Before an upgrade:
Remember to make backup/export files before an upgrade and save them on another storage device;
Make sure the device will not lose power during upgrade process;
Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.26beta5 (2026-10-30):
- bridge - fix BPDUs leaking to the wrong dual-connected bond in MLAG (introduced in v7.24);
- bridge - fix incorrect root-path-cost calculation in MLAG when the root bridge is on a single-connected port (additional fixes);
- bridge - fix MLAG restarting when hardware offloading is re-enabled;
- certificate - allow to import certificate with iPAddress name constraints;
- cmr - fix MLD stations not shown in Clients table;
- cmr - fix WiFi client tx/rx rates showing 0 in Clients table;
- console - allow reading bar, meter and progress values through the REST API;
- console - fix G and M size suffixes being converted incorrectly;
- console - free-memory reported in B by system resource monitor;
- defconf - fix missing mld-datapath in CAP default configuration;
- disk - reject duplicate NVMe-TCP server NQN values;
- fetch - fix HTTP fetch getting stuck in a "bad HTTP response" state;
- iot - improve Bluetooth stability on KNOT Gateway devices;
- ntp - increase maximum peer count to 100;
- ptp - fix PTP support on CRS804-4DDQ;
- qos-hw - add multicast-packet-drop counter and reset-counters command;
- route - add RPKI ASPA validation support (additional fixes);
- routing-filter - fix host matching in address lists with more than 64 ranges;
- sfp - fix DAC EEPROM corruption when disabling 400G ports on CRS804 and CRS812 switches (additional fixes);
- sfp - improve SFP/QSFP auto-negotiation on CRS8xx series switches (additional fixes);
- ssh - fix packet alignment when SHA-1 is used (introduced in v7.25);
- switch - fix broadcast traffic still reaching the CPU when port isolation is used on Atheros and MediaTek switches (additional fixes);
- system - improve stability (includes CVE-2026-98432);
- tls - fix SSTP client failing to connect when no TLS 1.3 cipher is available;
- tls - fix SSTP server rejecting TLS 1.3 clients that prefer AES-128;
- tls - improve memory allocation/release process;
- webfig - fix device mode values not being fully displayed;
- webfig - fix multi-value fields being displayed as empty (introduced in v7.25);
- webfig - replace dashboard value bars with grouped bar graphs (additional fixes);
- wifi - initial 802.11s meshpoint interface mode implementation (CLI only);
- wifi-mediatek - fix client tx rate staying at minimum after roaming;
- wifi-mediatek - fix low throughput for TWT stations (introduced in v7.26beta1);
- wifi-mediatek - fix station connect failures after an AP band switch (introduced in v7.26beta1);
- winbox - add rpki-aspa status to route details;
- winbox - allow removing auto-generated app certificates;
- winbox - allow setting vrf for WireGuard interfaces;
- wireguard - ignore leading and trailing whitespace in peer public keys;
What's new in 7.26beta4 (2026-10-27):
- app - add remove-certificate command for certificates not used by any app;
- bgp - improve update processing performance when multiple peers are used;
- bonding - add lacp-strict setting for 802.3ad bonds;
- bridge - fix incorrect root-path-cost calculation in MLAG when the root bridge is on a single-connected port;
- bridge - fix loop-protect not working when a VLAN interface is added to the bridge (additional fixes);
- certificate - add option for pasting certificate in PEM format in add and import commands;
- certificate - fix CRL download failing when the server responds with an HTTP 3xx code;
- certificate - fix empty error message when ACME DNS validation times out;
- certificate - fix services continuing to use the previous certificate after ACME renewal;
- cmr - fix configuration display not showing effective values for unset fields;
- cmr - fix VLAN rules being applied to all ports when port-labels is not set;
- cmr - improve stability;
- cmr - replace dashboard value bars with grouped bar graphs;
- cmr - require write policy to run the alert test command;
- console - fix custom SSH client login parameters being ignored (introduced in v7.26beta1);
- console - fix deprecated argument names not being readable with get and proplist;
- console - improve stability;
- disk - fix NFS clients being served the wrong export after a reboot;
- ethernet - disable EEE on RB4011, RB1100AHx4, L009, L11, L23 devices;
- ethernet - do not allow adding duplicate RPS interface entries;
- ethernet - fix broadcast traffic still reaching the CPU when port isolation is used on Atheros and MediaTek switches (additional fixes);
- iot - fix LoRa channel configuration changes failing with a validation error;
- ipsec - fix XFRM interfaces staying down until a reboot;
- ipv6 - fix from-pool address lifetimes not updating after a prefix renewal (introduced in v7.25);
- l3hw - improve stability on CRS8xx series switches;
- log - fix logging actions with target=script not running the script after a reboot;
- lte - fix eSIM provisioning from the mobile app (introduced in v7.26beta1);
- lte - fix Telit LE910C4-WWX modem serial driver not binding at cold boot;
- lte - fix traffic not passing with multiple locally terminated APNs for R11e-4G modem;
- lte - reduce eSIM pending notification send retry count to 2;
- netwatch - fix check-certificate not working for HTTPS-GET probes;
- netwatch - fix wrong checksum in the first ICMP echo of a test on TILE devices;
- poe-out - fix missing status column in print output;
- ppp - fix BG770A modem not initializing after a firmware upgrade until a reboot;
- route - add RPKI ASPA validation support;
- route - fix routing memory statistics missing some memory pools;
- sfp - fix DAC EEPROM corruption when disabling 400G ports on CRS804 and CRS812 switches;
- socks - fix comments not being saved;
- ssh - refactor SSH internal processes;
- switch - add a high-priority CPU queue for control traffic on Marvell Prestera switches;
- switch - fix CPU-sent VLAN-tagged packets with the DEI bit being dropped on Marvell Prestera switches;
- system - improve stability;
- tr069 - add nodes for GPS information;
- usb - add overcurrent monitoring and per-port power cycle for hAP be3 Media;
- user-manager - fix database not opening after reboot when db-path is several directories below the mount point;
- webfig - fix missing default values for CMR label fields;
- webfig - fix the Power Cycle action not working;
- wifi - fix virtual interface restart loop when reselect-interval and reselect-time are configured (introduced in v7.25);
- wifi - initial easymesh controller and agent implementation (CLI only);
- wifi-qcom-be - fix station mode not connecting when limited to an older standard than the AP;
- wifi-qcom-be - fix station not connecting when limited to narrower channel than AP;
- winbox - allow adding LTE interfaces with a master interface and APN profile (additional fixes);
- winbox - make RPS menu configureable;
What's new in 7.26beta3 (2026-10-16):
- apptraffic - fix connection tracking not reverting to auto when apptraffic is disabled;
- bridge - add dhcp-snooping-option82-policy setting for handling packets that already carry option 82;
- bridge - add topology-change, host-moves and STP timer statistics to monitors;
- bridge - fix fragmented IPv6 traffic being dropped by DHCPv6 snooping (introduced in v7.23);
- bridge - fix static host entries being aged out of the hardware table;
- bth - fix allow-uploads being settable on shares that point to a file;
- cmr - add low-voltage-pd-detected poe status;
- cmr - add user attribution to log entries;
- cmr - allow using the WiFi SSID as an automatic label;
- cmr - do not create alert conditions when rebooted=no or unpaired-device-connected=no;
- cmr - fix channel width report for wifi stations;
- cmr - fix device identity changes not syncing with the server;
- cmr - fix failed upgrade alerts showing an incorrect version;
- cmr - fix layout node coordinates displayed incorrectly when negative;
- cmr - fix manual upgrade to a pinned version;
- cmr - fix missing application counters in the apptraffic view;
- cmr - fix missing device export command;
- cmr - fix pairing password requirement changes not being detected;
- cmr - fix pairing state after a failed password pairing;
- cmr - fix setting port-labels for multiple ports from the CLI;
- cmr - fix the first interface-change alert not firing;
- cmr - fix upgrade "show-devices" listing non-paired devices;
- cmr - fix wifi-logs showing entries from unselected devices;
- console - fix /cmr configuration missing from the export;
- container - add label support;
- defconf - disable FTP and Telnet services;
- defconf - fix boot device selection after configuration reset with keep-apps=yes;
- discovery - do not send LLDP power requests before the default configuration is applied;
- disk - fix all-zero NGUIDs on NVMe over TCP exported namespaces;
- disk - fix newly formatted Btrfs disks failing to mount (introduced in v7.26beta1);
- dot1x - fix MACsec not working between ARM and MIPS devices;
- dude - replace dude 32-bit client with 64-bit version;
- ethernet - fix broadcast traffic still reaching the CPU when port isolation is used on Atheros and MediaTek switches;
- ethernet - fix occasional packet loss on hAP be Media;
- ethernet - fix spurious duplicate MAC address warning on WDS interfaces;
- evpn - fix MAC-IP route origination and withdrawal (introduced in v7.25);
- iot - fix LoRa gateway packet validation when transmitting;
- ipsec - fix IKEv2 EAP-TTLS client failing with invalid trust store (introduced in v7.21);
- ipsec - fix policies not being loaded after an upgrade (introduced in v7.25);
- l3hw - add VXLAN offloading to CRS8xx series switches;
- l3hw - fix hardware offload for active-backup bonds;
- l3hw - fix hardware offload for VLAN interfaces created directly on Ethernet ports on CRS8xx series switches;
- l3hw - fix offload issues on ECMP routes with non-offloadable paths;
- l3hw - fix packet loss when a directly connected host moves from a bond to Ethernet;
- l3hw - gate L3 hardware offload by the port's L2 hardware offload state;
- l3hw - stop forwarding packets through an unreachable nexthop;
- lcd - improve stability when changing the color scheme after touchscreen recalibration;
- leds - fix Audience front LED when wifi is managed by wifi-qcom-ac;
- log - fix the default flag not being shown for the default configuration log rules;
- lte - clear the cached eSIM profile list after a SIM change;
- lte - fix dialer for D-Link DWM-222W modems (additional fixes);
- lte - fix iOS tethering not obtaining an IP address;
- lte - fix linkup only after link-recovery-timer after firmware-upgrade on RG650E-EU modem;
- lte - fix packet loss with R11e-LTE-US modems (introduced in v7.21);
- lte - fix QMI modems waiting out the full link-recovery-timer after re-attaching;
- lte - fix Telit LE910C4-WWX modem not initializing after a cold boot;
- lte - improve modem firmware-upgrade for EG800K-EU modem;
- lte - improve stability for devices with QMI modems;
- lte - keep the "auto" MTU option on LTE interface after reboot (additional fixes);
- lte - prevent removing an APN profile that is still in use by inactive interfaces;
- mpls - fix dynamic-label-range rejecting a valid 1024-label range;
- netinstall - add force stop for in-progress installations;
- netwatch - improve stability when deleting https-get probes;
- poe-out - fix export not showing the configuration under the poe submenu;
- poe-out - fix poe-in voltage monitoring and LLDP power requests on hEX S (2025) devices;
- routing-filter - fix any-regexp community matcher matching an empty community attribute;
- routing-filter - fix community delete, filter and modify with regexp-only community lists;
- sfp - fix host link breaking on S+RJ10 modules when changing advertised modes;
- sfp - improve link stability for QSFP28 breakout ports to prevent interface lane flapping when one lane goes offline;
- sniffer - fix long-running captures failing after approximately 4.3 billion packets;
- snmp - add ospfAdminStat and ospfRouterId to the OSPF MIB;
- ssh - fix a failed command returning a successful exit status;
- switch - fix egress rate limiting with jumbo frames on Marvell Prestera switches;
- switch - fix link flapping on QSFP cage ports when connecting to NVIDIA DGX Spark;
- switch - fix VLAN-tagged traffic being looped back in MLAG setups on CRS8xx series switches;
- switch - improve SFP/QSFP auto-negotiation on CRS8xx series switches;
- system - fix interface statistics for third-party monitoring tools;
- tls - add Renegotiation Indication Extension support;
- traffic-flow - add post-NAT IPv6 addresses to NetFlow records;
- traffic-flow - fix CPU usage being classified as networking in the profiler;
- webfig - add on-demand loading of directory contents in the Files menu;
- webfig - fix static IPv6 addresses showing wrong lifetime values;
- webfig - improve network topology view performance;
- wifi - add station-bridge and station-pseudobridge mode support for MLO stations;
- wifi - fix client isolation assigned via RADIUS being lost after roaming;
- wifi - improve stability when disabling an AP with multiple connected stations;
- wifi - initial MLO station mode support on 802.11be devices;
- wifi - make station interfaces compatible with access points that do not retransmit EAPoL message 1;
- wifi-mediatek - fix roaming between APs belonging to the same MLO group;
- wifi-mediatek - improve stability when MLO stations connect;
- wifi-mediatek - update radio regulatory information;
- wifi-mediatek - update the wireless driver and firmware (additional fixes);
- wifi-qcom-ac - fix traffic being sent to the wrong station after a station-bridge roams between APs;
- winbox - add a comment field to the DNS adlist window;
- winbox - add the default-country parameter to wifi radio settings;
- winbox - add wpa3-psk-gd to wifi security profile authentication types;
- winbox - add ZeroTier controller, member and peer hint settings;
- winbox - allow adding LTE interfaces with a master interface and APN profile;
- winbox - display the "forced-on-bt" PoE-out mode set from the CLI;
- winbox - fix bridge filter window disabling valid fields for IPv6 rules;
- winbox - fix wifi radio band selection not being available in radio settings;
- winbox - hide ACL rule counter tools and graphs on non-Prestera switches;
- winbox - rename last-member-interval to last-member-query-interval;
- wireguard - ignore disabled peers when checking for duplicate Allowed Addresses;
- www - fix REST API login for users with rest-api policy, but without api policy;
What's new in 7.26beta1 (2026-10-01):
- bridge - add a per-VLAN DHCP snooping option;
- bridge - fix loop-protect not working when a VLAN interface is added to the bridge;
- bridge - show if bridge port is blocked by dot1x;
- bridge - store hw option for disabled bridge ports;
- cmr - add initial implementation of centralised platform for RouterOS devices, allowing updates, monitoring, alerts and other options;
- container - add /app menu to ARM32 devices;
- crypto - improve ECDSA and EdDSA key and signature validation;
- dhcpv4-client - improve stability when the interface is deactivated while the client broadcasts a DHCP release;
- dhcpv6-server - add a dns-none option to not include DNS options in responses;
- dhcpv6-server - fix a DHCPv6 server failure when the RADIUS reply contains an empty delegated IPv6 prefix;
- dns - improve service stability on HTTP/2 DoH connections;
- ethernet - improve stability on devices with Intel I226-V network controllers;
- ethernet - move the port bandwidth setting to the switch port menu;
- files - improve stability when moving directories to external storage;
- interface - show if interface is blocked by stp or dot1x;
- ipsec - fix IPsec tunnels failing after migration from the old QKD settings;
- ipsec - fix IPsec tunnels not establishing when an address my-id is configured on the responder;
- l3hw - add VRRP hardware offloading support;
- log - add the container name to CEF logs;
- lte - do not reconfigure if not RouterOS activated CID is deactivated for R11l-LTE7 modem;
- lte - fix dialer for D-Link DWM-222W modems;
- lte - fix IPv6 route not being added on modems that do not report a gateway via control interface;
- lte - fix modem firmware-upgrade failing when SMS polling is enabled;
- lte - fix multi-APN passthrough stopping when one APN fails to connect;
- lte - fix multi-APN passthrough stopping when one passthrough-interface VLAN is down on the CPE in multi passthrough interface setup;
- lte - fix passthrough cleanup when the lte link goes down for QMI modems;
- lte - fix recurring LTE disconnects R11e-LTE-US modem and some Sierra modems;
- lte - keep the "auto" MTU option on LTE interface after reboot;
- lte - reworked multi-apn support. Added support for slave APN interface add/remove;
- netinstall - install the package version of the configured update channel;
- ovpn - improve stability in UDP Ethernet mode when the TX queue is full;
- pim - fix a routing process failure when the hello-delay is set to 0;
- ptp - fix PTP not working on a VLAN-aware bridge when IGMP snooping is enabled;
- qos - fix per-queue counters after a switch restart (introduced in v7.23);
- quickset - fix the WAN interface being selected incorrectly;
- reverse-proxy - fix setting the VRF parameter for reverse-proxy rules via CLI;
- switch - add interface-list support to port isolation;
- switch - fix high CPU usage when removing switch VLANs on Atheros-based switch chips;
- switch - fix switch rules not working on Atheros-based switch chips;
- switch - fix switch rules port matchers not working on IPv6 traffic on Atheros-based switch chips;
- switch - fix switch rules with rate limits stopping traffic on CRS3xx devices;
- switch - improve stability on CRS326-24S+2Q+ devices;
- system - stop the flash configuration store from growing on dynamic configuration changes;
- webfig - add conditional coloring of cells in tables;
- wifi - add a default-country parameter in radio settings (CLI only);
- wifi - fix WPA3 SAE authentication issue for ECC group 21 (introduced in 7.24.3);
- wifi - implement channel.reselect-interval feature for missing drivers;
- wifi - reuse freed station association IDs;
- wifi-mediatek - update the wireless driver and firmware;
- wifi-qcom - fix antenna gain setting not affecting transmit power (introduced in v7.24);
- winbox - add the interface column to the OSPF neighbor list;
- winbox - rename "minimum-version" to "minimum-firmware" under "System/RouterBOARD" menu;
- winbox - show warning messages under "System/Users/SSH Keys" and "System/Users/SSH Private Keys" menu;
- wireguard - do not show an interface as running when it has no peers;
- wireguard - fix a client-dns value that could not be removed in WinBox;
- wireguard - fix a peer that would not work after import when no endpoint address is set;
To upgrade, click Check For Updates under System/Packages menu and select the testing Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
- Everything went smoothly
- I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)a
- I encountered an issue, but solved it (please post the solution)
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
