7.25 [stable] is released!
After upgrading from 7.24.5 to 7.25, Traceroute stopped working on my CCR1009-8G-1S-1S+ (9-core TILE). WinBox was also upgraded from v3 to v4.4.
Traceroute showed an empty window in WinBox, while the terminal command eventually returned:
action timed out - try again ... (13)
Regular Ping worked fine.
Even after closing all Traceroute windows, /tool profile showed constant CPU usage:
traceroute 11.1%
total 14.2%
This suggests the Traceroute process was stuck using one CPU core.
After rebooting, everything returned to normal, including Traceroute in both WinBox and the terminal.
Traceroute worked fine on 7.24.5. Possibly a regression in 7.25.
Same webfig issues as xavierbt, DNS configuration is MIA and I can't get it to show up after several tests.
At least it still displays properly under "/ip dns print"? But this is the first and last time I'll try to upgrade to a .0 release.
You are right, it is my amateur radio callsign and it has been issued in 1978...
At that time they were alphabetically assigned. Today you can choose one of your liking, but I have never changed it.
IP scan disappeared on hap lite with v7.25 =((
Hap lite is too slow (and doesn't even have the system requirements) for v7 anyway :sweat_smile:
I believe that it currently ships with ROS7, and I have one running it without issues (at least as an AP . . . it did get upset with OpenVPN and such on it). All in all, still does a decent job as a bare-bones 2.4G AP w/ROS7 . . .
I upgraded my infrastructure : RB5009, CCR2004, CRS328, RB4011, WAP LTE, HAP AX3.
Seems to work, except webfig in wireguard peers, allowed address is not displayed and printed in RED:
Capture d’écran 2026-10-31 à 21.14.37
Of course, the allowed address is displayed in /export. Wireguard works well. This is only a webfig display issue.
Also power cycling over PoE the Wap LTE from the CRS328 does not work.
Did you get with any versione, strange lag during gaming. Even with 7.23.8 LTS. For me hAP be lite is almost unusable. 7.24 is the best for now, but after a day it become unstable and lags during gaming, even normal browsing sometimes are not optimal after a while.
Is the allowed address the last entry in that menu that is set different from the default/unset "[-]"?
Because I notice the same with Webfig across various menus starting with Wifi/Configuration - the lowest entry I changed is "Country" and Webfig just shows it as unset. Export and Winbox both show it correctly.
The biggest problem is that in the case of Wifi/Configuration the Country setting is not mandatory so one can save from Webfig and the entry will be deleted.
I have been using Webfig almost exclusively ever since I started with MT and now I cannot trust it anymore. Sucks.
@EdPa,
  1. [bug] /ip socksify set socks5-password=X is not considered sensitive for /export hide-sensitive et al.
  2. [bug] /ip socksify set comment=X is accepted, but the comment is not saved anywhere (e.g. lost in /export executed thereafter).
  3. [feature request] Could /interface wireguard peers print show peer name by default? Otherwise one has to either use print detail (which is less readable - it's not a table) or duplicate this information in comment (as it is shown in print).
  4. [feature request] When /ip route add is created, it has no disabled parameter in non-verbose /export. If you /ip route enable/disable it, the route will have a disabled=no/yes parameter. There seems to be no way to remove the parameter (i.e. revert back to the way it was after /ip route add for /export) without removing and re-adding the route. This is inconsistent with the behaviour of disabled parameter for other options.
Could you kindly flag these internally, please?
Same issue here: I cannot use Webfib anymore to manage my wireguard peers and clients. Waiting for a fix.
I think it was already acknowledged that WebFig is fatally broken in this version and it will be fixed.
It should not be used.
I have that problem with 7.23.8, 7.24.5 and 7.25.0.
GRE tunnel over IPSec over Dual WAN does not work in 7.25 - it does work in 7.24.5 with no issues. Router RB5009, arm64. What is broken: tunnel is working when both WAN interfaces are up. If i disable one WAN interface or disable and enable the same WAN interface then it stops working and needs a reboot to work again. Please bring back the 7.24.5 behavior!
OK, so I spent the last hour or so reading through this thread. The major showstoppers for 7.25 seem to be:
  • DHCPv4 client not working properly in some scenarios
  • IPv6 prefix problems that could be time-dependent (i.e. may appear to work at first but fail on prefix renewal)
  • IPsec/GRE not working properly
  • WebFig not showing values that other configuration methods show. This may or may not result in a corrupted configuration if WebFig is used
  • a bunch of Wi-Fi stuff may be broken (I don't use Wi-Fi yet)
  • some MLAG stuff may be broken (I don't use MLAG)
In addition, 7.25 may or may not fix a CVE for a session credential replay attack. Did I miss anything else that is essential?
These are some serious showstoppers, as updated infrastructure will probably lose network connectivity. As a customer, I do not expect even one problem of that severity in a stable major release, let alone six of them.
So, the community has identified some severe problems with the current 7.25 release, I think we're all clear on that. The big question, given that 7.25 was released over a week ago, is: when can we expect a fix? Over a week, people relliant on IPv6 have severe problems with connectivity, so this should considered urgent, at least from my POV.
Upgraded early on without issues in my Audience's setup. Wanted to use new DHCPv6 server FQDN & add-dns-entries capability. Found some issues there, reported and got confirmation and waiting for fix.
hAP be lite – Kernel crash in station-bridge mode (RouterOS 7.25)
I'm experiencing reproducible kernel crashes on my hAP be lite running RouterOS 7.25 with the wifi-mediatek driver.
The router boots normally and remains stable until the Wi-Fi interface operating in station-bridge mode connects to an access point. As soon as the connection is established, RouterOS crashes with a "kernel failure" and the device reboots.
This happens consistently and is easily reproducible.
RouterBOARD firmware is also updated to 7.25.
Has anyone else experienced kernel crashes specifically in station-bridge mode on hAP be lite? Is this a known issue with the wifi-mediatek driver in 7.25?
DHCPv4 and DHCPv6 clients stuck at “searching...” after reboot on RouterOS 7.25; downgrade to 7.24.5 fixes both
I encountered a reproducible WAN DHCP issue on a MikroTik hAP ax³ (arm64) after upgrading to RouterOS 7.25.
Before the upgrade, the router had been working normally on RouterOS 7.24.5. No WAN, DHCP, NAT, firewall or WireGuard configuration changes were made as part of the upgrade.
After the 7.25 reboot:
  • IPv4 DHCP client on ether1-WAN remained in status=searching...
  • DHCPv6-PD client on the same interface also remained in status=searching...
  • The Ethernet link was healthy: link-ok, 1 Gbps, full duplex.
  • No IPv4 DHCP address, default route or DNS configuration was installed.
  • No IPv6 delegated prefix or IPv6 default route was installed.
For IPv4, I captured DHCP traffic on ether1-WAN. The DHCP server consistently replied with valid DHCPOFFER packets for the previously used lease and gateway. The router sent DHCPDISCOVER packets repeatedly, but never sent a DHCPREQUEST.
The capture contained repeated sequences like this:
Router -> DHCPDISCOVER
DHCP server -> DHCPOFFER
There were no DHCPREQUEST, DHCPACK or DHCPNAK packets.
I also checked the firewall carefully:
  • No explicit DHCP/BOOTP block rule was present.
  • A temporary, narrow IPv4 input accept rule for DHCP replies (UDP source port 67 to destination port 68) was added before the final WAN input drop rule. This did not change the behavior on 7.25.
  • IPv6 already had an input accept rule for DHCPv6 prefix delegation from fe80::/10 to UDP port 546, before the final WAN input drop rule.
  • As an additional test, I temporarily disabled only the final IPv6 input drop rule and renewed DHCPv6. The client still remained in searching... state.
  • Disabling WireGuard test tunnels did not change the issue.
I downgraded both packages to RouterOS 7.24.5:
  • routeros-arm64-7.24.5.npk
  • wifi-qcom-7.24.5-arm64.npk
Immediately after the downgrade and reboot:
  • IPv4 DHCP client became bound again.
  • IPv4 default route was installed.
  • Internet connectivity was restored.
  • DHCPv6-PD client became bound again.
  • IPv6 delegated prefix and IPv6 default route were restored.
  • Both IPv4 and IPv6 WireGuard tunnels resumed normal handshakes.
I then removed the temporary IPv4 DHCP firewall rule, forced a new DHCP renew, and IPv4 DHCP remained bound with an active default route and working Internet connectivity.
This strongly looks like a RouterOS 7.25 DHCP client regression or a DHCP/DHCPv6 runtime-state regression triggered by reboot on this device/configuration.
I can provide a sanitized DHCP packet capture and further diagnostics if needed.
