Sorry, but You haven’t understand me…
I wuld like to use ONLY 40Mhz-Ce or 40-MHzeC, but NOT 20/40MHz, because at noisy environment it very, very frequentry chanfing beteween 20/40MHz. But i would like to use only 40Mhz.
40MHz-Ce or 40MHz-eC would be 80 MHz wide
20MHz-Ce, 20 MHz-eC, 20 MHz-xx is 40 MHz wide.
The “20/40MHz Ce” setting is confusing, should be “20MHz Ce/40MHz”
Why use single chain with the SXT-ac, it’s a dual chain device. 20MHz-Ce/2S (40MHz/2S) has double the speed of 20MHz-Ce/1S (40MHz/1S)
(See http://mcsindex.com/, for the 40MHz column single stream HT-MCS07 (150Mbps) versus 20 MHz dual stream HT-MCS15 (144Mbps))
Look at the 802.11ac standards to find out how a transmitter decides to use one 20MHz channel or two 20MHz channels. It’s different from 802.11n. For 802.11n both channels must be clear for transmission, in 802.11ac the clear channels will be used, they don’t have both to be free.
When transmissions fail, the transmitter will step down the number of streams, MCS rate, and channel width, … until it works, or it totally fails = disconnect.
The algorithm on what to stepped down first, is not documented. It’s different from older ROS versions <5.9. (MUM presentation somewhere: Wireless Tips and Tricks for RouterOS v6
MUM South Africa 2013 Johannesburg Uldis Cernevskis MikroTik)
If the CCQ is excellent, but still the interface rate is stepped down, then there is interference from time to time (other transmitters, even other than 802.11, like nv2 or some remote controls)
If the other is in continuous transmission, the CCQ would drop, because of the many failed transmissions. (CCQ for that connection in the registration table)
“802.11 will reduce speed until it works”. You can set the max speed, but must let 802.11 step down, or you will frequently lose connection.
