I’ve been using the long term update channel for awhile now, after noticing that my WiFi became extremely flaky after upgrading to newer versions. Today I finally had some time to diagnose the issue, but was unable to fix it. I noticed that only the 5GHz network stopped working and that the associated bridge port is inactive with the error "is already a slave". I was unable to find out why. My cAP has a similar config, but that upgraded just fine. I hope someone is unable to pinpoint the issue and that this is the proper category for this question.
I am sorry to say that configs generally make me go cross eyed.
But let's start with what kit you have and what wireless you are expecting.
You have some sort of Chateau pro ax which is itself an AP and you have another AP?
You are expecting to find SSIDs 'Trusted' and 'Untrusted' from both units on both 2.4 and 5, which is working for the other AP but not for the Chateau? Can you confirm this and say what you are actually seeing from the Chateau?
MikroTik Chateau PRO ax and MikroTik cAP ax.
Trusted is 2.4GHz and 5GHz.
Normally I use the same SSID for 2.4GHz and 5GHz, but due to this issue I splitted the SSIDs.
UnTrusted is 2.4GHz only and a slave of Trusted 2.4GHz.
Yes. This setup works on older RouterOS versions (7.20.x) on both devices. On the current stable (7.22.3) and long term (7.21.4) the Chateau allows devices to join the network, but these disconnect, I assume due to the bridge port no longer working.
But don't make the usual presumptuous mistake: paste the entire configuration.
(Obviously, be EXTREMELY careful not to post your username/password or serial number on the forum.)
Consistently censor the sensitive parts without removing them.
Since CAPsMAN is disabled, you can ignore these read-only values.
I’m quite positive I only left out irrelevant stuff such as firewall rules, wireguard config, adlist config, IP address allocations, static DNS records. I don’t see any of these being relevant for this issue.
Okay, I'll leave you to your own device, but check out all the other topics...
Often, the "I know where the problem lies" people... don't solve the problem...
(ok, for sure not lists static DNS and dhcp leases or firewall address lists, no scripts and no schedules...)
JFYI, you are in blatant violation of Rule #12: The twelve Rules of Mikrotik Club
(there are reasons why the more experienced members ask for the FULL configuration)
What's the point of trying? At most, you'll solve other problems...
Given the rest of the configuration, the script to paste is this:
# fix *9 error (default "bridge") and set to default values (they have never been set by the user)
/disk settings
set auto-media-interface=none auto-media-sharing=no auto-smb-sharing=no
# fix *2000011 error (default "LAN")
/tool mac-server
/tool mac-server mac-winbox
# this is for 2 rules (input and forward), with same description
/ipv6 firewall filter
set [find where comment="defconf: drop everything else not coming from LAN"] in-interface-list=!LAN
# alignment with NEW default values on RouterOS 7.22.3 (they have never been set by the user)
/interface ethernet switch
set 0 cpu-flow-control=no
/interface ovpn-server server
remove [find]
/ip ipsec profile
set [ find default=yes ] dpd-interval=8s dpd-maximum-failures=4
# remove unused datapath on wifi settings
/interface wifi datapath
remove [find]
and an extra script, not related to the problem, for use the new fasttrack, if the device support it:
Simple: Maybe if some internal function that checks whether interface are already busy or not fails due to unsatisfied *xxx indexes,
perhaps by removing the errors the function executes correctly.
I’ve made the changes you suggested. Unfortunately the issue still persists; Trusted5 is still “already a slave” after re-adding the bridge port. New config:
