I want to add a RouterOS device which i change its winbox port number but it cant be connected unless i set it to default port
also i cant change background or add any photo to Dude
Any answer ?
Sinan, did you tried the following solution?
http://forum.mikrotik.com/t/the-dude-v6-38rc-test-builds/101859/1
You can specify probe port under device settings => Services => routeros mangement => Probe Port
yes i tried but it doesnt help me
Hello, Sinan!
It was verified in test environment that this solution works: Specify custom Winbox port for ROS device in Dude.
During verification we found some issue and reported it to Mikrotik support.
Thank you!
