All physical interfaces (except WAN) are contained within one bridge, why?
ex1:I have this working setup
WAN
…|5.x.x.x
WAN_Router
|192.168.10.1/24
p1|192.168.10.5/24
MT Router
p2..p5 4xTrunk
All my VALNs are located one one Bridge just as in the forum:
But, MT p1 serve as VLAN_10 and WAN at the same time! MT p1 is a untagged port to VLAN_10
-DefaultRoute & DNS: 192.168.10.1
In my firewall i use this (!ProtectedAddr is the 192.168.10.0/24 net) to prevent other VLAN to access VLAN_10 when they want WAN access.
/ip firewall filter add action=accept chain=forward comment=“no custom dns & no protectedIP”
dst-address-list=!ProtectedAddr dst-port=!53 in-interface-list=GuestLAN out-interface-list=BASE_WAN protocol=tcp
ex2:I consider to change the above to this
Then it will follow the, All physical interfaces (except WAN) are contained within one bridge.
But will it work?
WAN
|5.x.x.x
WAN_Router
|192.168.1.1/30 (only 2 real ip)
p1|192.168.1.2/30 (only 2 real ip)
MT Router
p2..p5 4xTrunk
-DefaultRoute & DNS: 192.168.1.1
Then VLAN_10 is now like all the other VALNs and i put a new ip/segment at MT p1 and the other router.
I have also removed MT p1 from the bridge, and assigned port p1 the ip 192.168.1.2/30 (only 2 real ip).
To protect the WAN_Router & MT p1 in segment 192.168.1.1 & 192.168.1.2 i think i still need the same firewall item?
Now to my question, what is the difference in the two setup? And what is the preferred one?
(Dont suggest i remove the WAN_Router, i wont)
Network diagram
Complete config /export
Dont really care about the unreadable attempt to explain anything,
Express yourself in terms of requirements.
Identify users/devices and groups of users/device (including the admin) and express
  • what they should be able to do
  • what they should NOT be able to do
Then a rational config can be prescribed.
A bridge is a virtual interface used to switch traffic between hosts.
So all member ports of a bridge are capable of communicating with each other in Layer 2…
http://forum.mikrotik.com/t/routeros-bridge-mysteries-explained/147832/1
That is a complicated explanation for otherwise a simple answer…
Yes i have read the link posted, but still see any problem in doing as i do in the first setup i running. As in the next setup i isolated the WAN port in then MT as p1.
Still i dont see any main difference when using the firewall as i show in ex1 and want to reuse in ex2
-Now to my question, what is the difference in the two setup? And what is the preferred one?
You will have to take that up with the author as I don’t think he was answering the same angle of question but I am supposing the ‘article’ could be expanded to be more encompassing. :slight_smile:
