I’m setting up a MikroTik router for a small business office (around 20–25 users). While going through documentation, I realized there are so many configuration options related to firewall, VPN, and access rules.
Since this forum has many experienced MikroTik users, I’d like to ask:
What are the recommended best practices for securing a MikroTik router in a small business environment?
Should I enable only specific firewall rules, or is there a standard template that works well?
Any common mistakes beginners make that I should avoid?
To trick hacker and waste his time when trying to hack admin account, if somehow attempt was successful, he will be disappointed after realizing that admin account has no rights and he will jump through the window in despere
Do you recommend no MGMT by wifi because wifi can be hacked? For me, there is a very high PITA factor for only managing via wire. I would appreciate further explanation of this recommendation.
I some way it is, if someone hacks fake admin account you will probably noticed it (even some login alarm can be scripted) and take some measures to prevent further attacks while attacker will not have any rights with such account to do some damage. If attacker was spending time to attack real admin account and succeed it will do some damage while is detected too late.
Wi-Fi can be intercepted and hacked somehow without physical access...
Is point #10:
If you DON'T know how to work around something security, assume there's definitely someone who does.
To access some of the main machines, you have to physically go there, or you have to use the fiber optic cable I rent between the office and the data center.
Of course, if the secret services come and intercept the cable, etc...
These are my recommendations, everyone can do as they wish.
Oddly enough, there are some RouterOS machines on my network and a few "forgotten" ports left open... on purpose...
A word to the wise.
As others have written,
it's easier to spot a mistake if the hacker is wasting time with something virtual and completely useless...
Like finding the password to a useless account, or hacking a virtual machine that... is useless...
@holvoetn
The advice to keep the admin account active anyway, turned out to be useful because whether the account exists or not, whether it is active or not, previously gave milliseconds of different response in which you could guess whether that account existed or not, active or not...
If you're doing it for a small business, best advice would be to hire someone that has enough knowledge/experience and can set this up accordingly. Default is fine, you start from that.
The biggest mistakes people do:
not keeping their devices up-to-date.
not taking backups.
when things are not working/behaving as they expect they start enabling/disabling stuff or allowing things they lack a proper understanding of.
allowing management from the outside.
not considering the internal LAN and assuming all bad things must always come from outside.
If you have 20 people in the office and your network is compromised and they cannot work, even if you do not lose data but it takes you a day to restore operations, that's the equivalent of a month's salary for a full time employee. If you lose data or it takes you longer to recover, then it'll cost you even more. I'm quite sure it will not cost you that much to have a network engineer setting this up for you. And it's a business, so it's deductible.
Don’t be fooled by posts from newcomers, especially those containing out-of-context links.
These posts are created solely to trick you, in the hope that you’ll respond.
Sure, I agree with you completely, but I was replying to Bogdano, who has been here since 2023.
If there was something wrong with the thread, the mods should have taken action much sooner - though, in my experience, they’re always the quickest and most precise when it comes to responding to criticism of MikroTik, even when that criticism is constructive.
It's impossible to act when a user circles back to insert a spam link. Users also can help notifying when this happens.
And I think the response time after the flagging was rather short.
