7.26beta [development] is released!
ughhh.... it hurts my finger scrolling the list :slight_smile:
Edit:
RB450G updated, no visible problems. iBGP reflector, OSPF ... nothing special but not a typical home router.
Upgraded my CMR and all good and then I upgraded the connected client and all good there as well however, upgraded via CMR, the progress is stuck at 20 % in the GUI however status is done.
WOW!
Are we really getting two interventions in the MPLS stack in the same release?
  • And I’m not just talking about how RouterOS or Winbox displays existing information.
This feels like a trap... They’re trying to get our hopes up.
All that’s missing now is an intervention in the MPLS forwarding plane—not just the control plane—and that would honestly bring a tear to my eye.
*) winbox - show the 2g-probe-delay value on wifi interfaces when a steering profile is applied;
minute detail, but glad it got fixed since the report :slight_smile:
I pray nightly for RSVP Fast Reroute and eVPN/MPLS
When roaming from ax2 (7.25.2) to hap ax s (7.26 b7), the channel speed gets stuck at 54.0 Mbps. CAPsMAN manager on RB5009UPr+S+ (7.25.2).
channel speed
Disable ft-over-ds; it's a known issue with Apple devices.
I had the same problem with other non-MikroTik APs as well.
Roaming from AX2 to AX3 is no problem & Roaming from AX3 to AX2 is no problem.
Suspected 7.26beta7 regression — frequent IPv6 BGP Hold Timer Expired on CCR2216; 7.25.2 unaffected
Hardware Off load on Prestera for MPLS encapsulation for L2VPN and L3VPN ?
6VPE support over IPv4 infra.
after a day, clients keep connecting to be lite, looks like b7 solved that issue, thanks
Does it depend on which Apple device? An iPhone 16 and a iPad Pro M4 work just fine without issues with ft-over-ds.
Wondering about the same. No issues observed with an Apple only household so far.
I found this paper by Cisco that gives a reason why one might prefer over the air:
https://www.cisco.com/c/en/us/products/collateral/wireless/access-points/enterprise-best-practices-ios-ipados-wp.html#80211rFasttransition
Kind regards,
Patrick
CMR "half-paired" client...
We re-ran our CMR lab on 7.26beta7 (x86 CHR).
The issue. With the defaults (client pairing-requirement=password, controller per-device confirm), the manual's one-command pairing often ends in an incomplete state:
/cmr/device/pair [find identity=cmr-client] username=<client user> password=<client password>
Its output ends with device:ok, cmr:ok instead of paired. Then:
  • the client shows paired,connected, so it looks fine from the client side;
  • the controller row keeps state="pair: device:ok, cmr:ok", and run-script answers no devices selected;
  • the session is idle (keepalives only);
  • even after a /cmr set enabled=no and enabled=yes, or a reboot of either side, still shows device:ok, cmr:waiting confirmation.
One more bare /cmr/device/pair [find identity=cmr-client] fixes it, and that fix survives a restart. But the "second 'bare' pair" should not be required. What remains unknown is that sometimes the first command does work.
How often on 7.26beta7: 7 of 9 single credentialed pairs over three fresh boots (beta5: also 7/9), and 22 of 24 in a second run with a packet capture. Splitting the two approvals avoided it every time (27/27). We tried three ways: a bare pair first and then the credentialed one; /cmr/client/pair on the client; or client pairing-requirement=none and then a bare pair.
It is not our test harness. We checked whether REST or the lab's extra NIC caused it:
  • It also happens with pair typed on the serial console, with the CHR's management NIC disabled on both routers. No REST is involved.
  • pair stops by itself after two status rows: device:password required, cmr:waiting confirmation, then paired or device:ok, cmr:ok. Over REST it returns in about 1 s, with or without duration=30s.
  • On the wire, every pairing opens the same way (97, 88, then 87 bytes). The client's next reply decides it: one 108-byte message leads to a half-pair, and 71 + 66 bytes leads to a commit.
  • A possible clue: when the client's second NIC (the one holding its default route) was disabled, 19 of 20 typed pairs committed, against 6 of 14 with it up. We have not captured what the client sends there during pairing.
Expected: the single credentialed pair either commits both approvals, or does not report success.
The other beta7 CMR lines, checked against beta5:
  • cmr - add VRF support for the CMR client: works. With the client's link in a VRF, /cmr/client set vrf=… reconnects it, still paired. It is not in the manual yet.
  • cmr - do not fail an upgrade when the device is already on the requested version: confirmed. The job now ends success=1/1 (beta5: 0/1), with no reboot.
  • cmr - fix import failing with duplicate device ids after exporting CMR settings: importing /cmr/export back onto the same controller still fails with failure: duplicate ids on the first /cmr device add. That line is the controller's own row, and /cmr/device/remove [find] does not remove it. Is the fix meant for importing on a different or reset controller?
Unchanged from beta5: a run-script line on the client still does more than the manual's read,write,test,reboot allow. For example, /user add group=full succeeds and secrets print in clear text.
Full results, raw evidence and the scripts to reproduce (disposable CHRs under QEMU):
This sounds interesting. Except I just don't know what that even means. The [native] API docs aren't changed, so if it's something there, IDK how to trigger it. And it by "API" you mean "CLI", I don't see any as-json or anything like that in the diffs. If it a console/setting, I don't see it. And the REST API is already JSON.
Going to need a better clue here.
We test MLAG on RouterOS 7.26beta7 (CHR arm64, Containerlab 0.83.0). We saw the same RSTP problems earlier on two CRS326-24S+2Q+ and on CCR2004. Every count below is generated by the test suite: Faults across runs. Setup and reproduction steps for points 4 and 5 are in the report.
1. RSTP/MSTP: the MLAG secondary sends no BPDUs while the MLAG primary reboots
With the MLAG pair as root, an MLAG primary reboot stops traffic: RSTP 3 of 3 runs, 10.49–11.65 s; MSTP 4 of 4 runs, 10.87–13.08 s. This includes mlag-lacp-fallback=no, lacp-strict=yes, a named MSTP region and an MSTI per VLAN. The last BPDU from the primary is at 4.8 s (L184). The secondary stays connected/secondary and root, but sends no BPDU (L257). At 11.08 s the access switch makes itself root (L256). The secondary's first BPDU comes at 22.22 s (L488).
2. Two MLAG pairs with RSTP: the other pair takes over as root
When pair A's MLAG primary reboots, pair B makes itself root (L614), in 2 of 2 runs, with equal or per-pair bridge priorities. Traffic stops for 16.29–17.59 s.
3. Withdrawn. The result with the access switch as root is not traced yet. We will post again once it is.
4. Frames sent back out a dual-connected MLAG bond (report fault 1; the "packets looped back to a dual-connected bond" fix listed for 7.25.2 and 7.26beta7 does not fully hold on 7.26beta7)
After a bond member or an MLAG peer returns, an MLAG peer sends frames from the peer port out a dual-connected MLAG bond, back to their sender or a second time to another host.
  • STP off, Small lab, broadcast and unknown unicast: member flap 4 of 4, MLAG primary reboot 3 of 3, MLAG secondary reboot 2 of 2, MLAG secondary power loss 2 of 2. None in primary power loss, single member loss, peer link loss or MAC move (result). At that moment the member is ATG---FE and the bridge port is forwarding (L57).
  • Medium lab, unicast, MLAG peer reboots: RSTP with the pair as root, primary 2 of 3 and secondary 3 of 3; MSTP with the pair as root, primary 2 of 4 and secondary 0 of 4; MSTP with the access switch as root of VLAN 110 only, secondary 4 of 9 and primary 0 of 9. None with STP off (result).
5. Two MLAG pairs with STP off: about 20 s outage on an MLAG primary reboot (report fault 2)
The other pair keeps sending out its member toward the rebooting switch after LACP expired it (ATGS---E), and the bridge port stays forwarding (L332). Pair A primary reboot 3 of 3, 19.67–23.34 s; pair B primary reboot 2 of 2, 20.66–22.18 s.
Questions
  • Should the MLAG secondary keep sending BPDUs for the pair while the MLAG primary is down?
  • Should an MLAG bond whose local member is not LACP-distributing stay a forwarding bridge port?
The test suite and run data are public: GitHub - narrowin/mikrotik-mlag-testsuite: test mikrotik mlag with containerlab · GitHub. Packet captures are not public; we can send them on request.
Edit 25 Nov: all counts now come from the generated table, point 3 withdrawn until traced, report fault numbers added.
For reference, @mischa01101's MLAG report above is filed as SUP-228968. Lab setup, results and the ongoing discussion are here:
The repo has the test suite plus the configs, timelines and results from every run, so each finding can be checked down to the exact line.
PS. IMO it would make sense for MikroTik to run a lab like this as part of their own development and release testing. It might have caught some of this earlier. If I were in charge, MLAG tests like these would definitely be a key part of the CI/CD pipeline.
@Amm0Bot Thank you for the detailed report.
We have reproduced it on 7.26beta7. With the default pairing requirements, a single /cmr/device/pair with the client's credentials sometimes stops at device:ok, cmr:ok. The client then shows paired,connected,
but the server does not finish its side, and run-script answers no devices selected. It is registered as a bug.
I would trade RSVP for SRv6.
I’ve been studying SRv6 recently.
I’ve already deployed it in test scenarios, as well as in very simplified setups for proof-of-concept purposes.
This time, I’ve been looking at SRv6 "under the hood"—examining the RFCs and how it’s implemented in FRR.
I was surprised to find it much less complicated than I had imagined.
The IPv6 stack itself—the header stacking—seems quite straightforward to implement.
In that regard—barring how MikroTik might choose to implement their own way to talk to switch chips (using their own custom approach rather than the chip vendors' standard SDKs)—I don’t see any obstacles to RouterOS supporting SRv6.
As for the TE (Traffic Engineering) component—handling constraints and calculating paths to reach specific segments—I believe the existing mechanisms in RouterOS cannot be reused and would need to be rewritten.
I would really love to see the beginnings of SRv6 support in RouterOS.
