Sorry, I asked sol to write this because my english is not good enough, but something broke on my end with the beta 8
"IPv4 TCP/HTTPS stalls after upgrading to 7.26beta8 — disabling FastTrack HW offload restores connectivity
After upgrading my CCR2116-12G-4S+ from RouterOS 7.26beta7 to 7.26beta8, I experienced widespread IPv4 connectivity problems across the LAN.
Symptoms:
- IPv4 pings and DNS resolution still work.
- IPv4 TCP/HTTPS connections time out or stall. Some connections establish successfully, but subsequent TLS/HTTP exchanges stop progressing.
- IPv6 connectivity continues to work normally.
- The router itself can reach Internet destinations over IPv4.
- The WAN DHCP lease and active IPv4 default route are present.
The primary WAN uses a VLAN interface, with IPv4 masquerading. FastTrack is configured for established/related TCP connections with hw-offload=yes.
Relevant hardware settings before the issue:
/interface ethernet switch
set switch1 l3-hw-offloading=yes
/interface ethernet switch l3hw-settings
set fasttrack-hw=yes
The active physical uplinks already have l3-hw-offloading=no at the switch-port level.
Troubleshooting
Temporarily excluding one LAN client’s HTTPS connection to 1.1.1.1 from FastTrack immediately restored access. Removing that exclusion reproduced the failure.
I then disabled only FastTrack hardware offloading:
set fasttrack-hw=no
This restored IPv4 connectivity without disabling software FastTrack or changing the NAT, routing or security policies. Software FastTrack remains active, confirmed by connection flags and increasing counters.
After this change, HTTPS requests to several independent sites and an IPv4 download succeeded. IPv6 also continued to work.
This suggests a possible regression involving the FastTrack hardware-offload path in 7.26beta8, although the exact cause has not been established.
Has anyone else observed this on a CCR2116 or another Marvell Prestera device?"
