7.25rc [testing] is released!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.25rc2 (2026-10-09):
  • bridge - fix DHCP snooping dropping DHCP messages on trusted ports when the source MAC differs from chaddr (introduced in v7.25beta3);
  • container - fix veth interfaces not getting an address from the correct DHCP server when a PVID is configured (introduced in v7.25beta3);
  • defconf - fix button script policies;
  • defconf - fix default configuration generation when CRS8xx series switch ports initialize late;
  • dude - fix the server not starting at boot when data-directory is on a USB disk;
  • ipsec - fix IPsec tunnels failing after migration from the old QKD settings;
  • ipv6 - fix cases when address is lost after reboot if prefix was taken from pool (additional fixes);
  • lte - fix missing MAC address on QMI LTE interfaces after the interface is recreated (introduced in v7.24.4);
  • lte - improve system stability when using Quectel EP06-E MBIM modem (additional fixes);
  • ovpn - improve stability in UDP mode when the TX queue is full;
  • route - improve static route handling performance;
  • system - improve stability;
  • wifi - reuse freed station association IDs;
  • wifi-mediatek - fix E62 performance issue (introduced in 7.25rc1);
  • winbox - show warning messages under "System/Users/SSH Keys" and "System/Users/SSH Private Keys" menu;
  • wireguard - fix a peer that would not work after import when no endpoint address is set;
What's new in 7.25rc1 (2026-10-01):
  • bgp - show interface names and VRF names in BGP logs;
  • bridge - fix MLAG bond slave interfaces not coming up when the MLAG configuration is removed (introduced in v7.25beta3);
  • bridge - fix MLAG peer ports going down when a bridge port is enabled (introduced in v7.25beta5);
  • bridge - fix virtual slave ports being removed from the bridge when MLO is triggered (introduced in v7.25beta4);
  • bth - add default client DNS and allowed IPs settings (additional fixes);
  • dhcpv6-server - fix send-reconfigure for DHCPv6 clients behind a relay;
  • ipv6 - fix missing IPv6 link-local addresses on some interfaces when the device is busy during boot;
  • lcd - improve stability when an SFP reports an unknown link speed;
  • switch - add packet and byte counters for ACL rules on Marvell Prestera switches (additional fixes);
  • switch - fix ACL rules remaining in the switch TCAM after removal (introduced in v7.25beta3);
  • vlan - add a forced-mac-address option for VLAN interfaces (additional fixes);
  • webfig - fix comboboxes in the System/PTP section not being editable (introduced in v7.25beta3);
  • webfig - fix empty Bridge and Interface/Ethernet sections (introduced in v7.25beta4);
Other changes since 7.24.5:
  • app - add the networkRouterIP variable for container apps;
  • app - allow the privileged mode to be enabled per service in the container app YAML;
  • app - fix CHR apps getting stuck on "starting" on slower boards;
  • app - show an error when an app variable cannot be resolved;
  • app - update the environment variables of the docker-with-komodo app;
  • bgp - add the always-compare-med setting;
  • bgp - fix BGP unnumbered connections within a VRF;
  • bgp - include the VNI number in outgoing EVPN routes;
  • bgp - log failed BGP connection attempts;
  • bridge - add dynamic ARP inspection;
  • bridge - add IP source guard;
  • bridge - add mlag-lacp-fallback and mlag-init-delay settings for MLAG;
  • bridge - fix a false "already added as bridge port" error;
  • bridge - fix an MLAG peer getting stuck in the disabled state after config changes;
  • bridge - fix bridge ports not forwarding;
  • bridge - fix MLAG MAC handling when used with VRRP;
  • bridge - fix VRRP MAC behavior in MLAG setups;
  • bridge - improve FDB synchronization between MLAG peers when VLANs are added;
  • bridge - make MVRP work with MLAG dual bonds;
  • bridge - rename the IGMP last-member-interval property to last-member-query-interval;
  • bridge - warn about VLAN entries when vlan-filtering is disabled;
  • bth - add resumable file uploads;
  • bth - check the available disk space before a file upload;
  • bth - fix file share issues when enabled through WinBox files menu;
  • bth - fix the file share getting stuck when disabling;
  • bth - return upload errors in JSON format;
  • capsman - add hw-protection-threshold;
  • capsman - fix the last-ip value being shown backwards;
  • certificate - fix ACME certificate issuance for wildcard domains;
  • certificate - refactor certificate internal processes;
  • console - allow the array access operator to accept arrays of indices or keys;
  • console - expose globals in the API;
  • console - fix background ":execute as-string" jobs not terminating on interrupt;
  • console - fix comment wrapping in the monitor command;
  • console - fix inconsistent /ip/firewall/filter print with src-address-list and dst-address-list;
  • console - fix the where filter ignoring flags set to false;
  • console - improve export order;
  • console - prevent an out-of-memory condition when ":execute as-string" produces large output;
  • console - prevent duplicate entries in /port/remote-access;
  • container - add a Ctrl-] escape sequence to exit a stuck container shell;
  • container - fix container interface handling on CHR;
  • container - fix veth interface left running after restarting a stopped container;
  • container - require the container device-mode to enable swap;
  • crypto - fix a possible crash during IPsec processing on Qualcomm devices;
  • detnet - use a single random source port;
  • dhcpv4-client - ignore forcerenew packets that are not unicasted to client;
  • dhcpv4-server - add ipv6-only-preferred parameter to respect option 108;
  • dhcpv4-server - show DHCP option 82 parameters in ASCII in addition to hex;
  • dhcpv6-client - add option 39 with the client hostname;
  • dhcpv6-client - fix DHCPv6 client address handling after prefix-hint changes;
  • dhcpv6-client - remove a duplicate dhcp-options parameter;
  • dhcpv6-relay - use the packet's source MAC for option 79 if relay and client are on the same link layer;
  • dhcpv6-server - add option 39 (FQDN) support and add-dns-entries option;
  • disk - improve RAID5/6 throughput;
  • dns - fix resolving domain names that end with a dot;
  • dot1x - rename the reauth-timeout to reauth-period;
  • email - fix server certificate verification;
  • email - show certificate related errors in the log;
  • ethernet - add the arp-accept parameter for interfaces with MAC;
  • ethernet - fix a stability issue on RB1100AHx2 under heavy traffic;
  • ethernet - fix bogus fast-path Rx traffic reported on an unconnected ether8 port on RB5009;
  • ethernet - fix link flap and unexpected reboots on RB5009;
  • ethernet - fix PPPoE link flapping on Intel X710;
  • ethernet - fix PPPoE over VLAN not working on Mellanox ConnectX-4;
  • ethernet - fix SFP compatibility on hAP ax S and hEX S (2025) devices;
  • ethernet - improve stability on x86 routers with Mellanox NICs;
  • evpn - publish MAC-IP routes (RT-2) for neighbors;
  • fetch - improve upload state reporting when using sftp;
  • fetch - never set a cookie jar for HTTP requests;
  • fetch - show a clearer error when keep-result and output are both used;
  • firewall - add NAT-related fields to CEF format logging;
  • hardware - show the device name and location in /system/resource/hardware menu;
  • igmp-proxy - improve stability when changing /routing/igmp-proxy parameters;
  • iot - add a GPIO menu in WinBox;
  • iot - add Bluetooth output power control;
  • iot - allow a custom radio plan even under a regional lock;
  • iot - enforce the fixed antenna gain on boards with an embedded antenna;
  • iot - fix round-trip-time timing issues in LoRaWAN Basic Station;
  • ip-service - fix services becoming unreachable after their VRF is disabled and re-enabled;
  • ipsec - add XFRM interface support;
  • ipsec - fix IKEv1 tunnels failing to establish when the commit bit is set;
  • ipsec - fix policy and SA handling after moving it to netlink;
  • ipv6 - fix a failure when releasing DHCPv6 prefix delegation pools;
  • ipv6 - fix cases when address is lost after reboot if prefix was taken from pool;
  • ipv6 - fix the DNS timer in router advertisements;
  • ipv6 - ignore router advertisements received on interfaces not in the accepting list;
  • l3hw - fix IPv6 link-local traffic being routed incorrectly;
  • l3hw - improve stability of L3 hardware offload when using IPv4-mapped IPv6 addresses;
  • l3hw - optimize ECMP nexthop offloading;
  • leds - add dark-mode support for L41;
  • leds - fix missing LED triggers when an R11e card is installed;
  • lte - accept both y and yes for eSIM confirmation;
  • lte - add band display support for Huawei ME909s modems;
  • lte - add missing network error messages for MBIM modems;
  • lte - add the sms-protocol=qmi option for sending and reading SMS;
  • lte - do not force reconfiguration on roaming network when roaming is disabled;
  • lte - fix LTE interfaces disappearing after FOTA updates;
  • lte - fix missing new firmware update notification on some modems;
  • lte - fix multi-APN connections not passing traffic on AT modems;
  • lte - fix the subscriber number not updating after switching SIM slots;
  • lte - improve system stability when using Quectel EP06-E MBIM modem;
  • lte - improve system stability with eSIM-capable MBIM modems;
  • lte - remove leftover APN slave interfaces when the master LTE interface is removed;
  • lte - use also the network reported ipv6 MTU on MBIM interfaces when "auto" mtu option used;
  • lte - use RA for IPv6 acquisition for FG621;
  • netinstall - add branding-and-custom-packages parameter for custom NPK packages;
  • netinstall - fix a duplicate device entry on RB2011 with SFP;
  • netinstall - fix adding and exporting server comments;
  • netinstall - fix multiple active interfaces inheriting the first interface's settings;
  • netinstall - fix Netinstall failing to reinstall RB850Gx2 devices;
  • netinstall - fix Netinstaller's memory check failing downloads to disk;
  • ospf - fix DR/BDR traffic not being received with multiple instances;
  • ospf - improve stability when a neighbor is lost;
  • pim - add MLD support for PIM;
  • pim - fix duplicate PIM configuration parameters;
  • pim - fix PIM-SM issues with IPv6;
  • pim - fix wrong or missing PIM configuration by separating PIM and GMP per interface;
  • poe-out - add port-type field to poe monitor and print output;
  • poe-out - firmware update for 802.3at capable boards (the update will cause a brief power interruption to poe-out interfaces);
  • poe-out - firmware update for 802.3bt capable boards (the update will cause a brief power interruption to poe-out interfaces);
  • poe-out - fix PoE fault led behavior;
  • poe-out - fix PoE ports entering overload state when a PSU is fed from a UPS;
  • port - accumulate incoming data in log file even without TCP clients connected;
  • port - add an FTDI latency_timer option for low-latency serial applications;
  • ppp - add port interface info to PPP outbound channel defaults;
  • ppp - fix a packet leak during dial-on-demand connection of a ppp-out interface;
  • ppp - fix BG77 modem port name and channel count;
  • ppp - fix the offline firmware-update notification for BG77/BG770 modems;
  • ppp - fix the SINR value reported for BG77 and BG770 modems;
  • ptp - add support for fixed master and slave port roles;
  • ptp - add transparent clock mode;
  • ptp - fix dropped packets on bridges with IGMP snooping and add vlan-id port setting;
  • qos - fix PFC and lossless buffer issues (introduced in v7.23);
  • queue - fix a typo in the cake-overhead-scheme parameter value;
  • sfp - fix QSFP28 optical modules failing to establish a link on CCR2216 and CRS520;
  • sfp - improve QSFP-DD link establishing to NVIDIA DGX Spark and other devices;
  • sniffer - improve packet time resolution;
  • sniffer - show packet timestamps with nanosecond precision in WinBox;
  • snmp - add an OID and logging for blacklisted program access;
  • snmp - add CAPsMAN radio data to SNMP;
  • snmp - add dynamic SNMP engine ID assignment;
  • snmp - add interface table with mtu and l2mtu OIDs;
  • snmp - add IP pool OIDs;
  • snmp - add IPv6 address and interface name to the MNDP neighbour table;
  • snmp - add OID blacklisting;
  • snmp - add OIDs for Netwatch probes;
  • snmp - add OSPF MIB tables;
  • snmp - add SHA-2 authentication for SNMPv3;
  • snmp - add transmit drop counters;
  • snmp - add VRRP status OIDs for monitoring;
  • snmp - fix the reported capability flags in LLDP-MIB;
  • snmp - fix the snmp tools timing out when authentication is used;
  • snmp - log a warning when the src-address family does not match the request;
  • snmp - remove an interface OID that should not be accessible;
  • ssh - add a connection id to SSH log entries;
  • ssh - add host key verification for the SSH client;
  • ssh - limit server output to the client's window size;
  • ssh - show router host key fingerprint;
  • ssh - switch the default host key type to Ed25519;
  • ssh - warn users when weak RSA key is being used;
  • ssl - enabled hardware accelerated GCM on Alpine CPUs;
  • ssl - improve logging;
  • switch - fix degraded slow-path throughput on CRS304 switch (introduced in v7.22);
  • system - fix the frequency units from Mhz to MHz;
  • system - improve stability (includes CVE-2026-31431, CVE-2026-67280);
  • system - reboot automatically when the boot process fails to start;
  • system - reduce the fan control interval on multi-core boards;
  • system - remove the channel label from the RouterOS version;
  • system - show health settings and overtemp options based on device capabilities;
  • system - warn about a missing wifi driver package on BE boards;
  • tftp - add VRF support;
  • traffic-flow - fix a kernel failure when disabling traffic flow on a busy system;
  • user - fix removal of inactive REST API sessions (introduced in 7.21);
  • userman - improve stability when importing database files;
  • vlan - warn when a VLAN interface is created on a slave interface;
  • webfig - add a generic table and union group support;
  • webfig - add column resizing to embedded tables;
  • webfig - hide the left menu only on QuickSet and Terminal pages;
  • webfig - improve comboboxes to select the first matching option while typing;
  • webfig - update style;
  • webfig - update the login page Help link;
  • wifi - add a stream-port argument to configure the sniffer streaming server port;
  • wifi - add fast transition support for MLD devices;
  • wifi - add interworking, aaa and steering settings to the network configuration;
  • wifi - add more steering debug logs;
  • wifi - add network 'labels' parameter to WinBox and WebFig;
  • wifi - do not preserve branding package on cap when upgrading via capsman;
  • wifi - fix CAPsMAN failing when mangle marking is used with encrypted data channels;
  • wifi - fix channel reselect interval/time operation for wifi-qcom-be and wifi-mediatek interfaces;
  • wifi - fix incorrect scan results for 320 MHz access points;
  • wifi - fix MLD link type change and SA query in station mode;
  • wifi - fix per-link client statistics for MLO connections;
  • wifi - fix SAE authentication using a wrong cached PMK;
  • wifi - fix station statistics not updating after switching MLD links;
  • wifi - fix the interworking network type;
  • wifi - fix the wrong band shown in the registration table;
  • wifi - fix traffic processing on CAPsMAN after an interface is disabled;
  • wifi - perform a channel switch instead of dropping clients on radar detection;
  • wifi - preserve dude package on cap when upgrading via capsman;
  • wifi - report channel in log messages;
  • wifi - report management frame protection (MFP) usage in registration-table;
  • wifi - show the EAP user identity in the registration table;
  • wifi - show the MLD links and SSID in MLO client log messages;
  • wifi-mediatek - fix 4.9 GHz band operation on the A42;
  • wifi-mediatek - fix the 5 GHz access point failing to start after reconfiguration on the A42;
  • wifi-mediatek - improve MLO client reconnection;
  • wifi-qcom - fix disconnects during fast transition roaming;
  • wifi-qcom - fix station mode association failures;
  • wifi-qcom - improve IP multicast delivery to wireless clients;
  • wifi-qcom-ac - fix a regression in station MAC address handling;
  • wifi-qcom-ac - reduce package size;
  • wifi-qcom-be - add hw-protection-mode support;
  • wifi-qcom-be - add the distance setting for 802.11be devices;
  • wifi-qcom-be - fix the block ack request being declined after a channel switch;
  • wifi-qcom-be - fix Wi-Fi intermittently unavailable after reboot;
  • wifi-qcom-be - improve throughput in dense client environments;
  • winbox - add a filtered LLDP tab to neighbor discovery;
  • winbox - add a Security tab and reorganize bridge and port dialogs;
  • winbox - add a wifi radio regulatory info (reg-info) view;
  • winbox - add device-mode configuration;
  • winbox - add ISIS support;
  • winbox - add progress bar support to the GUI;
  • winbox - add RSRP and RSRQ signal graphs to the PPP info view;
  • winbox - add the client MTU option for WireGuard peers;
  • winbox - add the container save option;
  • winbox - add wifi Spectral Scan support;
  • winbox - allow power-cycling multiple interfaces at once;
  • winbox - allow tuple fields with more than two values and multiple separators;
  • winbox - fix SFP optical power values of 0.0 dBm not being shown;
  • winbox - fix the channel.reselect-interval range field in CAPsMAN;
  • winbox - fix the EC/IO signal quality graph;
  • winbox - fix the ISIS neighbor level type being empty for "l2";
  • winbox - fix the Memory Limit field of fq_codel to use bytes;
  • winbox - fix the Min Prefix field in the routing rule dialog;
  • winbox - fix the MPLS TE tunnel path hops field;
  • winbox - fix the range field displayed in route filters;
  • winbox - fix the signal indication graphs for ppp-out interfaces;
  • winbox - fix the Skins menu for user groups opening a non-existent window;
  • winbox - fix the system note display on startup;
  • winbox - fix the wifi Authentication Types and Encryption fields;
  • winbox - fix wg-import creating an WireGuard interface without a config file;
  • winbox - improve status reporting under Tools/Email menu;
  • winbox - make the Power Cycle button act only on the selected interface;
  • winbox - open the Format Drive panel only for supported disks;
  • winbox - remove the redundant empty status field from the License window;
  • winbox - rename "send" to "transmit" in the Bandwidth Test window;
  • winbox - rework the switch QoS statistics table;
  • winbox - show WireGuard peer information;
  • wireguard - add the client-mtu parameter;
  • wireguard - allow referencing a peer by its name;
  • wireguard - allow unsetting the client-listen-port;
  • wireguard - improve error message reporting when adding a new peer;
  • wireguard - keep peer rx/tx counters when the peer is disabled and enabled;
  • wireguard - support comment lines in wg-import configuration files;
  • wireguard - treat empty private-key and preshared-key values as none;
  • wireguard - use the MTU value when importing a configuration;
  • wireguard - warn when an allowed-address overlaps another peer;
  • www - add the remote client IP and domain to HTTPS log messages;
  • www - fix a memory leak when parsing authentication headers;
  • www - improve URI parsing;
To upgrade, click Check For Updates under System/Packages menu and select the testing Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
RB450G with OSPF + iBGP updated from beta. Seems to be alive :slight_smile:
The /system/identity/print newline bug was still present in 7.25beta5. Now in 7.25rc1 it is fixed.
While in 7.24.5 the fix was mentioned in changelog, there is no such line in 7.25rc1 changelog.
How can I trust changelog anymore?
Could this new release as RC be the reason on MikroTik Support Team not responding SUP-224431 - VXLan not mapping remote MAC on one side - since 2026-09-22 ?
Yep... Maybe MAC-IP EVPN Routes can help on this...
But this is related to EVPN, and the issue is related to VXLAN pure.
I'm talking of a support ticket opened in 2026-09-22, full of details, rif files, backup files, packet capture files, export files, screenshots, topology.
10 days, 8 commercial days, and even a single "hello, we received your support request, and will try to reproduce".
Note: 6 times I asked for updates that support ticket. Even then, no response.
The changelog is a diff from 7.24.5, that's why.
:light_bulb:
Now I get it.
But then I'd like to highlight this.
again
Just 2 days between these releases. This "system - improve stability;" must be some serious thing.
2^8+18 lines of a changelog is a serious THING per se.
I have updated a hAP ax S...
My own home usage.
And the behavior of high CPU usage in wireless process that occurred on one of the previous beta versions of 7.25 is not occurring anymore.
Still evaluating.
VERY CRITICAL BUG ON CCR-1072 after installing 7.25RC1 the router itself changed the admin password and we are not able to login....
The first login with winbox 4.4 was fine, the second.... username or password wrong!!!!
also through cli and neghbor is the same... user or password invalid.....
very shit......
7.25rc1 broke my CAPs (missing SSIDs and /export timeouts)
After upgrading from 7.24.5 to 7.25rc1 I'm now seeing some really weird problems on both my hAP ax3 and hAP ac3, both running as CAPs. My RB5009, which is running CAPsMAN, seems to be fine.
The wireless configuration itself looks fine, but some of the configured SSIDs are simply not being broadcast.
And /export is completely broken now:
% grep -i '#error' *.rsc
export-hap-ac.rsc:#error exporting "/snmp/community" (timeout)
export-hap-ac.rsc:#error exporting "/interface/bridge" (timeout)
export-hap-ac.rsc:#error exporting "/interface/l2tp-ether" (timeout)
export-hap-ac.rsc:#error exporting "/interface/ovpn-client" (timeout)
export-hap-ac.rsc:#error exporting "/interface/ovpn-server" (timeout)
export-hap-ac.rsc:#error exporting "/interface/ppp-client" (timeout)
export-hap-ac.rsc:#error exporting "/interface/ppp-server" (timeout)
export-hap-ac.rsc:#error exporting "/interface/pppoe-client" (timeout)
export-hap-ac.rsc:#error exporting "/interface/pptp-client" (timeout)
export-hap-ac.rsc:#error exporting "/interface/pptp-server" (timeout)
export-hap-ac.rsc:#error exporting "/interface/eoip" (timeout)
export-hap-ac.rsc:#error exporting "/interface/gre" (timeout)
export-hap-ac.rsc:#error exporting "/interface/vrrp" (timeout)
export-hap-ac.rsc:#error exporting "/interface/vlan" (timeout)
export-hap-ac.rsc:#error exporting "/snmp" (timeout)
export-hap-ac.rsc:#error exporting "/interface/wifi" (timeout)
export-hap-ac.rsc:#error exporting "/zerotier/interface" (timeout)
export-hap-ac.rsc:#error exporting "/queue/interface" (timeout)
export-hap-ax.rsc:#error exporting "/ip/ipsec/policy/group" (timeout)
export-hap-ax.rsc:#error exporting "/ip/ipsec/policy" (timeout)
export-hap-ax.rsc:#error exporting "/interface/wifi" (timeout)
export-hap-ax.rsc:#error exporting "/queue/interface" (timeout)
Something is seriously wrong here. /export timing out on all sorts of completely unrelated things, and at the same time some SSIDs configured in CAPsMAN are simply not being advertised.
This started immediately after upgrading to 7.25rc1. The RB5009/CAPsMAN side seems to be OK, and both the hAP ax3 and hAP ac3 are affected.
I really regret upgrading to this RC. I'm probably going to have to downgrade back to 7.24.5 now, and I'm just hoping the downgrade doesn't make things even worse.
SUP-225393
Have you tried serial console?
A critical vulnerability (CVE-2026-84411) was discovered in MikroTik RouterOS versions prior to 7.24, affecting the web management service's HTTP request body handling.
At least do a simple google search before posting.
getting error
/system package update check-for-updates
channel: testing
mode: https
check-certificate: yes
ip-version: auto
installed-version: 7.25beta5
status: ERROR: IPv4: bad HTTP response
IPv6: no internet connection
* edit - worked after reboot
(nothing, error)
the problem is the console port.
In fact we were able to reproduce the issue in lab.
2 Mikrotiks router that are connected back to back with a cross rs232 cable over the console ports. One is upgraded to 7.25rc1 and after a while it refuses to give access to admin/password credentials on any service!
I opened the ticket SUP-225388 producing supout before and afeter the change.
in the lab we discovered that the password is not changed.
But the admis user is locked, if you disconnect the cross console cable between the two routers you could regain access.
So the routers connected through console generates some local login tentative:
  • those tentatives didn't produce any issue in the past versions
  • from 7.25rc1 it produce a lock in the user until the tentative are stoped
so be carefull if you are in this condition.
Interesting! That was also causing poor performance with hAP ax S, did you notice a higher wireless speed?
I did not do any tests on this...
and to be sincere, when I tried 7.25beta and CPU spiked...
I didn't wait more than 5 minutes. after upgrade. Just downgraded.
having lazy Sunday, I had to try it, but no luck, it did not happened to me ;( I upgraded cAP first, then be3 CAPsMAN, later ax3, hAP be lite, all fine, only back-to-home needed to be regenerated because of certificate issue.
one improvement over 7.24.5: /app firewall rules are now being generated with correct vlan interface name
cAP XL ac free HDD Space: 7.24.5 - 116 KiB, 7.25rc1 - 508 KiB. Quite good.
