .band=2ghz-n .width=20mhz
if /interface wifi export for it: only shows channel=2GHz channel.frequency=2437 configuration=Test configuration.mode=ap .tx-power=15.
WebFig, same interface: SSID, Country and DTIM Period are shown as set (the "−" button, like a real override), but with empty / first-of-list / default values instead of the inherited ones: SSID empty, Country "Afghanistan" (which is not the country set in the config), and DTIM Period 1.
Pressing OK or Apply writes those values. On another CAP radio, a few saves in WebFig produced (from the log):
system,info device changed by .../web:admin@... (/interface wifi set *3D channel=5GHz channel.band=5ghz-a .width=20/40/80mhz ...
configuration=Test configuration.country=Afghanistan .mode=ap .ssid="" .tx-power=0 ... security.authentication-types="" .disable-pmkid=no
.ft=no .ft-over-ds=no .wps=disable)
Saving the /interface wifi configuration entry in WebFig likewise added inline security.authentication-types="" .disable-pmkid=no .ft=no .ft-over-ds=no .wps=disable, which override the security profile on every AP using that configuration (802.11r was off on all of them).
The overrides could not be removed from WebFig (saving again re-posts the form). CLI fixed it: /interface wifi configuration unset value-name=security.ft (etc.), /interface wifi unset value-name=security, re-set channel=.
Expected: WebFig shows inherited values as inherited (the "+" state) and posts only fields the user changed.
Workaround: edit CAPsMAN-managed interfaces/configurations in WinBox or CLI; check /interface wifi export afterwards.
SNMP support of hardware sensors still buggy - rb1100ahx2 walk show:
MIKROTIK-MIB::mtxrHlVoltage.0 = INTEGER: 12.2
MIKROTIK-MIB::mtxrHlActiveFan.0 = STRING: main
MIKROTIK-MIB::mtxrHlTemperature.0 = INTEGER: 25.0
MIKROTIK-MIB::mtxrHlProcessorTemperature.0 = INTEGER: 27.0
MIKROTIK-MIB::mtxrHlPower.0 = INTEGER: 11.4
MIKROTIK-MIB::mtxrHlCurrent.0 = INTEGER: 938
MIKROTIK-MIB::mtxrHlProcessorFrequency.0 = INTEGER: 1066
MIKROTIK-MIB::mtxrHlFanSpeed1.0 = Gauge32: 5974
MIKROTIK-MIB::mtxrGaugeName.13 = STRING: voltage
MIKROTIK-MIB::mtxrGaugeName.14 = STRING: temperature
MIKROTIK-MIB::mtxrGaugeName.17 = STRING: cpu-temperature
MIKROTIK-MIB::mtxrGaugeName.18 = STRING: current
MIKROTIK-MIB::mtxrGaugeName.7001 = STRING: fan1-speed
MIKROTIK-MIB::mtxrGaugeValue.13 = INTEGER: 122
MIKROTIK-MIB::mtxrGaugeValue.14 = INTEGER: 25
MIKROTIK-MIB::mtxrGaugeValue.17 = INTEGER: 27
MIKROTIK-MIB::mtxrGaugeValue.18 = INTEGER: 9
MIKROTIK-MIB::mtxrGaugeValue.7001 = INTEGER: 5973
MIKROTIK-MIB::mtxrGaugeUnit.13 = INTEGER: dV(3)
MIKROTIK-MIB::mtxrGaugeUnit.14 = INTEGER: celsius(1)
MIKROTIK-MIB::mtxrGaugeUnit.17 = INTEGER: celsius(1)
MIKROTIK-MIB::mtxrGaugeUnit.18 = INTEGER: dA(4)
MIKROTIK-MIB::mtxrGaugeUnit.7001 = INTEGER: rpm(2)
two seconds later:
MIKROTIK-MIB::mtxrHlPower.0 = INTEGER: .0
MIKROTIK-MIB::mtxrHlCurrent.0 = INTEGER: 0
MIKROTIK-MIB::mtxrHlFanSpeed1.0 = Gauge32: 6111
MIKROTIK-MIB::mtxrGaugeValue.18 = INTEGER: -66
MIKROTIK-MIB::mtxrGaugeValue.7001 = INTEGER: 6111
mtxrHlCurrent is zero, corresponding value in mtxrGaugeValue.18 - is -66????
And output value of mtxrGaugeValue.18 is wrong - it should be same as mtxrHlCurrent - but it divided by 100 and rounded to integer.
Same on a pair of crs520-4XS-16XQ here.
